Old 10-06-2001, 02:29 AM   #1
SoCo
Member#: 63
Default Opinion needed for spending $2500
I have a 98 2.5rs dohc...and have $2500 to burn....i'm already running a Nitrous express 50 shot...but want something thats constantly always there....i was thinking of the following....
Force Induction
1. Ludespeed Stage 1 kit for $2400
2. Asr Stage 1 kit...?
NA
3. Cobb Tuning Cams-$800 for two cams..
What other options do i have???
thanks in advance...SoCo
SoCo is offline   Reply With Quote
Old 10-06-2001, 03:23 AM   #2
AZ-GT
Member#: 192
2011 WRX
WR Blue
The DOHC engine in the 98's don't take well to forced induction.
AZ-GT is offline   Reply With Quote
Old 10-06-2001, 04:00 AM   #3
Andrew
Member#: 1170
2005 STi
save up some more dollars and go with shiv's kit.
Andrew is offline   Reply With Quote
Old 10-06-2001, 04:02 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
i can give ya a list of stuff ya can buy for me
J/K
Jeremy
Old 10-06-2001, 05:35 AM   #5
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
$2500 will not get you a reliable turbo setup. What about sending your heads to Cobb for a thorough working over? In combination with their spicy cams you will probably be quite pleased. I assume you already have a fuel computer since you have nitrous. If not, you'll need one to properly adjust fuel delivery with the improved air flow.
Ben
bsquare is offline   Reply With Quote
Old 10-06-2001, 11:21 AM   #6
Charge
Member#: 3313
If turbo is the long range plan, why not a TEC II? Then you can just tune it now, get used to it, add boost later. That'll give you time to scrape together cash and knowledge for everything else you'll need.
Just my .02
Neil
Charge is offline   Reply With Quote
Old 10-06-2001, 12:22 PM   #7
kaos200
Member#: 2692
I agree, get an aftermarket ecu, doesnt have to be a Tec, although that is a nice option. A Wolf runs about a 1,000 less in the end, and I believe Haltechs are cheaper too.
Also dont forget to get some gauges
Oil Pressure,
EGT
Boost (if you know youre going FI)
or A/F instead of boost?
kaos200 is offline   Reply With Quote
opinions needed for Make it yourself tr/ashtray/ swift2fly Interior & Exterior Modification 0 06-08-2006 12:58 AM
Opinions needed for springs and sway bars... the_poser Brakes, Steering & Suspension 13 03-30-2006 07:27 PM
opinion needed for up pipe Lordhowe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-30-2005 11:23 PM
opinions needed for Yokohama AVS Intermediate. Dealer Xing Brakes, Steering & Suspension 10 05-09-2002 09:13 PM
(more) opinions needed for summer tires cj917 Brakes, Steering & Suspension 15 02-16-2001 01:07 PM
