Old 04-24-2006, 10:45 PM   #1
Seayak
Member#: 52687
2004 Forester XT 5M
Question Taller 5th gear for 04 FXT 5M?
Re-posted from Forester41 forum - no joy there...
My dealer needs to open up my tranny (again) to replace synchros... I'm thinking of changing 5th gear at the same time - I'd like to drop 500 to 700 RPMs. Does anyone know if this is possible and where I'd get the gear?
Seayak is offline   Reply With Quote
Old 04-25-2006, 03:29 AM   #2
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
the 5th gear set is independent from the others, so any 5th gear set with a similar hub/syncro design would work. i think all 5th syncros are the same too, but i would stick with 99 or newer. just find the model that has the ratio you want, get the vin#, go to subaru parts and buy a 5th gear set.
00Maddog is offline   Reply With Quote
Old 04-28-2006, 08:19 PM   #3
teiva-boy
Member#: 22825
Interesting thought, especially with today's gas prices.
Any real world experiences with someone doing this?
teiva-boy is offline   Reply With Quote
Old 05-01-2006, 01:15 PM   #4
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
I think you're out of luck with this one. The gearing in the FXT is the same as the WRX, and that's probably the tallest 5th you'll find. Your only options are either taller tires or a new final drive, but that will change the gearing in every gear, not just 5th.
bluescoobywagon is offline   Reply With Quote
Old 05-01-2006, 07:49 PM   #5
teiva-boy
Member#: 22825
I don't recall my old bug eye being over 3k at 70MPH? But it's been a while too, and I've been pampered by a 4l60E in a suburban for over two years.
Old 05-01-2006, 09:25 PM   #6
wrxtool
Member#: 75589
2005 forester xt
wrx and fxt gearing are not the same
wrxtool is offline   Reply With Quote
Old 05-01-2006, 11:22 PM   #7
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
Transmissions are the same, the final drive is different. The wrx is 3.90 and the fxt is 4.444. Someone will correct me if i'm wrong. Alos I think you are out of luck unless you change your final drive to wrx ratios (3.90) to drop those rpms down but this will also effect every other gear aswell.
John__Gotti is offline   Reply With Quote
Old 05-01-2006, 11:59 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Our USDM 5th gears on our 5spd Subarus are among the the lowest gearing there is.
put in a WRX tranny and rear diff and you'll be fine. Then the WRX guy would LOVE your tranny!
FuJi K is offline   Reply With Quote
Old 05-02-2006, 10:24 AM   #9
fliz
Member#: 30342
According to Unabomber's FAQ, the FXT 5th is .780, compared to .738 for the WRX.
I don't know if they are interchangeable, however.
From the FAQ:
How much are brand new, fully assembled 2005 OEM transmissions?
Ratios verified via SOA on 11/19/04 and all prices are retail with no discounts:
WRX transmission 32000AG970 $3111.92
3.454 (1st) 1.947 (2nd) 1.366 (3rd) 0.972 (4th) 0.738 (5th) WRX FD 3.90
(Front 3.9 center 1.1 rear 3.54)
FXT transmission 32000AG820 $3111.92
3.454 (1st) 2.062 (2nd) 1.448 (3rd) 1.088 (4th) 0.780 (5th) FXT FD 4.444
(Front 4.44 center 1.0 rear 4.44)
With all the busted/swapped WRX transmissions, it shouldn't be too hard to find a fifth gear out there cheap. The risk is the cost to pull the transmission apart.
fliz is offline   Reply With Quote
Old 05-02-2006, 03:38 PM   #10
fourdegrees
Member#: 49662
2005 FEALing fine
FXT manual trannies are the same gearing! Only different final drive.
fourdegrees is offline   Reply With Quote
Old 05-02-2006, 11:32 PM   #11
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
From the FAQ:
the cost should be 4 hours or less at any shop, as 5th gear r+r is an in the car repair, you just remove the extension housing (transfer section) from the trans and there 5th is staring at you. i have a spare 5th gear set from a 02 wrx if anyone is willing to give this a try.
not sure about the ratios, seems to be several opinions...time to check the service manuals.
Old 05-02-2006, 11:41 PM   #12
WRXOFIVE
Member#: 105201
05 WRX
The ratio's are NOT the same, look at the above post closely. The ratio's look different to me, also the Final drive is not going to make the ratio's in the trans. any different(meaning 1-4)
WRXOFIVE is offline   Reply With Quote
Old 05-02-2006, 11:42 PM   #13
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
ok here's your 04, looks like turbo is already .738
sorry about the spacing, computer>me
1. General Description
A: SPECIFICATIONS
1. MANUAL TRANSMISSION AND DIFFERENTIAL
Model Non-turbo Turbo
Type 5-forward speeds with synchromesh and 1-reverse
Transmission gear ratio
1st 3.454
2nd 2.062 1.947
3rd 1.448 1.366
4th 1.088 0.972
5th 0.780 0.738
Reverse 3.333
Front reduction
gear
Final
Type of gear Hypoid
Gear ratio 4.111 4.444
Rear reduction
gear
Transfer
Type of gear Helical
Gear ratio 1.000
Final
Type of gear Hypoid
Front differential Type and number of gear Straight bevel gear (Bevel pinion: 2, Bevel gear: 2)
Center differential Type and number of gear Straight bevel gear (Bevel pinion: 2, Bevel gear: 2 and viscous coupling)
Transmission gear oil GL-5
Transmission oil capacity 3.52 (3.7 US qt, 3.1 lmp qt)
Old 05-03-2006, 12:16 AM   #14
fourdegrees
Member#: 49662
2005 FEALing fine
Thank you for the above post. Cliff notes version: FXT gear ratios = WRX gear ratios. FXT FD ratio = 4.44
WRX FD ratio = 3.9
aftermarket taller 5th gear? jam69007 Transmission (AT/MT) & Driveline 5 05-14-2010 08:16 AM
Taller 5th gear for 5MT? BadTrip Transmission (AT/MT) & Driveline 49 06-17-2008 10:09 PM
Higher 5th gear for FXT? Seayak Forester Forum 8 04-22-2006 12:11 AM
Trade 05 WRX for 04 FXT? the05wrxguy General Community 28 11-29-2005 06:39 AM
Injen CAI for 04 FXT dizizjake Forester Forum 9 11-02-2005 04:26 PM
