Old 04-24-2006, 12:58 PM   #1
legacydreamz
Member#: 92423
2007 Honda CRV
and dolphins and s**t
Default 5x100 to 5x114.3?
is there any easy way for me to change my hubs so i can use 5x114.3 bolt pattern wheels? i know im going to have to use 05+ rotors and maybe calipers. im just curious in the stuff i going to need to swap my 5x100 out.
legacydreamz is offline   Reply With Quote
Old 04-24-2006, 01:03 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
You might have better luck if you search some of the Impreza forums. I'm sure it's been discussed at length there, but I've not seen it brought up seriously in here.
DLC is offline   Reply With Quote
Old 04-24-2006, 01:51 PM   #3
ooberdoob
Member#: 70418
Five Subarus later I
drive a lifted TJ.
spindles AND CVs i think
indeed, check the impreza forums.
ooberdoob is offline   Reply With Quote
Old 04-24-2006, 02:26 PM   #4
Kraziken
Member#: 38629
1999 Legacy GT (STI)
I myself checked the conversion forum.
It is very pricey.
Not worth the effort unless you're going to race your Legacy IMHO.
Kraziken is offline   Reply With Quote
Old 04-24-2006, 02:44 PM   #5
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Just wondering- is there some wheel out there is so great that it's even worth thinking about this conversion?
Kraziken- plenty of people race all manner of Subies on 5x100 hubs & wheels. Sure, the new STi 5x114.3 hubs are reportedly bigger/stronger/better, but I still have a hard time figuring out how such a conversion would be worthwhile on a Leg, unless you're a serious hard core track guy.
KD7000 is offline   Reply With Quote
Old 04-24-2006, 03:13 PM   #6
Kraziken
Member#: 38629
A snippet from the thread I read.
Why swap: Wheel selection of 5x114.3 bolt pattern and SUPERIOR front hub and bearing.
For serious Auto-X'ers, DE, or club racers, there are only a couple production wheels wider than 8.5" for the 5x100 bolt pattern and custom will run $2k+. 5x114.3 has 'any' width wheel and many can be found in the cheap, light, and strong category.
The 05 bearing in the front is larger / stronger which will prolong life and resist knock-back longer. Plus the hub and bearing come as one sealed unit, which I call a unit hub, which bolts to the knuckle. Replacing a unit hub should take ~30 mins.
Perhaps the parts costs isn't that great. I didn't consider this upgrade, because it would require dumping my uber expensive Volks.
The width of the wheel doesn't help us Legacy folk I think either, since we're already a bit more limited in space I think. At least us BD/BG owners.
If anyone is serious about this, check out the full thread here.
http://forums.nasioc.com/forums/show...ighlight=114.3
Old 04-24-2006, 03:53 PM   #7
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Good info Kraziken.
I'd think that even with near-perfect offset, the last two generations might have trouble with anything wider than 8". I saw something on MotorWeek about the differences in separate versus the hub units with integrated bearings. Interesting, and valuable if you need to swap bearings, but much more expensive than simply replacing the bearings in most cars.
Hub adapter 5x100 to 5x114.3 chucktoo Tire & Wheel 16 11-30-2009 03:51 PM
What do you think of spacers to convert 5x100 to 5x114.3 ? Legacy Tire & Wheel 11 05-03-2007 02:05 PM
Convert 5x100 to 5x114.3 P.C.D. chucktoo Brakes, Steering & Suspension 2 11-13-2005 08:48 PM
5x100 to 5x114.3 conversion Fitz Brakes, Steering & Suspension 2 06-25-2005 11:09 AM
Can we convert 5x100 to 5x114.3? awdlifestyles Subaru Conversions 1 04-01-2005 07:02 PM
