Old 04-24-2006, 10:23 PM   #1
JDM Importers
Vendor
Member#: 87569
Once Was Gr8wheels
OMGHi2U ej25 DOHC to Phase 2 SOHC
Help me out! putting a phase 2 SOHC into a 98 what do I need to do!
Is there a link
Kevin Jdmimorters
JDM Importers is offline   Reply With Quote
Old 04-25-2006, 05:32 PM   #2
FSRBIKER
Member#: 112753
2005 Outback XT
Not that I know of but I am doing the same swap right now. 2.5 SOHC from a 2002 RS to my 97 Legacy Outback. I even got the complete exhaust to the mid pipe bfore the muffler and it all swaps over. The main engine harness plugs on the passenger rear side are different, I will be converting the plugs this week. You will also have a lot less vacuum lines on the new motor.
Is there a link
Kevin Jdmimorters
FSRBIKER is offline   Reply With Quote
Old 07-21-2006, 01:10 PM   #3
FSRBIKER
Member#: 112753
2005 Outback XT
Anyone done this swap? I started to track down all the wiring conversion I would have to do but stopped, if anyone has input on the wiring swap that would help. I have the engine harness and most of the interior harness with the ECU but I think I am over my head.
Old 04-11-2014, 11:42 AM   #4
wrecks2020
Member#: 299572
I'm also looking at this swap. The thread ends here. Is there an easy way to do this or should I just rebuild the DOHC? Can I swap the intake manifold from the 98? Does the ECU on the 98 (automatic) work on a SOHC?
wrecks2020 is offline   Reply With Quote
Old 04-11-2014, 06:44 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Intake manifolds are not compatible, and ECUs and harnesses are different. People have managed to do the swap, but it's not very common at all. I've only seen a couple examples discussed in threads here in the years I've been on this site.
EJ25 dohc heads+ phase 2 block = what compresson ratio? supermoose Subaru Conversions 18 01-11-2016 02:21 AM
Early SOHC intake manifold bolt to phase 2 SOHC heads?? Will ECU work with cam sensor ciper Normally Aspirated Powertrain 7 08-26-2008 05:35 PM
Phase I DOHC to Phase II SOHC swap jnorth85 Subaru Conversions 4 04-23-2008 07:16 PM
WTB: EJ25 Phase 2 SOHC Block BossGVR4 Private 'Wanted' Classifieds 3 08-02-2006 04:45 AM
EJ25 dohc heads+ phase 2 block = what compresson ratio? supermoose Normally Aspirated Powertrain 2 01-29-2004 02:58 PM
