Old 04-26-2006, 01:45 PM   #1
whpotter
Member#: 45302
2003 WRX Wagon
Midnight Black Pearl
Default Urgent help needed on tranny question
The 5-spd in my '00 GT Ltd is shot. There is a guy relatively local to me that has a tranny for an '01 Forester that he is selling. The official charts and the Subaru shop say that the Forester tranny will not fit on the '00 GT Ltd.
I see posts around NASIOC about people trading trannys so what could be or is preventing an '01 Forester tranny from being dropped into my '00 GT Ltd?
whpotter is offline   Reply With Quote
Old 04-26-2006, 02:09 PM   #2
DLC
out back
Member#: 1964
01 BH
Blue/Bronze
The Forester might also be 4.44 gear ratio, which would necessitate the replacement of your rear differential as well.
As for it fitting, I don't know whether or not it will swap, but I'd be very surprised if it wouldn't bolt up just fine.
DLC is offline   Reply With Quote
Old 04-26-2006, 02:20 PM   #3
Rice & Gravy
Member#: 39569
09 Acura TSX 6spd
doodoo brown
You need a 4.11 final ratio to work without further parts beyond the tranny. It will bolt in though. I just went through this myself and found a used 01 RS tranny.
Rice & Gravy is online now   Reply With Quote
Old 04-26-2006, 02:25 PM   #4
whpotter
Member#: 45302
2003 WRX Wagon
Gray,
Were there any tricks involved in dropping it in (ie. any plug/wiring/bolt adapters)? Was it is as simple as just bolting it on?
Thanks!!!
Old 04-26-2006, 02:37 PM   #5
Rice & Gravy
Member#: 39569
09 Acura TSX 6spd
doodoo brown
It was not a job I had the time or the ability to do myself so I had someone else do it. As far as I could tell it is just taking the old one out and putting the new on in. Sorry I can't be of more help. I also had the flywheel resurfaced and a new clutch put in at the same time.
Old 04-27-2006, 01:41 PM   #6
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
why would you want a forester trans? Is it stronger or has a higher highway cruising speed? And yes, it should just bolt up as far as fitment is concerned. The final gearing and speedo are things I can't answer...
janikphoto is offline   Reply With Quote
urgent help needed on install of factory sub mtbmech Car Audio, Video & Security 31 12-15-2011 01:19 PM
urgent help needed....torque values on struts? JDMFLCL Brakes, Steering & Suspension 4 09-07-2009 05:21 PM
tranny removal....urgent help needed bobbarob Transmission (AT/MT) & Driveline 5 05-08-2004 10:13 PM
Urgent help needed on my non-subaru car dunk Electrical & Lighting 3 03-12-2003 03:29 PM
Urgent Help Needed on Truck Flood ! Im'Pat'za Interior & Exterior Modification 3 04-01-2001 10:23 PM
Message Board Statistics All times are GMT -4. The time now is 09:12 PM.
