Old 04-23-2006, 11:29 AM   #1
TurbojonLS
Member Sales Rating: (52)
Member#: 38772
2 Cars, No Bling
Default Mach V Stainless Steel Brake Lines
One of my stock brake lines was rubbing against my coilovers and resulted in the line wearing down. Not through, but there was an easily visible indentation in the line that definitely caused me some concern.
I replaced them with the Stainless Steel Brake Lines from Mach V Motorsports (http://www.fastwrx.com/teststbrlibl.html).
As you can see, they're covered in red sheathing, and include all the hardware you need. Install was just as simple as installing any other brake line, with the same amounts of mess. Some notes:
--The supplied brake caliper banjo bolts aren't exactly 14mm like the stock ones, they're a little larger. You can use a 14mm box wrench, but it won't go on smoothly.
--The rear brake line clips (that hold the brake lines to the shocks) are a pain. The groove in the Mach V Lines is narrower than the already narrow groove in the stock lines. It took a little flattening of the clips and a lot of cussing and twisting, but they do go back on. (Having done these clips probably 10 times on various suspensions I've installed, I think I'm experienced enough to say that this was more difficult than the stock lines. The person helping me has probably worked on twice as many suspensions as I have, and was having similar difficulties).
I had ATE Super Blue in the system previously, so I just used more Super Blue. We bled in the order of Passenger Front, Driver Rear, Driver Front, Passenger Rear, first with the car off, then with the car on. This second bleed step really seemed to help with the feel of the pedal. It gained even more firmness.
Impressions:
These lines made a noticible difference in brake feel. There is almost no slop anymore, and the brakes are very firm. I definitely recommend them to anyone.
Other Search Terms:
Fastwrx
SS Lines
Break/Breaks ()
TurbojonLS is offline   Reply With Quote
Old 04-23-2006, 12:24 PM   #2
Capt Crunch
Member Sales Rating: (15)
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
I have these as well and they do the job for much less than other braided lines. I like how they are coated. I recommend them.
Capt Crunch is offline   Reply With Quote
mach v stainless steel brake lines nkx Car Part Reviews 16 08-29-2012 01:56 PM
Stainless steel brake lines to match car model or brake upgrade? giantturtle Brakes, Steering & Suspension 7 02-06-2008 10:24 PM
Mach V stainless steel brake lines...anyone using them? GonzoWRX Mid Atlantic Impreza Club -- MAIC 12 10-17-2006 02:59 PM
stainless steel brake lines braking???? 98skuby Brakes, Steering & Suspension 25 06-04-2006 10:16 PM
FS: 2002 WRX Front Brakes, GC8 Stainless Steel brake lines paultg Private 'For Sale' Classifieds 5 11-08-2005 10:10 PM
