Old 03-20-2000, 07:26 AM   #1
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Thumbs up KYB AGX
Hey gang...
just wanted to let u all know i FINALLY have them & they are installed!!! i am running them with the H&R springs against the general consensus of the main board
oh well, that's me! So far they are freakin fantastic, but it's only been 3 days!
If you are gonna order them for your Legacy, don't even bother telling the distributors (SPD being the exception) that you are putting them on a Legacy - they will insist KYB doesn't make them for our car. Just use the Impreza part numbers and tell the distributors they're for an Impreza.... I've even spoken to techs at KYB about this... they were very surprised when they realized the Legacy/Impreza part numbers were EXACTLY the same!!!
I did a search/quote request with about every major distributor out there. SPD's price is darn near unbeatable. You may want to try Summit Racing as well, but I know Mike Shields is very reliable so you can't go wrong with SPD!!!
sorry so long... just wanted to share the info!
j.
Old 03-20-2000, 07:14 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
Can you give us some more details on how the car rides? I know you've only had them a couple days, but any info would be helpful. The AGX is adjustable, right? If so, can you adjust them to pretty much ride like stock, and then firm them up for fun when necessary?
Also, how is ride height affected? I guess in your case it's probably dictated more by the springs. I'm thinking of going for the KYB's and keeping my stock springs.
Thanks for the update.
Pat Olsen
'99 Legacy 2.5GT 5 speed sedan
Old 03-20-2000, 09:50 PM   #3
GTMAN
Member#: 480
1998 Legacy GT Wagon
Smile
Do go on about the handling. Got my struts today and am trying to find a good place to install them - the dealership charges $78golden dollars/hr.
How long should the job take?
Did you re allign you wheels? If so, what are your camber/toe in specs? (guess it should not change cus the springs were already on the car)
What are the do and don'ts during the install do I need to look for?
Thanks for the info.
GTMAN
98GT
GTMAN is offline   Reply With Quote
Old 03-21-2000, 06:35 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
hey guys... ok...
So the car rides really nice... i have the KYB's set at 2front/4rear which is a "medium" setting... just about similar to stock, but a tad stiffer. pretty nice for everyday driving... i think though i will turn the rears up a notch just to see what type of difference this creates.
I can not wait to rally cross this car! this thing corners soooo much better - don't get me wrong, it did well with just the H&R's but now it feels like it's on rails... the struts really made an incredible difference.
Ride height is about the same as it was. The H&R's seemed to lower the car just about an 1" in front, 1.25" (guessing) in rear. The struts seemed to have no effect on the height of the car.
I will be getting an alignment this week just to be certain we have everything set the way it should be.
Things to watch out for during install??? man... there are so many! I will post later about details on that!!
The job took a really long time - expect at least 4-5 hours i'd say, although I have heard of it being done in 2-3.... (good luck!)
j.
Old 03-21-2000, 09:42 AM   #5
rsquire
Member#: 265
1998 22B Blue
1986 Ford RS200 White
Post
Reason it took more than 4 hours, was because we kept stopping for a beer and a chat... :-)
Richard
rsquire is offline   Reply With Quote
Old 03-21-2000, 10:02 AM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
Tips for installing:
When removing the front struts, be sure to slacken off the bolt at the top of the strut before before removing the strut from the car.... we learned this one the hard way and it took up much time!!! we ended up re-installing the strut inorder to slacken the bolt!
Instead of bleeding the brake lines, you can cut the braket holding the brake line. This allows the brake line to be slid out from it.
On the front struts, take note of the exact position of the markings on the top of the two lower bolts. Otherwise camber will be out. You have to try and get them set back at the correct markings/notch - I am getting an alignment just to be sure we got it right.
according to those who assisted me, this about covers it... any other questions, let me know.
j.
Old 03-21-2000, 03:53 PM   #7
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Exclamation
Wait...you mean all this time I was waiting for the AGX's to come out for the 97+ Legacy and the Impreza's will work?? I can't believe this!!!
So the AGX's for the latest Impreza are what you got? Got any part numbers?
If this is true, H&R/AGX combo here I come!
Kevin www.lagging.com
PS Thanks for the tip Jamie!
Force[FED] is offline   Reply With Quote
Old 03-22-2000, 06:31 AM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Thumbs up
Hey Kevin!
part numbers are
FR 734006
FL 734007
RR 733010
RL 733011
they ride so nice! you'll love them!
good luck!
j.
Old 03-23-2000, 01:28 PM   #9
PaulN
Member#: 566
1994 Legacy GTB
Green
Post
Jamie
Hi, I have been trying to get H&R springs to fit my GTB but have been told they don't exist over here for any 95-99 legacies - do you know the part numbers for a 95 wagon for all 4 springs
Thanks Paul
PaulN is offline   Reply With Quote
Old 03-23-2000, 06:42 PM   #10
GTMAN
Member#: 480
Question
Jamie,
How did you attach the speed sensor to the front strut - I don't see a bracket for it?
I'm probably taking it to a shop to do it so I dont want them to fool around too much making some bracket that I dont need - if I really dont need it - and charge me for that time.
GTMAN
98GT WGN
Old 03-25-2000, 12:10 AM   #11
BG5
Member#: 695
Talking
gtman:
Try a junk yard for a earlier model 2nd gen legacy, the ABS lead bracket is a bolt on (instead of welded like my 99) on at least the '95 front-ender I got my brackets from...
they fit perfectly on the AGX's
if you go to the dealer, unfortunately
you have to buy the whole sensor lead to
get the bracket...
BG5 is offline   Reply With Quote
Old 03-26-2000, 07:13 PM   #12
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
Originally posted by GTMAN:
Jamie,
you are gonna crack up... pretty creative here...
we used some zip-ties and tape... yeah.. w/the KYB/AGX there's no bracket... this will work though... believe me, that thing isn't going anywhere...
the local shops wanted $400 for installation!!!
Old 03-27-2000, 10:45 AM   #13
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Post
I sure hope you are right about this info SubieGal (don't see how NOT, since you are running with them). I checked the part #'s you gave me and they are indeed the numbers for the AGX's for the Impreza. How come no one realized this earlier? And if this is the case, how come Mike Shields says that the suspension items for the Impreza will not work on the Legacy?
I am planning on ordering the shocks from an East Coast vendor...if they don't fit/work I am screwed. Did you get the part numbers right off the boxes?
Kev
Old 03-27-2000, 11:05 AM   #14
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
i did get the part #'s off the boxes... and... i called KYB and talked to both a US and JAPANESE rep at the same time... we sort of made this "discovery" ourselves... the techs were very surprised...
i checked the part #'s that MShields sells... the fronts are actually for a Nissan according to KYB... the rears are the same part #'s as the Impreza...
i don't know what else to tell you other than they are on my car and they ride GREAT!!
those are definately the part #'s i ordered and installed....
j.
Old 03-27-2000, 08:36 PM   #15
BG5
Member#: 695
Post
Kev
generally the only differences between the impreza and legacy are the springs/strut damper rates, not the physical format -- AGX works cuz it's adjustable... you could stick a Prodrive Impreza setup in there but the rates would be all wrong.
ps, having purchased my AGX's from SPD, I can confirm the part #'s are the same as the impreza.
Old 03-28-2000, 04:50 AM   #16
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Post
Glad to hear all this. I won't be ordering my parts from SPD, since there is an East coast distributor that I have dealt with in the past, and they give me good deals. Besides, I can also save on shipping since the shocks would be coming from my state (NJ).
Thanks gang!
Kev
Old 03-29-2000, 12:17 AM   #17
GG
Member#: 1062
Post
I think NJ sales tax beats UPS shipping charges any day.
GG is offline   Reply With Quote
Old 03-29-2000, 07:22 AM   #18
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Post
Looks like I am getting the shocks for $440 SHIPPED to me, and no tax. The shop is located in PA, but the shocks are in a warehouse in Jersey.
I think that pretty much beats most places on price. Looks like I am going to install the H&R's and AGX's this weekend.
Got any info/tips that I should know in advance Jamie? Any specific/special tools I would need?
I sure hope my Team Loco wheels with 215/45/17 tires don't rub
Kevin
Old 03-30-2000, 12:39 AM   #19
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Cool
WHERE DID YOU (FORCE[FED]) BUY THE SHOCKS FOR $440?
CRAZY KEN is offline   Reply With Quote
Old 03-30-2000, 04:26 AM   #20
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Post
E-mail me and I will give you the details. I haven't ordered the AGX's yet because I want to make sure that my wheels/tires don't rub first (that would suck royally).
E-mail me at [email protected] and I will give you the place to talk to.
Kev
Old 03-30-2000, 07:03 AM   #21
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
Kev -
read the beginning of this thread for all the tips...
and my car actually came up a little bit after installing the struts! it was fairly low and now sits just a tad higher than it used to....
let me know how it goes!
j.
Old 03-30-2000, 09:08 PM   #22
GG
Member#: 1062
Post
Did you happen to get a price on these KYB's from Shox.com ?? Those guys seem to win everytime I priced out something with them.
Old 03-30-2000, 09:23 PM   #23
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
I'd emailed Shox.com for a quote and never did get a reply... i got my KYB's from a local dealer for $100 a corner....
not too bad... about the same price that MShields has... (SPD)
Old 03-31-2000, 04:21 AM   #24
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Post
RDEnterprise (shox.com) used to be kicka$$ when I ordered some DSM stuff from them a few years back. But lately they don't seem to have the same customer service as before, and their prices are no better than most. If you hunt around you can probably find a local place with prices that are just as good.
For me, shox.com is 3000 miles away, and shipping on heavy items is expensive. Much better to just order from the East coast.
Kev
FS: Brand new kyb agx setup, and a used kyb agx setup j3t 1993 - 2001 Impreza Specific Parts 3 06-10-2009 01:42 AM
KYB GR2 or KYB AGX? sexycat Brakes, Steering & Suspension 9 12-11-2008 11:18 AM
KYB AGX or KYB GR2 ? 99subi Brakes, Steering & Suspension 11 03-13-2005 03:46 PM
KYB GR-2 or KYB AGX for Rally-x Eclipse/WRX 66666 Brakes, Steering & Suspension 3 10-11-2004 07:23 PM
H+R w/ KYB AGX vs GC's w/ KYB AGX jkjersey Brakes, Steering & Suspension 2 09-06-2002 03:39 AM
