Old 10-05-2001, 11:58 PM   #1
astrocreep
Member#: 10931
1996 honda
white
Default What does a blow-off valve
I guess the title is pretty self-explaining. Any info would help. All i know is that it is apart of the intake manifold i guess?
astrocreep is offline   Reply With Quote
Old 10-06-2001, 02:24 AM   #2
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
A blow-off valve vents excess pressure from the intake tract to prevent it from damaging the turbo. The surge of air associated with the throttle snapping shut when you shift would normally force a lot of air back onto the compressor blades.
Ben
bsquare is offline   Reply With Quote
Old 10-06-2001, 02:42 AM   #3
ninetalesnwf
Member#: 3739
85 R30 skylineGT-T
Red/black
amen to that brother
ninetalesnwf is offline   Reply With Quote
Old 10-06-2001, 03:57 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
perfect explanation
Old 10-06-2001, 12:19 PM   #5
astrocreep
Member#: 10931
1996 honda
white
Hey it all makes sense now, the meaning of life, why they give you 8 hot dog buns when hot dogs are sold in packs of 10. Seriously though thanks for the info much thanks
Old 10-07-2001, 02:31 AM   #6
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
The best explanation of wastegates and blow off valves Iíve seen in print has to be in the July 2001 SCC issue as a part of the Suck, Squish, Bang, Blow articles. Grab a copy of that if you can, it explains wastegates too
Really_Soaked is offline   Reply With Quote
Old 10-07-2001, 03:15 PM   #7
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
what's the downside to blowoff valves??? i heard they can also do the opposite and hurt your turbo. whats the chance of that happening
Penguinking is offline   Reply With Quote
Old 10-07-2001, 03:28 PM   #8
supermarkus
Member#: 6971
2008 WRX STi
SSM
They can only hurt your turbo if they dont work. Like if they are stuck or you have the wrong spring in the valve. A really stiff spring will let more pressure build before the valve pops open.
supermarkus is offline   Reply With Quote
Old 10-07-2001, 07:25 PM   #9
Subies
Member#: 2543
2002 wrx
Is blow off valve the same as a by pass valve? What's the difference?
Subies is offline   Reply With Quote
Old 10-07-2001, 09:20 PM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
subies-
theoretically yes but work in different ways depending upon the system.
jeremy
Old 10-07-2001, 09:35 PM   #11
bsquare
Member#: 1911
2000 Impreza 2.5RS
A blow-off valve is not capable of damaging your turbo unless it fails at the wrong time (meaning when it is needed and you are running a ton of boost). There can be problems with atmospheric venting BOVs and certain air flow sensors which get confused by the sudden change in pressure, but this doesn't really hurt anything. Recirculating valves (which pump the air back into the intake tract on the other side of the turbo) will not cause this problem. Also, recirculating valves make a lot less noise (a very good thing since I find loud BOVs really annoying).
I'm not sure what you mean by a bypass valve, but if it is a pop off valve, the idea is to act as a backup for a wastegate which is not working correctly. If the wastegate fails to open or can't vent enough exhaust, the turbos will make excess boost (called creeping or spiking). A pop off valve is generally a purely mechanical device (meaning no solenoid), which vents excess pressure in the intake tract. So, while a BOC only vents when there is the surge associated with the throttle closing, the POV will vent, no matter what, once the pressure hits a certain level. For example, if you are running 10 psi and your engine will die a horrible death if you get to 14psi, you could run a POV with a spring set to 27psi (14.7psi atmospheric + 12.3psi of boost) to vent if the boost ever crept or spiked over 12.3psi.
Ben
Old 10-07-2001, 11:34 PM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
bypass valves are used in factory supercharged setup...perform the same function just designed in little bit of a different way.
Jeremy
Old 10-08-2001, 06:05 PM   #13
the Dabbler
Member#: 4540
MY00 2.5RS Sedan
Abnormally Aspirated
I've heard the term "bypass valve" used synonymously with "blow off valve", especially in systems where the valve in question is plumbed back to the intake (i.e., not vented to atmosphere). I think either is acceptable in polite conversation, though one or the other might be more strictly correct.
the Dabbler is offline   Reply With Quote
Old 01-16-2006, 10:42 PM   #14
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Peaty is offline   Reply With Quote
Old 01-18-2006, 04:38 PM   #15
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Peaty man, with all the BOV threads, why did you bump a 4.5 y/o thread?
Old 01-18-2006, 04:48 PM   #16
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
At least I posted some info and not another question
GFB Blow Off Valve $100 04GT35RSTi Engine/Power/Exhaust 3 06-18-2010 07:37 PM
GFB Blow off valve Project Blackhawk Private 'Wanted' Classifieds 0 06-01-2010 08:20 PM
What type of Blow Off Valve? dayydreaming89 Newbies & FAQs 39 01-31-2008 03:50 PM
what type of blow off valve makes the ZZ ZZ ZZ sound wrb2006sti General Community 7 10-26-2006 12:49 AM
What is a blow off valve? m-keith Newbies & FAQs 7 09-27-2001 11:02 AM
