Old 04-25-2006, 03:08 AM   #1
sha_zapple
Member#: 41012
1998 Legacy L
Default JDM foglight install
So im about halfway done. So far ive got the bumper cut and Im on the verge of getting the mounting correct.
stock hole size vs cut hole size
test mounting. Since the USDM and JDM bumper and bumper beam arnt the same Ive had to cut up and drill the beam a bit as well as the JDM bracket
original bracket vs modified
How it should look when the bracket bugs are fixed vs ye old foglights
The easy part will be running the wires. I already have one relay for the fogs and i picked on another for the sides. Only need to run one more wire to the cabin.
Ill be posting a DIY on SLi in a few days (ive taken about 50 pictures so far!). I hope to be done the mounting tomorrow (still need the male end for the second fog switch, so the sides will have to wait)
sha_zapple is offline   Reply With Quote
Old 04-25-2006, 07:57 AM   #2
MitchGT
Member#: 73684
2012 4Runner
Is there a way to control which bulb comes on? Or do both light up whenever you hit your fog switch?
MitchGT is offline   Reply With Quote
Old 04-25-2006, 11:18 AM   #3
sha_zapple
Member#: 41012
1998 Legacy L
Ill have two switches, one for the fog (round) and one for the sides (rectangular)
Old 04-26-2006, 03:33 AM   #4
sha_zapple
Member#: 41012
1998 Legacy L
woot, wiring
relays
switches
I still have to wire up the second switch, but that should be easy since the first switch is already hooked up (I can splice off of all the wires to it, except for the relay)
Technically I could put everything back together, but Id still like to fiddle around and aim them before I put the bumper back on. Id also like to paint the brackets and some parts around the radiator.
interesting comparo pic of how large the new fogs really are.
some measurements i took
what underneath my dash looks like
Old 04-27-2006, 01:54 AM   #5
sha_zapple
Member#: 41012
1998 Legacy L
finished!
Old 04-27-2006, 02:35 AM   #6
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
huzzah!
looks great!
now grab a beer.
fibuz
fibuz is offline   Reply With Quote
Old 04-27-2006, 10:35 AM   #7
MitchGT
Member#: 73684
2012 4Runner
^^^ agreed.
Nice install.
Old 05-02-2006, 06:26 PM   #8
CarlitoQC
Member#: 83097
hmm i have to do the same process... hopw it! this post will help won't be too hard on wiring...bumper. cut and mounting mod... the whole thing finally
CarlitoQC is offline   Reply With Quote
Old 08-20-2006, 04:33 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I've read some things that said these were combination fog/driving lights, but I've also seen something that said the outer lights were turn assist lights (that should come on with your turn signals to project light around a corner). Which is correct? Where do the outer lights project their light?
Pat
Old 08-20-2006, 04:38 PM   #10
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I thought they were turn assist lights w/ projector foglights.
Wiscon_Mark is offline   Reply With Quote
Old 08-21-2006, 04:58 AM   #11
that one legacy
Member#: 103665
yeah i read somewhere that the outer reflector uses turn signal bulbs, i would imagine it wouldn't be much good for anything else.
me personally, if i ever get JDM fogs for mine (it's either that or Hella Micro DEs), i'm just gonna hook the outer bulb up to the corner lamps.
that one legacy is offline   Reply With Quote
Old 08-21-2006, 01:50 PM   #12
sha_zapple
Member#: 41012
1998 Legacy L
The bulbs are 12v 35W. Theyre not supposed to blink, instead theyre constant so you can see curbs and such. I dont have them setup like that though. I have them wired up so I can turn them on whenever I want. They light up the ditches quite nicely.
Check out the DIY section at www.sl-i.net I have a full write-up on how to install them there.
Old 08-21-2006, 03:27 PM   #13
that one legacy
Member#: 103665
12v 35w, are they 194 bulbs then? or those really small globular bulbs? i was thinking that if i do go with the jdm fogs, i'd just have them wired to the corner lights so that they are constant on (IE: the parking lights). that way they'd give a bit more illumination on the corners, and would serve as pretty good marker lights.
Old 08-21-2006, 05:42 PM   #14
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Looks great! Man I'd like to go with these but it's so much work for a little bling...
xcntrk75 is offline   Reply With Quote
Old 08-21-2006, 08:38 PM   #15
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
or better lighting, which is totally about safety. Looks are the perk.
Old 08-21-2006, 09:39 PM   #16
that one legacy
Member#: 103665
does anyone have any idea which has the better output, beam pattern, cutoff, etc... between the JDM BG fogs, and the Hella Micro DEs?
Old 08-21-2006, 10:25 PM   #17
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
That would have to be a personal experience thing, TOL. There aren't any hard numbers because people mount these things differently, and there isn't a good way to collect the subjective data.
I can tell you that both would be a big improvment.
Old 01-25-2015, 09:53 AM   #18
zomg
Member#: 183407
'04
WRB STi/goldies/wingless
bump from the dead. trying to install these lights on my legacy and having difficulty maching up the brackets without pictures!
zomg is offline   Reply With Quote
Old 01-25-2015, 05:24 PM   #19
phieleven
Member#: 108466
'98 GT & '95 LX
Outback BH & BP
phieleven is offline   Reply With Quote
Old 02-06-2015, 07:27 PM   #20
zomg
Member#: 183407
'04
awesome, thanks. found the thread halfway through the install... turned out great!
JDM foglights installed but not working Subaruist Electrical & Lighting 11 11-06-2006 06:24 PM
JDM Foglight Install Questions on a 98 Legacy GT 2.5WagonGuy Legacy Forum 1 05-20-2006 06:55 PM
JDM foglight install how to sha_zapple Legacy Forum 0 04-30-2006 11:23 PM
JDM Foglight Installation Instructions Mercureie Interior & Exterior Modification 2 02-13-2006 01:03 AM
JDM Foglights installed TEKNOSYS Member's Car Gallery 39 01-29-2006 01:11 PM
