Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 04-23-2006, 02:34 AM   #1
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
Default drop in pistons
I have a new 06 STI with 500 miles and I want to replace my pistons. I a want to know who sells drop in pistons, so I wont have to have everything balanced.
Boxer112 is offline   Reply With Quote
Old 04-23-2006, 02:42 AM   #2
nxttruck2002
Member#: 90879
nxttruck2002 is offline   Reply With Quote
Old 04-23-2006, 03:32 AM   #3
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
Not balanced but bored to meet clearence issues.
Old 04-23-2006, 03:37 AM   #4
nxttruck2002
Member#: 90879
Why don't you properly break the motor in frist...?
Old 04-23-2006, 04:20 AM   #5
djviper
Member#: 107276
99 V.R.Special
WRC blue
if your spending the money on putting up rated pistons in what is essentialy a new block id say spend the extra few dollars and get a matched set of pistons, incedently why?
and nxttruck, no real point breaking the motor in as when he changes the pistons he will have to run it in again as new to seat the new rings
djviper is offline   Reply With Quote
Old 04-23-2006, 06:02 AM   #6
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
i was thinking since the block is still so new, i can drop the pistons in and not have to worry about sealing issues..am I in the right frame of mind? if not guide me, no use in spending $2300 for new block when i can spend $600 for pistons
Old 04-23-2006, 12:33 PM   #7
STEALTH-WRX
Member#: 7822
Multi layer snot green
All of the blocks have inconsistancies in the bores. The cylinders have "A" and "B" sleeves which are something like 2/10 - 3/10 of a thousandth different. I would suggest honing the block the block and getting a final bore. Then get that bore and order some pistons. I know most people dont like JE but they have a really bad ass new design for the EJ257 that they have availble that no one knows about. I have seen them with my own eyes.
STEALTH-WRX is offline   Reply With Quote
Old 04-23-2006, 01:35 PM   #8
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Wiseco's? Just about any set of pistons will drop in be fine and give you no trouble. Any set of forged pistons will probably outlive the block, or at least the rods.
Sko is offline   Reply With Quote
Old 04-23-2006, 01:47 PM   #9
flycaster
Member#: 60142
2011 WRX
Grey
Actually, the "allowed" tolerance between the A and B sleeves is a full thou. On a recent new block we just built, it was more.
Boxer, at the very least measure to double-check and touch re-hone for better new ring seating. You can do this without splitting the case if you have someone who knows what they're doing.
flycaster is offline   Reply With Quote
WTB: EJ257 with drop in pistons tjphillips36 Private 'Wanted' Classifieds 2 03-02-2009 02:13 PM
drop in pistons (cp)? explor4u Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 09-09-2008 02:34 PM
CP drop in piston installment Q`s?? DJIMPREZA Built Motor Discussion 4 04-11-2008 03:12 AM
CP drop in pistons with 07 sti heads???? DJIMPREZA Built Motor Discussion 10 04-09-2008 02:52 AM
What`s the CR from sti 07 USDM heads and CP drop in pistons? DJIMPREZA Built Motor Discussion 5 10-10-2007 11:58 AM
