Old 04-24-2006, 09:28 PM   #1
WRXDrUnKiE
Member#: 69608
2004 STi
Default Bigger Injectors with a stock STi?
I am going to be rebuilding an STi I just bought and I would like to put some forged pistons and helix 860cc injectors. Does anyone know if I can do this and keep it stock without running into any problems. I am upgrading to a gt30R kit later on and dont want to have to replace injectors and pistons then if it will be out of the car now.
-Matt
WRXDrUnKiE is offline   Reply With Quote
Old 04-24-2006, 09:41 PM   #2
STimo
Member#: 110273
450 whp 30R STI
[email protected]
DO NOT run bigger injectors without engine management, you can ruin your motor.
If you plan on installing forged pistons, i would also look into doing to whole bottom end while you are in there. It costs quite a bit to pull the motor and open it up. My suggestion is while you are in there, you should upgrade everything so you don't have a weak link.
STimo is offline   Reply With Quote
Old 04-24-2006, 10:06 PM   #3
WRXDrUnKiE
Member#: 69608
2004 STi
What weak links other than pistons would I have to worry about? And I couldnt use an SAFC or anything or an AP?
Old 04-24-2006, 11:16 PM   #4
STI2005PR
Member#: 68988
2015 STI
Grey
And why will he ruin his motor? He will run very rich and that's about it.
STI2005PR is offline   Reply With Quote
Old 04-24-2006, 11:25 PM   #5
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
For one, the car won't start nor idle with 800cc injectors. Secondly, you'll wash the bores and contaminate the oil with overfueling.
Simple answer, don't do injectors unless you have EM. Used EM is only $500 anyway.
TypeC is offline   Reply With Quote
Old 04-24-2006, 11:29 PM   #6
billy720
Member#: 76903
2004 WRX STi
if you're gonna spend money to get pistons put in,you might as well do everything at one time to save money.mine is in the process of being rebuilt as we speak.my valves floated so i decided i might as well get it rebuilt since it was gonna cost me a lot to get them fixed.I dropped $8k for the project.Custom forged pistons and rods,rod and main bearings,arp headstuds,darton race sleeves,new gaskets,ferrea valves,retainers,locks,seals.other mods on the car right nowerrin catless race pipes,hks 3inch turboback,perrin 816ccs,perrin fuel rail,walbro fuel pump,utec,fp green,aps dr725,clutchmaster single plate clutch w/flywheel
billy720 is offline   Reply With Quote
Old 04-24-2006, 11:36 PM   #7
billy720
Member#: 76903
2004 WRX STi
forgot to add that i was upgrading from the green to gt35R.i'm selling my green if ur intersted.1500k miles on it.1250shipped
Old 04-25-2006, 12:04 AM   #8
bboy
Member#: 56468
04 Improved STI
Dirty White
100% correct. Engine Management should be THE FIRST MOD EVERYTHING ELSE DEPENDS ON TUNING WITH IT.
Buy a Walbro pump.
Think about calling a reputable performance shop/vendor and discussing an upgrade path. If you are yanking the motor, there's tons of stuff you can do while it's out. I recommend www.worldoneperformance.com becuase I know all of them well.
Old 04-25-2006, 09:20 AM   #9
STI2005PR
Member#: 68988
2015 STI
Grey
Actually your wrong. My car started fine, idle fine and drove fine with 810cc injectors. The problem came when I past 4,000rpms that it would run very rich.
Old 04-25-2006, 09:36 AM   #10
jays05
Member#: 78165
05 STI 35r + e85
Swapping injectors with the motor in the car is really easy.
jays05 is offline   Reply With Quote
Old 04-25-2006, 04:15 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Old 04-25-2006, 04:18 PM   #12
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Originally Posted by Uncle Scotty
it is with the sti (not sure on the newer 06 2.5 wrx's), but 1/10th as hard as the GBOD's and the 2 litre
overdose is offline   Reply With Quote
Old 04-25-2006, 05:14 PM   #13
WRXDrUnKiE
Member#: 69608
2004 STi
Im coming off of an 02 wrx, injectors took a while for us.
Will I need bigger injectors with these mods? gtasti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 06-25-2008 05:22 PM
Injectors with a stock turbo? bendavi17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-13-2007 10:51 AM
Whats wrong with the stock STi injectors? jdiddy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-05-2006 09:24 AM
Bigger Injector with light mods? wrathfirex Engine Management & Tuning 5 02-01-2004 11:43 PM
anyone run a bigger turbo with the stock top mount? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-03-2003 01:30 PM
