#1 |
Member#: 102013
Vehicle:2002 WRX |
Have some logs to take a look at....how to posts? I did a search...no help
#2 |
Member#: 44351
Vehicle:2004 Mitsubishi Evo 701whp 9.91@146 |
#3 |
Member#: 102013
Vehicle:2002 WRX |
posts logs? in the right format from a text file
#4 |
Member#: 102013
Vehicle:2002 WRX |
Load Knock Mod Mod Mod WB
RPM MAP MAF TPS Site Count Ign#1 Inj#1 Ign Fuel Boost MAF AFR psia V % deg duty deg % (CL) V 3703 +4.5 3.2 82 30 00 +32.1 22.5 +27.3 +1.4 ECU. 2.8 12.86 3716 +4.7 3.2 82 30 00 +32.2 22.3 +27.3 +2.8 ECU. 2.8 12.86 3822 +5.1 3.2 82 30 00 +31.7 21.6 +26.7 +2.0 ECU. 2.8 12.93 3930 +5.5 3.3 82 30 00 +31.4 24.0 +26.3 +1.9 ECU. 2.9 12.99 3972 +5.9 3.4 87 30 00 +31.3 26.1 +26.1 +1.4 ECU. 2.9 12.81 4135 +6.4 3.4 95 40 00 +31.1 25.7 +25.8 +0.4 ECU. 2.9 12.46 4135 +7.0 3.6 96 40 00 +32.0 29.8 +24.5 +0.4 ECU. 2.9 12.17 4251 +7.4 3.5 96 40 00 +32.2 34.5 +23.5 +0.2 ECU. 3.0 11.81 4432 +8.2 3.6 95 50 00 +32.4 36.9 +22.8 -0.3 ECU. 3.1 11.58 4432 +9.2 3.9 92 50 00 +29.6 38.9 +22.2 -0.5 ECU. 3.1 11.27 4553 +10.0 3.8 92 60 00 +29.0 48.2 +22.1 -1.5 ECU. 3.2 11.02 4714 +11.5 3.9 92 60 00 +27.9 44.2 +20.3 -0.4 ECU. 3.4 10.89 4741 +12.7 4.0 91 70 00 +26.1 50.2 +19.6 -1.6 ECU. 3.3 10.67 4894 +13.7 4.0 81 70 00 +26.9 56.5 +19.7 -1.2 ECU. 3.2 10.52 5065 +14.9 4.1 64 80 00 +27.7 54.2 +19.5 -1.1 ECU. 3.4 10.48 5096 +14.9 4.1 64 70 00 +31.1 51.0 +19.5 -0.8 ECU. 3.3 10.65 5257 +13.9 3.9 38 60 00 +31.3 27.1 +21.0 -1.0 ECU. 2.1 10.93 4901 +9.0 3.6 0 20 00 +8.9 34.1 ECU. +0.1 ECU. 2.9 11.33 4997 +5.1 3.6 98 10 00 +26.3 32.5 +26.1 -0.9 ECU. 3.1 12.59 3683 +3.5 3.3 102 30 00 +30.8 24.2 +27.9 +2.5 ECU. 2.9 12.56 3813 +3.1 3.3 103 40 00 +31.9 24.7 +25.0 +0.7 ECU. 2.8 11.27 3749 +6.4 3.4 102 40 00 +31.6 24.9 +24.5 +1.3 ECU. 2.8 11.45 3796 +8.4 3.3 103 40 00 +31.3 25.3 +23.9 +1.5 ECU. 2.9 12.21 3858 +8.6 3.4 102 50 00 +31.8 26.4 +23.5 +1.1 ECU. 2.9 12.52 3858 +9.2 3.4 103 50 00 +31.5 25.0 +22.5 +0.9 ECU. 2.9 12.49 3921 +9.6 3.5 102 50 00 +31.7 28.0 +22.0 +0.0 ECU. 2.9 12.34 3926 +10.2 3.6 102 50 00 +32.1 29.8 +21.4 +0.0 ECU. 3.0 12.30 4030 +10.4 3.5 102 50 00 +32.0 29.7 +21.5 +0.5 ECU. 2.9 12.06 4060 +10.4 3.6 102 50 00 +32.0 29.8 +21.8 +0.4 ECU. 3.0 11.80 4040 +10.6 3.6 102 50 00 +31.6 33.5 +21.2 +0.5 ECU. 3.0 11.68 4177 +10.8 3.6 102 60 00 +31.6 33.1 +20.8 -0.8 ECU. 3.0 11.61 4257 +11.5 3.7 102 60 00 +31.2 35.3 +19.9 -1.5 ECU. 3.0 11.56 4240 +12.1 3.7 102 60 00 +31.5 39.7 +19.3 -0.9 ECU. 3.0 11.53 4317 +12.9 3.7 101 70 00 +29.4 40.7 +18.5 -0.2 ECU. 3.1 11.49 4268 +13.5 3.9 102 70 00 +28.4 40.7 +17.9 -0.1 ECU. 3.2 11.37 4420 +13.9 3.9 101 70 00 +27.0 46.2 +17.7 -0.3 ECU. 3.2 11.23 4385 +14.5 4.0 102 70 00 +26.3 46.9 +16.1 -0.4 ECU. 3.2 11.12 4510 +15.1 3.9 102 80 00 +25.5 47.3 +15.6 -1.0 ECU. 3.2 10.93 4566 +15.9 3.9 102 80 00 +26.5 48.7 +15.5 -1.0 ECU. 3.2 10.83 4610 +16.4 4.0 102 80 00 +25.4 47.1 +15.6 -1.3 ECU. 3.1 10.89 4597 +16.6 3.9 101 80 00 +26.2 47.9 +15.7 -1.6 ECU. 3.2 10.96 4708 +16.4 3.9 102 80 00 +25.7 46.1 +16.1 -1.4 ECU. 3.2 10.96 4649 +16.4 4.0 101 80 00 +26.1 49.4 +16.0 -1.7 ECU. 3.2 10.89 4728 +16.1 4.0 102 80 00 +26.2 53.4 +16.0 -2.0 ECU. 3.2 10.90 4789 +16.4 4.0 102 80 00 +25.5 46.0 +16.3 -1.9 ECU. 3.1 10.96 4816 +17.2 4.0 102 90 00 +26.6 49.4 +15.9 -1.3 ECU. 3.2 10.89 4852 +17.2 4.1 102 80 00 +26.9 58.1 +16.1 -1.3 ECU. 3.3 10.86 4952 +17.2 4.1 102 80 00 +27.7 56.4 +18.0 -1.3 ECU. 3.2 10.80 4916 +16.6 4.2 102 80 00 +27.7 53.7 +18.9 -0.9 ECU. 3.4 10.76 5232 +15.7 4.2 102 70 00 +28.5 54.6 +20.4 -0.8 ECU. 3.4 10.76 5065 +15.5 4.0 101 70 00 +28.0 55.0 +19.9 -0.6 ECU. 3.4 10.73 5216 +15.7 4.1 101 80 00 +30.7 51.5 +19.1 -1.5 ECU. 3.4 10.80 5324 +16.4 4.1 101 80 00 +31.0 50.6 +19.2 -2.1 ECU. 3.4 11.02 5257 +16.4 4.1 101 80 00 +31.3 50.3 +19.6 -2.1 ECU. 3.3 11.33 5184 +16.1 4.0 101 70 00 +31.6 50.3 +20.6 -1.3 ECU. 3.4 11.49 5324 +15.1 4.0 102 70 00 +32.1 51.1 +20.7 -1.3 ECU. 3.3 11.48 5464 +14.3 4.1 102 70 00 +31.8 51.4 +20.9 -1.4 ECU. 3.4 11.42 5482 +14.1 4.1 102 70 00 +31.4 51.5 +21.0 -1.8 ECU. 3.4 11.42 5537 +13.9 4.1 102 70 00 +32.1 53.8 +21.0 -1.8 ECU. 3.4 11.42 5464 +14.1 4.2 101 70 00 +32.1 51.7 +21.0 -1.5 ECU. 3.4 11.43 5611 +14.3 4.1 101 70 00 +32.2 50.9 +21.0 -1.5 ECU. 3.5 11.37 5537 +14.5 4.1 102 70 00 +32.8 53.9 +21.0 -1.5 ECU. 3.4 11.30 5767 +14.9 4.2 101 70 00 +33.0 59.1 +21.1 -1.7 ECU. 3.4 11.27 5747 +15.1 4.1 102 70 00 +33.5 56.7 +21.1 -1.7 ECU. 3.4 11.17 5757 +14.7 4.3 101 70 00 +33.2 58.2 +21.4 -1.9 ECU. 3.4 11.05 5827 +14.1 4.1 101 70 00 +33.5 60.6 +21.5 -1.7 ECU. 3.4 10.95 5817 +13.5 4.2 102 60 00 +33.7 50.8 +21.7 -1.8 ECU. 3.3 10.93 6006 +13.3 4.1 101 70 00 +34.1 56.1 +21.2 -1.6 ECU. 3.5 10.96 6093 +13.7 4.0 87 70 00 +37.5 53.5 +21.7 -1.6 ECU. 2.9 10.95 5630 +9.4 3.7 0 30 00 +8.9 38.8 ECU. -0.4 ECU. 2.9 11.27 5184 +3.9 3.4 0 10 00 +9.0 26.2 ECU. -0.9 ECU. 2.6 12.68 4714 -2.2 3.1 0 10 00 +8.9 19.6 ECU. +0.4 ECU. 2.6 12.56 4380 -8.3 2.8 0 00 00 +8.9 31.5 ECU. +10.0 ECU. 2.5 11.28 4115 -9.6 2.6 0 00 00 +11.1 31.5 ECU. +10.9 ECU. 2.4 11.33 3770 -10.0 2.5 0 00 00 +11.3 31.5 ECU. +11.0 ECU. 2.0 11.89 3439 -10.0 2.4 0 00 00 +11.4 31.5 ECU. +11.0 ECU. 2.1 13.06 3147 -10.4 2.1 0 00 00 +11.7 31.5 ECU. +11.0 ECU. 2.0 17.15 2903 -10.6 2.0 0 00 00 +11.9 31.5 ECU. +11.0 ECU. 2.0 >25:1 |
#5 |
Member#: 81123
Vehicle:2002 2.5 WRX BY RIP 02' 2.5WRX PSM |
Post logs using copy and paste as normal, but highlight and use the Wrap Code Tags around icon (#) - like this:
Code:
3703 +4.5 3.2 82 30 00 +32.1 22.5 +27.3 +1.4 ECU. 2.8 12.86 3716 +4.7 3.2 82 30 00 +32.2 22.3 +27.3 +2.8 ECU. 2.8 12.86 3822 +5.1 3.2 82 30 00 +31.7 21.6 +26.7 +2.0 ECU. 2.8 12.93 3930 +5.5 3.3 82 30 00 +31.4 24.0 +26.3 +1.9 ECU. 2.9 12.99 3972 +5.9 3.4 87 30 00 +31.3 26.1 +26.1 +1.4 ECU. 2.9 12.81 4135 +6.4 3.4 95 40 00 +31.1 25.7 +25.8 +0.4 ECU. 2.9 12.46 4135 +7.0 3.6 96 40 00 +32.0 29.8 +24.5 +0.4 ECU. 2.9 12.17 4251 +7.4 3.5 96 40 00 +32.2 34.5 +23.5 +0.2 ECU. 3.0 11.81 4432 +8.2 3.6 95 50 00 +32.4 36.9 +22.8 -0.3 ECU. 3.1 11.58 4432 +9.2 3.9 92 50 00 +29.6 38.9 +22.2 -0.5 ECU. 3.1 11.27 4553 +10.0 3.8 92 60 00 +29.0 48.2 +22.1 -1.5 ECU. 3.2 11.02 4714 +11.5 3.9 92 60 00 +27.9 44.2 +20.3 -0.4 ECU. 3.4 10.89 4741 +12.7 4.0 91 70 00 +26.1 50.2 +19.6 -1.6 ECU. 3.3 10.67 4894 +13.7 4.0 81 70 00 +26.9 56.5 +19.7 -1.2 ECU. 3.2 10.52 5065 +14.9 4.1 64 80 00 +27.7 54.2 +19.5 -1.1 ECU. 3.4 10.48 5096 +14.9 4.1 64 70 00 +31.1 51.0 +19.5 -0.8 ECU. 3.3 10.65 5257 +13.9 3.9 38 60 00 +31.3 27.1 +21.0 -1.0 ECU. 2.1 10.93 4901 +9.0 3.6 0 20 00 +8.9 34.1 ECU. +0.1 ECU. 2.9 11.33 4997 +5.1 3.6 98 10 00 +26.3 32.5 +26.1 -0.9 ECU. 3.1 12.59 3683 +3.5 3.3 102 30 00 +30.8 24.2 +27.9 +2.5 ECU. 2.9 12.56 3813 +3.1 3.3 103 40 00 +31.9 24.7 +25.0 +0.7 ECU. 2.8 11.27 3749 +6.4 3.4 102 40 00 +31.6 24.9 +24.5 +1.3 ECU. 2.8 11.45 3796 +8.4 3.3 103 40 00 +31.3 25.3 +23.9 +1.5 ECU. 2.9 12.21 3858 +8.6 3.4 102 50 00 +31.8 26.4 +23.5 +1.1 ECU. 2.9 12.52 3858 +9.2 3.4 103 50 00 +31.5 25.0 +22.5 +0.9 ECU. 2.9 12.49 3921 +9.6 3.5 102 50 00 +31.7 28.0 +22.0 +0.0 ECU. 2.9 12.34 3926 +10.2 3.6 102 50 00 +32.1 29.8 +21.4 +0.0 ECU. 3.0 12.30 4030 +10.4 3.5 102 50 00 +32.0 29.7 +21.5 +0.5 ECU. 2.9 12.06 4060 +10.4 3.6 102 50 00 +32.0 29.8 +21.8 +0.4 ECU. 3.0 11.80 4040 +10.6 3.6 102 50 00 +31.6 33.5 +21.2 +0.5 ECU. 3.0 11.68 4177 +10.8 3.6 102 60 00 +31.6 33.1 +20.8 -0.8 ECU. 3.0 11.61 4257 +11.5 3.7 102 60 00 +31.2 35.3 +19.9 -1.5 ECU. 3.0 11.56 4240 +12.1 3.7 102 60 00 +31.5 39.7 +19.3 -0.9 ECU. 3.0 11.53 4317 +12.9 3.7 101 70 00 +29.4 40.7 +18.5 -0.2 ECU. 3.1 11.49 4268 +13.5 3.9 102 70 00 +28.4 40.7 +17.9 -0.1 ECU. 3.2 11.37 4420 +13.9 3.9 101 70 00 +27.0 46.2 +17.7 -0.3 ECU. 3.2 11.23 4385 +14.5 4.0 102 70 00 +26.3 46.9 +16.1 -0.4 ECU. 3.2 11.12 4510 +15.1 3.9 102 80 00 +25.5 47.3 +15.6 -1.0 ECU. 3.2 10.93 4566 +15.9 3.9 102 80 00 +26.5 48.7 +15.5 -1.0 ECU. 3.2 10.83 4610 +16.4 4.0 102 80 00 +25.4 47.1 +15.6 -1.3 ECU. 3.1 10.89 4597 +16.6 3.9 101 80 00 +26.2 47.9 +15.7 -1.6 ECU. 3.2 10.96 4708 +16.4 3.9 102 80 00 +25.7 46.1 +16.1 -1.4 ECU. 3.2 10.96 4649 +16.4 4.0 101 80 00 +26.1 49.4 +16.0 -1.7 ECU. 3.2 10.89 4728 +16.1 4.0 102 80 00 +26.2 53.4 +16.0 -2.0 ECU. 3.2 10.90 4789 +16.4 4.0 102 80 00 +25.5 46.0 +16.3 -1.9 ECU. 3.1 10.96 4816 +17.2 4.0 102 90 00 +26.6 49.4 +15.9 -1.3 ECU. 3.2 10.89 4852 +17.2 4.1 102 80 00 +26.9 58.1 +16.1 -1.3 ECU. 3.3 10.86 4952 +17.2 4.1 102 80 00 +27.7 56.4 +18.0 -1.3 ECU. 3.2 10.80 4916 +16.6 4.2 102 80 00 +27.7 53.7 +18.9 -0.9 ECU. 3.4 10.76 5232 +15.7 4.2 102 70 00 +28.5 54.6 +20.4 -0.8 ECU. 3.4 10.76 5065 +15.5 4.0 101 70 00 +28.0 55.0 +19.9 -0.6 ECU. 3.4 10.73 5216 +15.7 4.1 101 80 00 +30.7 51.5 +19.1 -1.5 ECU. 3.4 10.80 5324 +16.4 4.1 101 80 00 +31.0 50.6 +19.2 -2.1 ECU. 3.4 11.02 5257 +16.4 4.1 101 80 00 +31.3 50.3 +19.6 -2.1 ECU. 3.3 11.33 5184 +16.1 4.0 101 70 00 +31.6 50.3 +20.6 -1.3 ECU. 3.4 11.49 5324 +15.1 4.0 102 70 00 +32.1 51.1 +20.7 -1.3 ECU. 3.3 11.48 5464 +14.3 4.1 102 70 00 +31.8 51.4 +20.9 -1.4 ECU. 3.4 11.42 5482 +14.1 4.1 102 70 00 +31.4 51.5 +21.0 -1.8 ECU. 3.4 11.42 5537 +13.9 4.1 102 70 00 +32.1 53.8 +21.0 -1.8 ECU. 3.4 11.42 5464 +14.1 4.2 101 70 00 +32.1 51.7 +21.0 -1.5 ECU. 3.4 11.43 5611 +14.3 4.1 101 70 00 +32.2 50.9 +21.0 -1.5 ECU. 3.5 11.37 5537 +14.5 4.1 102 70 00 +32.8 53.9 +21.0 -1.5 ECU. 3.4 11.30 5767 +14.9 4.2 101 70 00 +33.0 59.1 +21.1 -1.7 ECU. 3.4 11.27 5747 +15.1 4.1 102 70 00 +33.5 56.7 +21.1 -1.7 ECU. 3.4 11.17 5757 +14.7 4.3 101 70 00 +33.2 58.2 +21.4 -1.9 ECU. 3.4 11.05 5827 +14.1 4.1 101 70 00 +33.5 60.6 +21.5 -1.7 ECU. 3.4 10.95 5817 +13.5 4.2 102 60 00 +33.7 50.8 +21.7 -1.8 ECU. 3.3 10.93 6006 +13.3 4.1 101 70 00 +34.1 56.1 +21.2 -1.6 ECU. 3.5 10.96 6093 +13.7 4.0 87 70 00 +37.5 53.5 +21.7 -1.6 ECU. 2.9 10.95 5630 +9.4 3.7 0 30 00 +8.9 38.8 ECU. -0.4 ECU. 2.9 11.27 5184 +3.9 3.4 0 10 00 +9.0 26.2 ECU. -0.9 ECU. 2.6 12.68 4714 -2.2 3.1 0 10 00 +8.9 19.6 ECU. +0.4 ECU. 2.6 12.56 4380 -8.3 2.8 0 00 00 +8.9 31.5 ECU. +10.0 ECU. 2.5 11.28 4115 -9.6 2.6 0 00 00 +11.1 31.5 ECU. +10.9 ECU. 2.4 11.33 3770 -10.0 2.5 0 00 00 +11.3 31.5 ECU. +11.0 ECU. 2.0 11.89 3439 -10.0 2.4 0 00 00 +11.4 31.5 ECU. +11.0 ECU. 2.1 13.06 3147 -10.4 2.1 0 00 00 +11.7 31.5 ECU. +11.0 ECU. 2.0 17.15 2903 -10.6 2.0 0 00 00 +11.9 31.5 ECU. +11.0 ECU. 2.0 >25:1 ![]() |
#6 |
Member#: 102013
Vehicle:2002 WRX |
how do you wrap? walk through please.
1 2 3 so on I am missing something. |
#7 |
Member#: 51243
Vehicle:2004 Subaru WRX STi WRB - GTX30r |
1. You copy your log from notepad or whatever application your veiwing it in.
2. Reply to this thread. 3. Paste the log into the reply box. 4. Highlight your text of the log you just pasted into the reply box then click the number sign above ( # ) 5. Then below that list your problem and your mods. 6. Edit your profile to list your car and set your region to MAIC ![]() |
#8 |
Member#: 44351
What are your mods and what are your problems?? I know you have aftermarket injectors, but that's about all I know.
Other than that, the tune looks ok. Air/fuels are pretty consistant, but could be leaned out in the mid-range to get them into the low 11's. The timing and boost curves really have me confused. This is either a rather big turbo, or a really bad tune. But if it was a big turbo, I would think it would be able to hold boost all the way to redline. Give us more info!!! ![]() |
#9 |
Member#: 29963
Vehicle:04 sti silver |
How about doing a third or 4th gear pull from around 2K. That will let us see the whole tune.
#10 |
Member#: 205671
Vehicle:2007 wrx |
i am trying to post a log and it only shows one number in the code box, i am copying form an excel file .csv extension
| Thread Tools | |
| Display Modes | |
| Besides forums and youtub and like sites, how do you spend your time on the internet? | lag | Off-Topic | 19 | 07-30-2009 08:21 PM |
| When posting log files, how do you put a table in the post that you can scroll throug | sburck | Newbies & FAQs | 4 | 04-12-2009 10:31 PM |
| How do you wash your car during the winter? | PoweredbyJun | Mid West Subaru Owners Club Forum -- MWSOC | 63 | 01-12-2007 11:11 PM |
| how do i post decent pix on the forum? | kneedragger | Bay Area Impreza Club Forum -- BAIC | 2 | 06-03-2001 03:07 PM |
| How do you raise boost levels on the WRX? | mastervic27 | Factory 2.0L Turbo Powertrain | 12 | 04-02-2001 06:04 AM |
