Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-23-2006, 02:56 PM   #1
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Default Evaluate this log please?
Hey guys
A friend of mine just got his UTEC tuned by a local tuner and from what I see, it looks pretty good. He just wants to squeeze a bit more out of his car. I logged this 1-2-3 gear pull :
Code:
3650, +0.4,3.0, 84, 10,   00,  12.1,+27.4,  25.4,+24.8, +1.1,385.00,3.0
 3912, +1.3,3.2, 89, 20,   00,  rich,+28.0,  30.8,+22.7, +0.0,385.00,3.0
 4262, +2.5,3.5, 95, 20,   00,  rich,+25.8,  41.1,+21.2, +0.9,385.00,3.2
 4591, +3.9,3.7, 95, 30,   00,  rich,+21.5,  58.3,+19.4, +1.0,350.00,3.5
 4852, +5.3,4.0, 96, 40,   00,  rich,+19.1,  70.7,+18.2, -0.6,350.00,3.7
 5350, +7.4,4.2, 95, 50,   00,  rich,+24.2,  82.0,+15.7, -1.8,300.00,3.9
 5767, +9.8,4.3, 95, 70,   00,  rich,+24.6,  82.6,+15.1, -3.0,300.00,3.8
 6207,+11.7,4.4, 95, 80,   00,  rich,+26.1,  87.7,+15.4, -3.7,300.00,4.0
 6706,+13.7,4.5, 95, 80,   00,  rich,+30.9,  88.5,+14.9, -3.6,300.00,4.0
 6626,+12.3,4.1,  0, 60,   00,  rich,+10.7,  26.0,ECU. , -2.2,ECU.  ,2.3
 6301, +6.2,1.6,  0, 10,   00,  rich,+11.1,   5.9,ECU. , -2.8,ECU.  ,1.4
 5777, +1.5,3.4, 73, 10,   00,  lean,+38.9,  51.1,+30.9, -2.8,300.00,3.4
 4468, -1.4,3.9, 89, 10,   00,  rich,+16.7,  60.8,+23.5, +1.1,385.00,3.5
 4535, -0.6,3.6, 96, 40,   00,  rich,+20.6,  54.3,+18.4, +1.2,385.00,3.5
 4553, +4.7,3.7, 96, 50,   00,  rich,+15.8,  53.7,+15.5, -0.6,385.00,3.5
 4522, +9.2,3.8, 95, 70,   00,  rich,+15.4,  55.8,+13.6, -2.9,385.00,3.5
 4675,+11.5,4.0, 92, 80,   00,  rich,+16.3,  60.8,+14.5, -2.9,350.00,3.6
 4880,+13.9,4.0, 96, 90,   00,  rich,+18.7,  66.9,+14.1, -3.5,350.00,3.5
 5035,+15.7,4.1, 95, 90,   00,  rich,+22.3,  69.0,+13.6, -3.9,300.00,3.6
 5241,+16.1,4.1, 95, 90,   00,  rich,+23.1,  72.7,+14.0, -4.0,300.00,3.7
 5359,+16.8,4.2, 96, 90,   00,  rich,+23.3,  74.5,+14.0, -4.0,300.00,3.7
 5555,+16.4,4.3, 96, 90,   00,  rich,+23.6,  73.0,+14.0, -3.9,300.00,3.7
 5817,+15.9,4.3, 96, 90,   00,  rich,+23.6,  80.1,+14.1, -3.8,300.00,3.8
 5899,+16.1,4.4, 91, 90,   00,  rich,+25.0,  84.6,+14.3, -3.6,300.00,3.9
 6093,+15.7,4.4, 62, 80,   00,  rich,+24.7,  83.8,+14.7, -3.6,300.00,3.9
 5767,+12.5,3.8,  0, 50,   00,  rich, +8.9,  32.0,ECU. , -1.7,ECU.  ,1.9
 5518, +5.7,1.6,  0, 10,   00,  rich,+11.2,   4.8,ECU. , -2.9,ECU.  ,1.2
 5159, +0.4,3.0, 38, 10,   00,  lean,+22.8,  31.0,+22.0, -3.2,280.00,3.0
 4301, -2.2,3.7, 78, 10,   00,  rich,+21.0,  51.4,+23.9, +1.1,385.00,3.4
 4363, -1.2,3.8, 96, 30,   00,  rich,+16.2,  53.2,+19.5, +0.9,385.00,3.5
 4385, +3.7,3.9, 96, 50,   00,  rich,+14.1,  58.6,+16.6, -0.3,385.00,3.6
 4535, +8.4,4.0, 95, 60,   00,  rich,+15.3,  60.7,+13.7, -2.9,350.00,3.6
 4662,+11.3,4.0, 96, 80,   00,  rich,+16.4,  62.0,+14.5, -2.9,350.00,3.5
 4714,+13.5,4.0, 96, 90,   00,  rich,+17.4,  61.4,+14.5, -2.8,350.00,3.6
 4823,+15.5,4.1, 96, 90,   00,  rich,+17.8,  63.2,+14.2, -3.0,350.00,3.6
 4880,+16.4,4.1, 96, 90,   00,  rich,+19.0,  61.4,+14.0, -3.6,350.00,3.6
 4990,+15.9,4.1, 95, 80,   00,  rich,+19.5,  68.2,+14.0, -4.0,300.00,3.7
 5073,+15.7,4.1, 96, 80,   00,  rich,+22.6,  65.1,+14.2, -4.0,300.00,3.6
 5128,+15.3,4.1, 96, 80,   00,  rich,+23.3,  69.8,+13.8, -4.0,300.00,3.7
 5282,+15.1,4.2, 96, 80,   00,  rich,+22.7,  71.8,+14.1, -4.1,300.00,3.7
 5359,+15.3,4.2, 96, 80,   00,  rich,+23.0,  72.8,+14.4, -4.1,300.00,3.7
 5376,+15.9,4.2, 95, 90,   00,  rich,+23.2,  72.6,+14.0, -4.0,300.00,3.8
 5464,+16.4,4.2, 96, 90,   00,  rich,+22.6,  75.4,+14.0, -3.9,300.00,3.7
 5640,+16.6,4.3, 96, 90,   00,  rich,+22.8,  78.0,+14.0, -3.9,300.00,3.8
 5827,+17.0,4.3, 96, 90,   00,  rich,+23.3,  79.9,+14.0, -3.7,300.00,3.8
 5817,+16.1,4.3, 95, 80,   00,  rich,+24.8,  83.1,+14.5, -3.9,300.00,3.9
 5837,+15.9,4.3, 70, 80,   00,  rich,+24.6,  82.7,+14.2, -3.8,300.00,3.9
 5640,+13.5,3.6,  0, 70,   00,  rich,+40.7,  68.6,ECU. , -3.2,ECU.  ,3.0
 5482, +7.4,2.0,  0, 10,   00,  rich,+10.9,   4.8,ECU. , -3.0,ECU.  ,1.3
 5096, +0.6,1.2,  0, 10,   00,  23.7,+11.3,   3.9,ECU. , -3.2,ECU.  ,1.2
 4748, -6.1,1.7,  0, 10,   00,  lean,+11.3,   5.7,ECU. , +1.0,ECU.  ,1.7
 4415,-10.8,1.9,  0, 00,   00,  24.0,+11.4,  30.3,ECU. , +0.0,ECU.  ,1.8
I thought timing was pretty linear up top and could use some gradual advancing after peak torque.
Also, no wideband to log AFR's - sorry.
He has APS 40 turbo, APS FMIC, all APS exhaust plumbing, TGV deletes, UTEC with ABC hooked up, 550 inj. (scaled to 550), APS fuel rails.
Thanks for any constructive criticism.
kingtut12 is offline   Reply With Quote
Old 04-23-2006, 08:30 PM   #2
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Anyone?
Old 04-24-2006, 09:43 AM   #3
TurbojonLS
Member#: 38772
2 Cars, No Bling
I'm still running the stock turbo, so take this with a grain of salt.
1 - Why is he only boosting 17psi? I would expect to be running closer to 20.
2 - Timing looks whack. Its lower than ECU timing at almost every point in the log, even at really low boost.
Also, its really hard to get more constructive w/out A/F numbers.
TurbojonLS is offline   Reply With Quote
Old 04-24-2006, 10:51 AM   #4
Xman23
Member#: 50224
2004 WRX
I agree
Xman23 is offline   Reply With Quote
Old 04-24-2006, 11:00 AM   #5
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
I think:
- Timing too low, try to increase it in small step
- Boost can be push more and increase it in small step
- Set ur TPS to reach at least 100%
- Next time pull from low rev like 2000-7000 rpm in 3rd or 4th gear and data log it.
Just my 2cnt
WRX-Blue-Mica is offline   Reply With Quote
Old 04-24-2006, 04:51 PM   #6
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Thanks guys, I thought timing was rather low as well. As far as boost goes, it certainly needs tweaking. Thanks.
Old 04-24-2006, 07:08 PM   #7
Freon
Member#: 88322
2009 BMW 135i
#1: Either your TPS isn't calibrated right or your friend wasn't pushing the pedal all the way down. You should hit 100-102. This is easy to fix. Lower the map TPS voltage by a tenth and you should be good to go, or tell your friend to push harder on the gas. Now you can hit the last load column on your boost map.
#2 Timing is really bad. +15 might be ok at 4000-4500 and 16psi, but it should slowly creep up as you approach redline. Even at full boost I'll hit 20-23 degrees, as would most cars, at 6000-7000rpm. It looks like the guy just filled the whole map, 80+load, 4500+rpm with "14" over and over. That's not a good tune. You're giving up power and running higher EGT for it. Really, that timing map is whack. It should look more like this:
Code:
 RPM	  MAP	 MAF	TPS	Site	Count	afr	 Ign#1	 Inj#1	 Ign	  Fuel	Boost	 MAF
2544	-10.6	2.3	32	0	0	23.6	9.1	36.5	ECU. 	0	ECU.  	2.8
2495	-8.1	2.7	34	0	0	15.7	9.7	17.4	ECU. 	0	ECU.  	2.7
2590	-5.3	2.8	35	10	0	13.6	28.7	17.6	24.6	3.5	ECU.  	2.9
2662	-2.2	2.9	49	10	0	13.9	23.4	23	24.4	3.5	114	3.1
2773	0.6	3	51	20	0	12.6	19.8	24.7	21.5	2.1	154	3.2
2851	1.9	3.2	56	20	0	12.4	18	29.8	21.5	2	162	3.2
2878	3.5	3.3	58	30	0	11.8	14.8	35.8	18	2.7	182	3.3
3072	4.7	3.4	57	40	0	11.5	13.7	38.1	17	2.4	178	3.4
3189	6.5	3.3	57	40	0	11.8	15.3	36.8	17	1.9	178	3.4
3360	7.6	3.4	66	50	0	11.8	17.3	39.3	16.6	2.4	182	3.6
3436	8.4	3.5	95	50	0	12.2	17	43.6	16.7	2.2	325	3.6
3572	9.6	3.8	101	60	0	12.2	12	54.7	16.5	3.3	340	4
3728	11	3.9	101	70	0	11.2	12.9	61.4	16	3.1	340	4
3940	12.9	3.9	102	80	0	11.1	17.1	59.3	16	3.1	340	3.9
4011	14.7	3.9	102	80	0	11.5	20.8	64.5	16.8	2.9	350	4.1
4235	15.7	4	101	80	0	11	21.3	72.6	17.5	2.6	350	4.1
4468	15.7	4.1	102	80	0	11.1	20.6	76	17.5	2.8	350	4.2
4728	15.5	4.2	102	80	0	10.9	21.8	81.4	17.8	2.2	350	4.2
4844	15.5	4.2	102	80	0	10.9	22.7	86.7	18.6	1.2	350	4.3
5042	15.5	4.3	102	80	0	10.9	24.4	84.1	19.6	-0.3	350	4.2
5316	15.3	4.2	101	80	0	11	24.8	88	20.1	0.3	350	4.2
5482	15.3	4.3	102	70	0	11.3	24	85.3	21.9	0.3	350	4.3
5717	14.5	4.4	101	70	0	11.3	23.5	91.2	22	0.3	340	4.4
5889	15.1	4.4	100	80	0	11.4	23.6	96	22	0.5	340	4.4
6049	15.1	4.4	102	80	0	11.1	24.2	95.7	22	0.5	330	4.4
6184	15.1	4.4	100	80	0	11.2	25.4	95	23.6	0.4	330	4.4
6435	15.3	4.4	100	70	0	11.1	26.7	94.7	24.8	0.2	330	4.4
6447	14.3	4.4	54	70	0	11.1	30.8	93.8	26.9	-0.3	166	4.4
6816	9.8	1.7	1	0	0	14.1	22.8	7.1	29	0.5	ECU.  	1.5
6373	3.5	1.4	91	10	0	12.8	40.6	40.4	25.8	-0.4	290	3.4
5350	0.8	4	106	10	0	18.1	25.9	76.8	24	0	350	4.2
5073	0.2	4.3	105	40	0	10.1	21.9	93.4	22.4	0.4	350	4.3
5282	5.3	4.4	105	70	0	10.8	21.2	90.4	21.6	0	350	4.4
5446	11.6	4.3	105	80	0	11.3	21.7	90.4	20.6	0.4	350	4.3
5500	14.9	4.4	105	80	0	11.3	21.4	89.8	21	0.4	340	4.3
5698	15.3	4.4	105	70	0	11.3	21.3	88.7	22	0.3	340	4.4
5837	14.9	4.4	104	70	0	11.3	21.3	91.5	22.4	0.4	340	4.4
5787	14.7	4.4	103	80	0	11.2	21.4	95.3	22	0.5	340	4.4
6006	14.3	4.4	102	70	0	11.1	22.1	93.9	23.1	0.4	330	4.4
5952	15.1	4.4	71	80	0	11.2	22.2	96.4	22.6	0.5	310	4.4
6049	13.5	3.9	15	0	0	10.2	32.2	14.3	27.8	0.4	154	2.5
5777	7.2	1.6	2	0	0	13.7	23	5.4	26	0.2	ECU.  	1.3
5446	0.6	1.1	2	0	0	13.6	23.1	4.1	26	0	ECU.  	1.2
4945	-6.5	1.5	2	0	0	31.8	23.2	5.6	26	0	ECU.  	1.7
4604	-11.8	1.8	2	0	0	30.3	23.3	23	ECU. 	0	ECU.  	1.8
(this tune runs richer than needed in the 10-40 load columns, but is otherwise, IMHO, really good)
#3. Your midrange boost is low, and you have lots of injector left. There is a ton of midrange power and torque left on the table. Basically, any turbo that can do 15psi @ 6500rpm is going to be able to push 17-18psi at 4500rpm without any trouble.
More logs would help. I'd really like to see a dump of the timing map as well. You really should get a wideband as well and log that.
A full pull from 2500rpm in 3rd or 4th gear would also help.
Freon is offline   Reply With Quote
Old 04-24-2006, 09:02 PM   #8
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Freon
Thanks for the informative post. Very thorough and to the point -
Victor, if your reading this you should log on and introduce yourself - these guys can really help you out. I will copy your timing map next time we meet up and post it.
If I remember - at 80, 90, 100 load at around 5000 and up it was 14 deg give or take a half everywhere. Car ran super smooth and no knock detected whatsoever.
Thanks guys
Old 04-25-2006, 12:50 AM   #9
AaronWRX
Member#: 7194
2011 997.2 Turbo
yeah... 14 degrees of timing. meh. did he take it to a shop that does mostly DSM tuning?
top of 3rd and only 4.3v's of maf? <orangecounty> Weak Sauce! </orangecounty>
AaronWRX is offline   Reply With Quote
Old 04-25-2006, 06:38 PM   #10
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Actually, to the shop's defense, they had never tuned a UTEC and did a decent(safe) job. But yeah, DSM's and Honda's. Were gonna adjust timing a bit and see if that is enough, but I'm afraid fuel adjustments will need to follow, but without a wideband, I am a bit nervous to make big changes.
Please critique this log... starace Open Source Reflashes 6 02-09-2008 06:01 PM
Please evaluate my log, first timer!!! BBBsti LTD Engine Management & Tuning 4 03-19-2007 10:49 AM
It's soooooooo slooooowowwwwwww Please Help.. Hijack This Log Enclosed... Damien Off-Topic 17 07-01-2006 10:44 PM
Utec related misfires? Evaluate my logs BigBoosting UTEC 19 05-25-2006 03:02 PM
Please have a look at this log mistaboosta Engine Management & Tuning 12 12-03-2004 09:35 PM
