Old 04-23-2006, 11:45 AM   #1
TecnoWRX
Member#: 81474
2008 VW
R32
Default Dyno #'s for '02 WRX
I went to Agile Auto yesterday for there Dyno Day that turned out to be 3 people in 3 hrs. They have a dynapack, which i hear runs 10-15% less than other dynos. I made 199 hp and 206 tq. if you take in the 10% correction that is 219hp. If i am wrong with the correction please let me know, i dont want to be telling misinformation.
Mods that Matter: Lightened Pullies, TXS UP/DP/Mid Section/FMIC, Blitz Nur Spec Rear, HKS/ZeroSports Intake. This is on a stock turbo without engine management spiking to 16 psi then leveling to 14.
TecnoWRX is offline   Reply With Quote
Old 04-23-2006, 12:35 PM   #2
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
u really need some injectors, engine management, and a bigger turbo to take advantage of ur mods. or at least some EM and get it tuned.
what do stock WRX's dyno?
stickman is offline   Reply With Quote
Old 04-23-2006, 05:21 PM   #3
wrxskier18
Member#: 88005
2002 WRX + NSX
Silver + Green
yeah, you DEFINATELY need some EM
wrxskier18 is offline   Reply With Quote
Old 04-24-2006, 09:07 AM   #4
TecnoWRX
Member#: 81474
2008 VW
R32
That is the plan whenever i can get some $$$. i know that i am doing the modding a little out of order.
would injectors fix the AF problem without EM or would EM alone fix the AF problem?
Old 04-24-2006, 09:43 AM   #5
CalcVictim
Member#: 57056
2006 Miata
Copper Red
with stock turbo EM should fix your AF ratio
CalcVictim is offline   Reply With Quote
Old 04-24-2006, 10:58 AM   #6
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
You don't need an in injector upgrade for the stock turbo.
I am running a tuned map of the cobb stage2 and my IDC probably peaks about 90-92%. I am running about 11.2:1 A/F and my boost spikes to around 17.5psi.
What some people don't realize is that, the IDC reaches it's peak at redline typically where it's richest, NOT where your peak boost is on the stock turbo. I could easily turn the stock turbo up to 20psi and still have headroom. My IDC at my peak boost level is (off the top of my head) around 87%.
akira02rex is offline   Reply With Quote
Old 04-24-2006, 12:34 PM   #7
REX8
Member#: 24038
Thats why he said "injectors....and a bigger turbo..."
Finish reading his sentence....
Old 04-24-2006, 12:40 PM   #8
REX8
Member#: 24038
Double post...
Old 04-24-2006, 03:04 PM   #9
TecnoWRX
Member#: 81474
2008 VW
R32
Is the FMIC throwing my AF out of wack? Or is it the boost controller? The controller that i have is the ABC from a UTEC. Would a Fuel pump fix the AF. If i was to go back to a TMIC but stay with the ABC, does anyone think that would help with the AF.
Old 04-24-2006, 03:10 PM   #10
rewt
Member#: 60794
2007 Solstice GXP
Running a "boost controller" with no means to adjust your fueling is throwing your AF out of whack. Are you getting any knock?
rewt is offline   Reply With Quote
Old 04-24-2006, 03:27 PM   #11
TecnoWRX
Member#: 81474
2008 VW
R32
I dont hear or feel any knocking sounds. this is a total newb question, but what is knock and what should it sound like. i tried a minor search and didnt really come up with anything definate.
Old 04-24-2006, 04:02 PM   #12
InfamousDX
Member#: 25413
Just adding a boost controller is fine on an 02-03... your AFR's are probably ok. Problem is you threw another factor into the equation... the front mount is DEFINITELY skewing your AFR's.
And just because you don't hear or feel any ahrd knock, doesn't mean it's not happening.
Old 04-24-2006, 04:08 PM   #13
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
you spent tons of money on those parts to gain ~30 whp and most of that probably comes from the $20 boost controller. Please do yourself a favor. Spend under $1k for EM and a tune and you'll probably double that hp gain.
rex n effect is offline   Reply With Quote
Old 04-24-2006, 04:19 PM   #14
REX8
Member#: 24038
No, his stock ECU throws more fuel at it...
Old 04-24-2006, 04:25 PM   #15
wrxskier18
Member#: 88005
2002 WRX + NSX
Silver + Green
I totally agree. This is stupid. Why waist money and risk destroying your engine. If you don't know what knock is, you should probably do some research...a lot of it. Why put on mods on an expensive car when you don't know anything about what it does!?! Did you talk to Hill at AA? He's a very knowledgeable guy.
Sell the FMIC and boost controller and buy an AP and you would probably end up with some extra cash not to mention your car will have more power and SAFER power. And definatley get a protune from Hill if you can.
Old 04-24-2006, 04:38 PM   #16
TecnoWRX
Member#: 81474
2008 VW
R32
No i did not talk to Hill about the AF. No on e there seemed to awfully concerned about it. The only thing they said was that the car is idling a little rough, and to change my spark plugs.
I have thought about doing this after going to the dyno.
Old 04-24-2006, 04:41 PM   #17
CynicX
Member#: 48199
06 WRX
You would get very similar numbers on a tuned stock WRX and not have to worry about blowing it up. Even the OTS Cobb Stg1 map will get you around that area, a 590ish dollar part that Agile can use now and in the future for making your car operate properly.
As everyone else has mentioned get some EM and your going to need it professionally tuned for your mods. Even still it might be tough to take advantage of alot of your mods with a stock turbo and stock fueling.
Knocking is pre-detonation. Combustion accures when its not supposed too due to air/fueling being out of whack. I've never heard it on a WRX but most be say it sounds like a BB in a tin can being shaken around. A couple serious knocking events will take its toll on your engine, if it doesnt take it out completely.
CynicX is offline   Reply With Quote
Old 04-24-2006, 06:05 PM   #18
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
i would just put ur stock TMIC and stock intake back on until u get some type of EM.
dont waste ur money on an intake since stocker works very well, especially for the minor mods u have. i think the FMIC and intake are making ur a/f whack.
just keep ur FMIC on the side until u get the bigger turbo, injectors and fuel pump.
then put it all back on, get ur EM tuned and u wll be good to go. then save up for a tranny.
Old 04-24-2006, 06:26 PM   #19
abosworth
Member#: 53856
2012 Speed3
Red Mica
I think around 169 whp.
abosworth is offline   Reply With Quote
WTT: stock for CF hood for '02 wrx dtseng01 Private 'Wanted' Classifieds 11 03-13-2006 11:09 PM
Part #'s for 05 WRX "pink" STi springs please CapeRex Brakes, Steering & Suspension 2 07-23-2005 05:29 PM
Some 2.5 Dyno #'s for everyone cjm04WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 12-30-2003 10:28 PM
a-pillar boost gauge for '02 wrx for sale recce02 Southern California Impreza Club Forum -- SCIC 5 01-04-2002 12:29 PM
