Old 06-01-2001, 10:07 AM   #1
lucien2
Member#: 1519
1998 Volvo V70R
Question Swaybar Q
Hi All-
got my front tower brace on last ight, which is a nice, subtle addition to the GT's handling at speed. I was getting ready to bolt the 18mm sway bar up, but....
I did a little exit ramp tooling around this morning and found that the rear end is willing to step out and curtail any push with with a little throttle lift. I am now worried that an 18mm bar is going to be a bit much for the otherwise stock suspension, and that I may end up with a snap oversteer-prone set up if I do. Anyone out there with track experience in their car care to weigh in with an opinion?
lucien2 is offline   Reply With Quote
Old 06-01-2001, 11:11 AM   #2
slide
Member#: 1130
2013 STI Hatch
Post
Wow, I would have thought 18 be a bit soft.
I run my adjustable at no softer than 22. But I also have GAB's and a whole lot of other crap. Upgrade your struts and springs. Then see how the rear end stays. By the way, you aren't still running stock tires? That should be your first upgrade.
slide is offline   Reply With Quote
Old 06-01-2001, 04:49 PM   #3
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Post
I can't imagine an 18 upsetting the balance; I've got crappy tires on my OB< but it's pretty balanced, and will only step out when *I* want it to.........
sybir is offline   Reply With Quote
Old 06-01-2001, 06:29 PM   #4
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
Post
We have bigger swaybars than most on our cars, and found that the best way of making the car's rear more consistent was changing the rear swaybar links.
Having said that, none of us are in an OB (they did wonders on my old BG5) - all sedans, so I can't vouch that such links are avail for your car (surely someone's got them though).
Hope this helps.
anotherB4 is offline   Reply With Quote
Old 06-01-2001, 07:12 PM   #5
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Post
The swaybar links are identical between the OB and other Legacys of the same body styles. Same with sway bars (other than size).
We have an 18mm bar on my wife's GT. She's not a performance driver by any means, but has not had any problems with the car oversteering. The ride's a bit harsher, and the car tramlines a bit more, but that's to be expected - the stiffer the swaybar, the less independent your suspension is. I think you'd be perfectly safe putting an 18mm on there.
rrubel is offline   Reply With Quote
Old 06-01-2001, 08:51 PM   #6
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Post
I'd recommend the "WhiteLine" links to go with the 18mm bar. I'm very pleased with the improvement the combo made in our Wagon! Great pricing!! http://www.pdm-racing.com/index_2.html
<FONT face="Comic Sans MS">Glenn O</FONT f>
[This message has been edited by nuburu2 (edited June 01, 2001).]
nuburu2 is offline   Reply With Quote
Old 06-02-2001, 12:17 AM   #7
2.5GTL
Member#: 5082
1998 Legacy GT Ltd
Post
I just put on my new adjustable sway bar and I have it set at 19mm with otherwise stock suspension. Last night I was playing and got into a nice slide where my rear was coming around slightly faster than my front. Because of the road I also had to brake as I was sliding through the exit of the corner. I did have to counter steer just a little bit so keep things resonably straight but the car was also very much in control. If you are confident in you driving skills or don't push the car at all then the 18mm should be fine. Personally, I loved the control I had last night. Hope this helps.
Jason
2.5GTL is offline   Reply With Quote
Old 06-02-2001, 12:42 AM   #8
rallysquirrel
Member#: 7006
2007 SpecB
Post
What's the stock swaybar in the rear. On my OB it's 18mm. I've got a little bit of understeer.
rallysquirrel is offline   Reply With Quote
Old 06-02-2001, 12:52 AM   #9
froggert
Member#: 768
OB, volt, 911,
ram 1500, 1098s, m620
Post
i think it's 15 mm on the legacy gt. i couldn't get the car to do anything but push with the front strut tower bar and stock suspension and sway bar. i was also running dunlop sp 5000's in stock size. might the tires be the key?
roger
froggert is offline   Reply With Quote
Old 06-02-2001, 07:00 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
The rear end shouldn't want to step out at all with the stock rear sway bar on there. Dropping the throttle mid-corner should get the car to tuck in a little bit, but not actually transition to oversteer. If you're actually getting the rear to come around, I'd check your alignment - make sure your rear toe is at zero. A little toe out in the rear will make the rear more willing to come around - I used to run a bit of toe out for auto-x.
With both of my GTs, the stock suspension + 18mm bar was very nice. On my '97, stock suspension + 18mm bar + Kartboy endlink bushings + Powerflex rear sway bar bushings = absolutely perfect balance. The car would still push if I got on the gas too hard in low speed corners (ie trying to accelerate too hard at an auto-x), but at speed the car was wonderfully neutral.
So, make sure your alignment is good, and go for the 18mm. You should be fine.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 06-02-2001, 03:41 PM   #11
lucien2
Member#: 1519
1998 Volvo V70R
Post
Thanks all, especially Pat. Yea, she just tucks in real nice right now, but it sounds like 18mm with a set of links and bushing will be a nice upgrade, low cost too. I have an 18mm bar lying around already, off my Outback (went to the whiteline there, the OB is set up as well as an OB can be now).
Ok so, free 18mm bar, $100 or less for links, $30 for the bushings, that leaves room for....
TIRES!!!!!! GET THESE DAMNED RE92s OFF! What do you all suggest? the Kumho? this car will see snow maybe 3x a year, avg. 3-6", with th occasional baltimore "blizzard" of 8"
RCE Rear SwayBar/Technica Brake Lines/Kartboy Endlinks Devil2holla Suspension/Brakes/Handling 7 06-08-2010 07:14 PM
17mm Front Swaybar + 22mm Rear Swaybar links_courses Brakes, Steering & Suspension 30 05-18-2004 07:12 PM
Swaybar replacement for PGT? Endlinks? Swaybar mounts? Subie Gal? Sean Motorsports 6 10-25-2002 04:15 PM
Local Trade: WRX STi/SPT Front Swaybar for WRX Stock Swaybar + $50 fastfood New England Impreza Club Forum -- NESIC 5 09-24-2002 01:30 AM
SPO adj. swaybar or MRT adj. swaybar? Any suggestions???? k2snow Brakes, Steering & Suspension 3 11-13-2001 03:47 AM
