Old 04-23-2006, 12:24 AM   #1
blue blurr
Member#: 51111
Default Possible to make Hks SSQV recirculating?
I have been wondering for awhile if there is a way to make the Hks SSQV recirculating like stock? Maybe some kind of adapter that screws onto the top that allows it to pop into the return hose? Any info someone has would be great
blue blurr is offline   Reply With Quote
Old 04-23-2006, 01:05 AM   #2
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
HKS sells a recirculating kit. You can read about it here
http://www.hksusa.com/categories/?id=1063
it shows universal kits and parts, but I'm sure if you call them they can help.
kingtut12 is offline   Reply With Quote
Old 04-23-2006, 12:00 PM   #3
blue blurr
Member#: 51111
Thanks! I just orderd the fitting, I will try and use the stock hose, see if that works.
Old 04-23-2006, 12:02 PM   #4
Davenow
Member#: 23676
What part about the problem with aftermarket BOVs sucking has very little to do with venting to atmosphere dont you guys understand??
You could somehow probably make it recirc, but that isnt going to fix the fact that it leaks like a bastard, which causes your turbo to overwork to make the same boost, producing a hotter, less dense, more detonation prone air charge.
Old 04-23-2006, 12:11 PM   #5
blue blurr
Member#: 51111
I dont care about that, my car runs perfectly fine. I am just tired of the noise everytime I shift and want it quiet again. I have a fmic with a universal hks welded on so I can not go back to stock.
Old 04-23-2006, 12:29 PM   #6
o2sys
Member#: 43842
200? WRX STI
i think all noise maker mods are fun and everyone has to atleast try it before they get rid of it...is just a fact of life.
o2sys is offline   Reply With Quote
Old 04-23-2006, 12:50 PM   #7
blue blurr
Member#: 51111
Well yeah, but I didnt even want one. I got a great deal on a fmic with the hks bov on it so I wasnt going to say no. I'm glad I found a way to make it quiet though, haha
Old 04-23-2006, 01:00 PM   #8
turboscooby13
Member#: 56280
2003 M3
For the price of that, I would think you could find a used stock BOV on eBay or something.
**EDIT I'm stupid . . . you said FMIC. . . duhh!!
turboscooby13 is offline   Reply With Quote
Old 04-23-2006, 01:14 PM   #9
BoostedAWD
Member#: 19519
2002 Subaru WRX
World Rally Blue
could you elaborate a little more?
BoostedAWD is offline   Reply With Quote
Old 04-23-2006, 03:06 PM   #10
KmanRuffian
Member#: 48360
2011 WRX 5-door
He did some tests measuring intake temps post-turbo and found that they were higher with all of the aftermarket BOVs he tested. This indicated that the BOVs were leaking boost because the turbo was having to spin faster to generate the same boost as without the leak. This increase in intake charge temp increases the chances of detonation occuring as he mentioned. Also your turbo will die sooner than if no leak was present...
-D
KmanRuffian is offline   Reply With Quote
WTB: HKS SSQV Recirculation Kit MidnightBlack02WRX Tri-State Area Private Classifieds 1 01-17-2006 10:04 AM
Wtb hks ssqv recirculating adapter djchang84 Private 'Wanted' Classifieds 2 12-20-2005 04:08 PM
HKS SSQV recirculation fitting wrx2 Private 'Wanted' Classifieds 1 02-08-2005 04:21 AM
HKS ssqv recirculation kit bhkim126 Private 'Wanted' Classifieds 1 12-01-2003 01:40 PM
WTB: HKS SSQV recirculating fitting Tragic Private 'Wanted' Classifieds 2 10-14-2003 03:48 AM
