Old 04-25-2006, 12:43 AM   #1
typeRsti
Member#: 111748
Default Does this look like detonation? my #2 rod bearing has been hammered to peices
hi guys, recently stripped my 97 sti engine due to a big knocking sound, i had purposely bought the car cheap knowing it had a knocking bearing, im a mechanic in new zealand and have done plenty of engine rebuilds but none on a subaru .So since i have owned a few wanted to have a crack.. anyway, once stripped i noticed the #2 connecting rod was as loose as a whore and there was basicly nothing left but hammered bearings and a scored crank.. im assuming that because the previous owner had fitted a full 3 inch exhaust and a blitz cone filter and had left the air temp sensor dangling in the engine bay that the car had leaned out and cause detonation on that cylinder.. Just after any other thoughts on this as i would hate to rebuild and have the same thing happen again, im thinking an injector clean and flow and return to the old airbox would be a start( obviously i have to rebuild the engine first) and once done a run on my local awd dyno
cheers
i have some pics of the #2 piston which has some odd carbonless spots on it.. how do i upload pictures?
typeRsti is offline   Reply With Quote
Old 04-25-2006, 08:50 AM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
you need to host them on photobucket or similar... You also need to have a certain number of posts before you can put pics up...
jigga is offline   Reply With Quote
Old 04-25-2006, 02:12 PM   #3
bboy
Member#: 56468
04 Improved STI
Dirty White
That set up plus a stealthy manual boost controller and no tuning would end in lots of det. What's your question?
You need to tune and everything will be fine.
Old 04-28-2006, 03:51 AM   #4
typeRsti
Member#: 111748
yeah.. i didnt own the car when the damage was done... thought detonation from these mods would cause it... you just backed up what i thought
cheers
Old 04-28-2006, 10:38 AM   #5
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
That makes me think maybe the head gasket was on its way out. Also when rod bearings go it allows the piston to hit the head and sometimes it bends valves, That could explain the carbonless spots
Scoobie Steve is offline   Reply With Quote
Old 05-02-2006, 05:12 AM   #6
typeRsti
Member#: 111748
that makes complete sense, was thinking the carbonless spots look very symmetrical like valve marks, but theres no indentations in the pistons.. recon those old factory sti pistons are alot stronger than i thought, no doubt once i strip the head the valves might be a tad bent... hope not though!
cheers for the input
Does this look like a Warhol to you? Kha0S Off-Topic 15 02-02-2006 05:20 AM
does this look like a scam to you guys? Depeche Off-Topic 6 11-16-2005 10:20 AM
uhm.. What does this look like to you? *lmao* Sauceboy01 Off-Topic 19 07-09-2004 01:40 AM
