Old 04-22-2006, 06:53 PM   #1
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default ej20 rods are the same as the ej22t correct?
is it just a different size crankshaft in the ej20 from the ej22t are the pistons and rods the same dimensions...will they fit??my machine shop guy is going on my word that the rods for the ej20 are the same as the ej22t rods... anyone verify?
going with Scat H beam rods, and J&E pistons.
IllNastyImpreza is offline   Reply With Quote
Old 04-23-2006, 08:01 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
the rods and crank are the same....rods are 5.137'', and the crank is 75mm. the only difference is in the bore.
~Josh~
Old 04-24-2006, 12:47 AM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
saweeet thanks
Are the '06 WRX shocks the same as the ones on the '02-'05 WRXs? Chiketkd Brakes, Steering & Suspension 1 01-30-2006 03:34 PM
Are the brake pads on the 98 2.5RS the same as the 02 WRX? zroom tsuchiya Brakes, Steering & Suspension 4 08-09-2005 11:08 PM
Are the doors on a WRX wagon the same as the sedan? MannyMoehawk#5 Interior & Exterior Modification 4 06-29-2005 09:34 PM
04+ Springs the same as 02-03 correct? xEclipsE RaceRx Brakes, Steering & Suspension 5 04-29-2005 04:35 PM
are the AT diff carrier the same as the mt diff carrier? scobaru Transmission (AT/MT) & Driveline 4 08-14-2003 02:43 PM
