Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Old 04-26-2006, 05:32 PM   #1
ROC pit-bull
Member#: 67814
1995 legacy L
white
Default Q. Bout Crankshaft
I need to know if a crank from a NA motor can be used on a turbo engine?
also will a crank from late 90's work in a ej257 block? If anything else needs to be done please don't leave that out..
ROC pit-bull is offline   Reply With Quote
Old 04-28-2006, 11:31 AM   #2
bugeyes
Member#: 64494
2001 V7 sti
I have researched this and have spoken the mechanic guys at MRT and Rigoli. Yes all the cranks are the same material (that includes n/a, wrx and sti). The only difference being the phase 1 and phase 2 types where the thrust journal is different and rod journal diameter.
And to add, here in Aust we didnt get the 2.5L sti till this year so we were running 2.5 n/a engines cranks and blocks for turbo builds.
Your question regarding late 90's crank in a ej257 should be ok. Of the top of my head they changed from phase 1 to phase 2 around '96/'97.
bugeyes is offline   Reply With Quote
Old 04-30-2006, 07:11 PM   #3
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
DOHC 2.5l NA engine Phase I Has unique rods.
SOHC 2.5l NA engine Phase II
The change over happened around 98-99 but there are some bastards out there.
Scoobie Steve is offline   Reply With Quote
Old 05-01-2006, 12:13 PM   #4
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Phase I EJ25 crank has slightly smaller big end bores. Pauter Rods website show the correct diameters:
http://www.pauter.com/subaru.htm
After talking with Crawford Performance they made it sound like all Phase I cranks will fit Phase I blocks.
As well Phase II cranks will fit Phase II block but require machining.
However Phase I cranks will will not fit Phase II blocks.
MY99 2.5GT is offline   Reply With Quote
Old 05-01-2006, 09:36 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
whoa whoa whoa.....then why can you put a phase I EJ25 crank into a EJ22 block to stroke it......or is it that the EJ22 block is also phase I?
~Josh~
Old 05-01-2006, 10:27 PM   #6
Scoobie Steve
Member#: 2289
1998 11.87@112mph
EJ22t block is 1994 era...Phase I
Did the "game" die? If you know what I'm talkin bout, you know what I'm talking bout Asinine Off-Topic 34 01-12-2006 10:40 AM
('93-'01) Got Bored.. So i wrote a Rap bout Subaru .. DarkLite Impreza Forum 34 04-24-2001 04:13 PM
wrx rear speakers 4" into 6" ?? how bout rear deck 6x9's? LttLDGN Car Audio, Video & Security 0 04-17-2001 11:43 PM
How bout this for wild.... ExchangeGuy Texas Impreza Club Forum -- TXIC 19 03-21-2001 01:40 PM
hear bout the beat down! chillN 2.5RS Hawaii Impreza Club Forum -- HIIC 6 11-22-2000 10:15 AM
