Old 04-22-2006, 02:35 AM   #1
CarlitoQC
Member#: 83097
Default EJ25 compression
The dealer said compression Cyl. 1-2 = 195 & cyl. 3-4 = 190. What are normal/good compression readings? Legacy 98 GT 2.5L
CarlitoQC is offline   Reply With Quote
Old 04-22-2006, 09:02 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
According to the FSM, it should be 176psi, so you're looking pretty damn good. How many miles on it?
Pat Olsen
'97 Legacy 2.5GT sedan
Old 04-22-2006, 12:51 PM   #3
CarlitoQC
Member#: 83097
98 GT 5-spd... almost 122000 miles
Old 04-23-2006, 12:41 PM   #4
CarlitoQC
Member#: 83097
anyone else want to post their last compression results? Just to have a better idea here
thanks
Old 04-23-2006, 02:10 PM   #5
flanders
Member#: 76382
2000 BH
BP Wannabe
I've never had the compression cheched on my bucket, I did ask for it to be done during my 100k service but a boatload of issues came up and I didn't press the issue.
Honestly, I don't think I want to know.
flanders is offline   Reply With Quote
Old 04-23-2006, 08:27 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
if your compressoin results are 10% above factory, you have a good motor, especially since you have 120k on the odo.
~Josh~
Old 04-23-2006, 09:07 PM   #7
CarlitoQC
Member#: 83097
glad to here. so factory is 176 PSI. thanks now i feel a little safer to invest on my GT
Old 04-24-2006, 10:59 AM   #8
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
I just ran a cold compression test on my sedan the other day, between 190 and 195 across the board. I don't know if running it warm would make a difference.
The strange thing about that is that it has a leaky headgasket (blows bubbles in the coolant overflow), so I was expecting it to be lower.
Dan Cech is offline   Reply With Quote
Old 04-24-2006, 06:11 PM   #9
CarlitoQC
Member#: 83097
hummm pretty bad post now i feel unsafe
thanks for the info tho
EJ25 compression ratio Chi_San Normally Aspirated with bolt-on Forced Induction Powertrain 2 08-14-2005 05:37 AM
how to properly do a compression test for a ej25 latinskllz Service & Maintenance 9 11-29-2004 12:57 PM
DOHC EJ25 Compression Honkey3k Legacy Forum 1 07-21-2004 10:39 PM
EJ25 Compression Test Results at 50,000 miles latinskllz Normally Aspirated Powertrain 4 11-11-2002 02:46 PM
