Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-25-2006, 11:00 AM   #1
method6980
Member#: 89073
Default Huge problems please help
Hey there,
I have just gotten my car up to stage 4.
VF34 pinks, UTEC, full exhaust FMIC.
Now when my car hits boost, it seems to choke itself out... stutters like crazy.
I was under the impression it was the MAF, however i tested that and its working just fine. A friend who is a mechanic insists its the fuel management system (UTEC). I think i might have the older version of the utec on my 05, would that cause these issues? is there a fix to it?
method6980 is offline   Reply With Quote
Old 04-25-2006, 11:16 AM   #2
method6980
Member#: 89073
One more thing...
I bought the utec from EBAY, how does one check what version it is??
We just unhooked the UTEC, and the car now runs on the stock ECU a LOT better. i guess it is not the MAF sensor. What would cause the car to cut out the way it does?
Old 04-25-2006, 12:40 PM   #3
9vapors
Member#: 92582
did you have the car tuned after you made your car stage 4? Sounds like it needs to be tuned.
9vapors is offline   Reply With Quote
Old 04-25-2006, 01:02 PM   #4
method6980
Member#: 89073
Tried to tune it with a friend who has one as well. she wont hit max boost.... just cuts out.
Old 04-25-2006, 01:03 PM   #5
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
get some logs up so we can see what's going on.
SloRice is offline   Reply With Quote
Old 04-25-2006, 02:12 PM   #6
TurbojonLS
Member#: 38772
2 Cars, No Bling
Also post some screenshots of your parameter settings.
TurbojonLS is offline   Reply With Quote
Old 04-25-2006, 02:25 PM   #7
method6980
Member#: 89073
How would i go about getting either of those?
I dont have a laptop. lemme see what i can figure out right quick
Old 05-25-2006, 09:41 AM   #8
Chrisdolf
Member#: 49248
2002 WRX 2.5L Hybrid
It sounds like you may be running the wrong parameters on your UTEC. Stages 1-3 use the same parameters, but stage 4 requires different ones. When you switched your car to stage 4, did you upload the stage 4 parameters from TurboXS to your UTEC?
Chrisdolf is offline   Reply With Quote
Old 05-25-2006, 11:28 AM   #9
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Then how the ___ did you expect to install and run a UTEC?
I recommend downloading the TXS manual and reading it a few times. All of your questions will undoubtedly be answered.
TypeC is offline   Reply With Quote
Old 05-25-2006, 01:04 PM   #10
Bolster
Member#: 22290
2002 WRB WRX Wagon
+ infinity! Yikes! It is very important to RTFM, especially with a UTEC.
Bolster is offline   Reply With Quote
Huge problem. Need HELP! importfanatic17 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 06-24-2008 03:12 PM
Huge problem, need help dtseng01 General Community 1 06-15-2007 06:13 PM
Huge Problem Need Help mishalov Engine Management & Tuning 4 06-08-2005 08:15 PM
Huge Problem. Please Help! drifterx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 12-17-2002 12:11 PM
('93-'01) Huge Problem please help!!!!!! 2.5rsMI Impreza Forum 8 08-05-2001 07:30 PM
