Old 06-01-2001, 08:07 AM   #1
Benjamin Tang
Member#: 4496
2009 Forester
red
Post air intake
i just had a ride in a 2.5 rs impreza with a minnam intake and was disappointed at how loud it was... it was difficult to hear the radio and there was much resonance in the interior... very uncomfortable.
i was going to do a jcsports intake on our legacy, but now i'm not so sure. gtbguy says to get a cai but it's too much fuss to be pulling it off every time it rains (and it rains a lot in vancouver).
can u guys share your experiences with me regarding how civilized your intakes are in your legacy? i'm hoping it just because it's an impreza that is the reason why it's so loud...
ben
Benjamin Tang is offline   Reply With Quote
Old 06-01-2001, 08:40 AM   #2
froggert
Member#: 768
OB, volt, 911,
ram 1500, 1098s, m620
Post
ben, i thought hearing the engine was a good thing.
mine is stock sounding at idle, but "growls" under load.
you're probably not going to want a j-tube intake if you want to keep it quiet. your best bet may be to keep the stock air boxes, put in a k&n filter, and maybe pull the intake silencer.
roger
[This message has been edited by froggert (edited June 01, 2001).]
froggert is offline   Reply With Quote
Old 06-01-2001, 08:51 AM   #3
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Post
Ben - w/ the JCS intake, you can only hear it @ wide open throttle.
GTBGUY is offline   Reply With Quote
Old 06-01-2001, 08:56 AM   #4
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
yeah, the JC Sports intake isn't quite as loud as the Minnam...though it is much louder than stock. But that's a good thing
JGard is offline   Reply With Quote
Old 06-01-2001, 09:00 AM   #5
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Post
Ben,
I have a Weapon R Hyper intake that I thoroughly enjoy. I would recommend an oil catch can to any cone intake that doesn't come with one.
<IMG SRC="http://members.i-club.com/MembersList/UserPics/3681/LegacyIntake.jpg" border=0>
If you want every day drivability this is the one. I also have a 2.5" midpipe with an aerospeed muffler. This setup gives me almost silence at idle and normal, easy acceleration sounds stock. The big change is at WOT. It transforms. Its hard to compare the sound. I guess it sounds like a well tuned Honda exhaust except about 3 octaves lower. In car resonation is only experienced at WOT with the windows down (most of it is from my exhaust).
MY99 2.5GT is offline   Reply With Quote
Old 06-01-2001, 09:04 AM   #6
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Post
Personally I'd avoid foam filters (ie: Weapon-R, HKS etc) They deteriorate and get sucked into the engine... as well, you have to replace them, and can't "clean" them like a mesh filter.
Old 06-01-2001, 09:11 AM   #7
cfwdfw
Member#: 5046
'97 Legacy gt 5 spd
Deep Saphire Blue Sedan
Smile
gtbguy,
how often then would you change the filter to avoid this problem? Seems like that should be an simple solution ... hmmm... wonder how much the filters cost?
Charlie
cfwdfw is offline   Reply With Quote
Old 06-01-2001, 10:23 AM   #8
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
It gets pretty hot under the hood so I avoid getting air from under there:
http://www.scoobymods.com/mods/impreza/thermal.php
I modified the stock setup to just get cool fender air:
<IMG SRC="http://www.scoobymods.com/mods/impreza/images/my99cai.jpg" border=0>
http://www.scoobymods.com/mods/impreza/silencer.php
Quieter too
Peaty is offline   Reply With Quote
Old 06-01-2001, 06:11 PM   #9
Benjamin Tang
Member#: 4496
2009 Forester
red
Post
an oil catch can would be a difficult thing for me since it's prohibited for emissions regs in my area...
i didn't know foam filters were that bad... but isn't the sti drop-in filter made out of foam?
since i have an ej22 i am not familiar with the ej25 setup... the ej25 has 2 filters?!?
i noticed that there is a company that makes a "shroud" around the filter that is supposed to help protect it from heat... will it help with induction noise too?
ben
[This message has been edited by Benjamin Tang (edited June 01, 2001).]
Old 06-01-2001, 07:19 PM   #10
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
Post
Hi Ben, just a quick one from Japan.
I can't remember if you have changed the Engine mamagement and sensors etc, but watch the AFS when changing out air filters.
This is the #1 killer of OE AFSs. Some "filters" let too much muck through and the AFS can get too dirty and start screwing things up.
Hope this helps. Cheers.
Oh, and the D revision has a Denso AFS - at least on the turbos. Have yet to see the guts of it...
anotherB4 is offline   Reply With Quote
Old 06-02-2001, 06:04 PM   #11
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Post
Ben - US spec (Cali spec) cars have 2 air filters even for the older style cars. Here in Canada only the black air-box by the fender exists.
As well, your MAF is going to be ok, it's a HOT-WIRE type not like the '99RS' w/ HOT-FILM which are more fradgile.
Old 06-02-2001, 06:15 PM   #12
lucien2
Member#: 1519
1998 Volvo V70R
Post
I inherited a JC intake on my GT. sounds stock except WOT, then it has a pleasing but not irritating growly howl. My only concern is with the K&N...I am a little paranoid this thing isn't doing the whole job, especially with the removal of the 2nd filter box. I kind of wish there was a paper filter replacement for this intake so thatI would know for sure that proper filtration was happening. I cleaned the K&N last month and it is almost black again...hmmm...
lucien2 is offline   Reply With Quote
Old 06-02-2001, 06:18 PM   #13
froggert
Member#: 768
OB, volt, 911,
Post
i only had 1 filter (the one by the fender) on my 97 legacy. the other box was just that - a box. maybe they changed it over in 98 or 99?
Old 06-02-2001, 07:58 PM   #14
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Post
For those of you who are concerned about the filtration power of the K&N's you can always move over to the APEX-i or the Blitz Filters which are dry elements, and have great filtration. The reason why the K&N's get black so quickly are because when it's oiled again, causes "pooled" spots of oil.
When I clean and re-oil, I usually do it overnight, allowing me to spray 3 layers of oil (very light layers), to allow for maximal penetration of the filter.
Old 06-03-2001, 01:23 AM   #15
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Post
Well, personally that's one of the things I like about the K&N! You can clean and re-oil it as often as you like, and if done correctly, you can be assured it's doing the job!!! Why go with paper?, or the constantly degrading foam? The K&N is proven. Worry about something else!
<FONT face="Comic Sans MS">Glenn O</FONT f>
nuburu2 is offline   Reply With Quote
Old 06-04-2001, 02:54 AM   #16
SubaTubaru
Member#: 5343
97 Legacy GT
4 tone red
Post
does K&N make a filter to fit my weapon R intake? or do i got to buy more weapon R filters? also does anyone know how long the filters last from weapon R? how many miles..
Mike
SubaTubaru is offline   Reply With Quote
Hot Air Intake VS Cold Air intake.Poll & Discussion arfrce Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 73 09-01-2008 11:35 PM
WTB: 02/03 WRX stock air intake or trade for Injen cold air intake limpstick VIC Private Classifieds 17 02-16-2007 02:46 AM
WTB: 00-01 RS or 00-02 Forester stock air cleaner / air box / air intake tubes JapCarRealGood SWIC Private Classifieds 2 12-30-2006 02:18 PM
ram air intake vs cold air intake Shaji Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 62 07-21-2002 10:05 PM
AEM cold air intake or Injen cold air intake? energy57 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 05-20-2002 01:27 AM
