Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 04-24-2006, 02:43 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default RA Gearsets, Bushings, Mounts, guaranteed *best* pricing on ACT, Exedy!!!
Hey all,
Our RA gears are out being cryoed but almost all of them are already presold. We have a few sets left that are currently unspoken for. If you've been waiting for these, now is the time to get them!!!
Version 6 STI RA (Special Edition) Gearsets w/ Bearings and Synchros- Cryo Treated - $1909 shipped
- Stronger than stock WRX gears
- 1mm thicker gears
- Cryotreated for added durability
- Includes new bearings and synchros
- Replace gears 1-4 (shorter ratios)
- Retains stock 4th and 5th gear ratios
- Better accelleration, same cruising fuel mileage
Version 6 STI RA (Normal) Gearsets w/ Bearings and Synchros- Cryo Treated - $1909 shipped
- 1mm thicker gears
- Replace all gears (shorter ratios)
- Ideal for track
Cusco Engine/Tranny Mount Combo - 02+ WRX / 04+ STi - $250 Shipped
These mounts are stiffer than the STi Group N mounts and are designed to reduce excessive flex in the stock mounts.
STi Group N Tranny Mounts - 02+ WRX / 04+ STi - $69 Shipped
The STI "Group-N" Transmission Mount is designed to reduce excessive motion of your transmission during shifting and launching. This is done by increasing material stiffness over your stock transmission mount. By decreasing this type of motion, more energy is focused to the drivetrain and chassis rather than spent twisting your transmission. These make an excellent replacement for the liquid filled platic units that are standard issue in the 06 STi.
STi Group N Engine/Tranny Mount Combo - 02+ WRX / 04+ STi - $159 Shipped
The STI "Group-N" Engine and Tranny Mounts are designed to reduce excessive motion of your motor and transmission during hard acceleration, deceleration, and cornering. This is done by increasing material stiffness over your stock engine and tranny mounts. By decreasing this type of motion, more energy is focused to the drivetrain rather than shifting the engine and tranny. These make an excellent replacement for the liquid filled platic units that are standard issue in the 06 STi.
2) JDM 5th and 6th Gear Close Ratio Conversion Kit - 04+ STi
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes a shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box. Professional installation is recommended.
Ratios:
-5th Gear - 1.062 (0.971 stock)
-6th Gear - 0.842 (0.756 stock)
$319 Shipped for 5/6th Gear Conversion
$769 for rebuild w/ 5/6th Gear Conversion
Cusco Shifter Bushings - 02+ WRX
$37 Shipped
Also, we now carry Kartboy products! Please PM for pricing and combos.
http://www.gruppe-s.com/Subaru/subtrn.htm
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: [email protected]
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
Gruppe-S is offline
Old 04-24-2006, 02:46 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
OK, we know everyone claims to have the best pricing on ACT and Exedy but take a good look around and then compare to our prices. We're fairly confident that we really do have the *BEST* pricing on ACT and Exedy. If we don't, let us know and we'll beat our competitors pricing.
1) Exedy Organic Clutch Kit and ACT Steetlite Flywheel (Stage 1)- 02+ WRX
-Clamp Load: 2300 lbs/ft.
-Pressure Increase: 44% over stock clutch.
-Weight: clutch - 14.3lbs, flywheel - 13.9 lbs.
$750 Shipped!!!
$1175 Installed!!!
2) Exedy Hyper Single Clutch/Flywheel Kit (Stage 3)- 02+ WRX
-Clamp Load: 2655 lbs/ft.
$PM FOR BEST PRICE!!!
3) Exedy Twin Plate Clutch/Flywheel Kit (Stage 4)- 02+ WRX
-Clamp Load: 2205 lbs/ft.
4) Exedy Organic Clutch Kit and Steetlite Flywheel (Stage 1) - 04+ STi
-Weight: clutch - 14.3lbs, flywheel - 15.4 lbs.
$925 Shipped!!!
$1350 Installed!!!
5) Exedy Hyper Single Clutch/Flywheel Kit (Stage 3) - 04+ STi
6) Exedy Twin-Plate Clutch/Flywheel Kit (Stage 4) - 04+ STi
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Gruppe-S is offline
Old 04-24-2006, 02:46 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) ACT HD Street Disc Kit and Steetlite Flywheel (Stage 1) - 02+ WRX
-Torque Capacity: 411 lbs/ft.
-Pressure Increase: 32% over stock clutch.
-Weight: clutch - 17lbs, flywheel - 13.9 lbs.
$649 Shipped!!!
$1100 Installed!!!
2) ACT HD Street Disc Kit and Prolite Flywheel (Stage 1+) - 02+ WRX
-Weight: clutch - 17lbs, flywheel - 9.6 lbs.
$699 Shipped!!!
$1119 Installed!!!
3) ACT HD Street Disc Kit and Steetlite Flywheel (Stage 1) - 04+ STi
-Torque Capacity: 475 lbs/ft.
-Weight: clutch - 17lbs, flywheel - 15 lbs.
$855 Shipped!!!
$1275 Installed!!!
4) ACT HD Street Disc Kit and Prolite Flywheel (Stage 1+) - 04+ STi
-Weight: clutch - 17lbs, flywheel - 11.1 lbs.
$879 Shipped!!!
$1299 Installed!!!
And for the hardcore guys out there:
5) ACT HD 6 Pad Race Kit and Prolite Flywheel - 02+ WRX
-Torque Capacity: 527 lbs/ft.
$699 Shipped!!!
$1119 Installed!!!
6) ACT HD 6 Pad Race Kit and Prolite Flywheel - 04+ STi
-Torque Capacity: 608 lbs/ft.
-Pressure Increase: 35% over stock clutch.
$819 Shipped!!!
$1239 Installed!!!
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Gruppe-S is offline
Old 04-24-2006, 07:47 PM   #4
wrx-rated
Member#: 89562
2002 wrx
white
Default tranny mounts
pmed you!!!!!
wrx-rated is offline
Old 04-25-2006, 01:17 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
PM received, thanks.
Gruppe-S is offline
Old 05-04-2006, 09:28 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
RA gears now on backorder.
Gruppe-S is offline
Closed Thread
ACT, Exedy, Twin Disc Rebuild Kits! No Limit Motorsport Drivetrain 747 01-02-2015 04:41 PM
STi 6 Speeds! STi Mounts! *BEST* pricing on ACT, Exedy! Gruppe-S Drivetrain 7 07-31-2006 06:41 PM
As always, the *BEST* pricing on ACT and Exedy. Kartboy and STi mounts in stock too. Gruppe-S Drivetrain 9 07-17-2006 06:14 PM
Guaranteed Lowest Prices on ACT and Exedy! Gruppe-S Drivetrain 10 06-02-2006 05:35 PM
JDM STi Spec C 6 speed tranny, guaranteed best prices on Exedy and ACT! Gruppe-S Drivetrain 4 04-18-2006 07:17 PM
