Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 04-27-2006, 01:39 AM   #1
homiusang
Member#: 88836
06 Evo IX
GG
Default What rear camber to run on stock STi?
I had an alignment done couple weeks ago with my stock 04 STI and I told them to maximize the negative cambers and zero toe all around. The guys were able to get -.6 up front for cambers and ~-1.2 on the back.
I know the front negative camber will enhance handling, but what about the rear camber? Do you also max it out or just leave it?
homiusang is offline   Reply With Quote
Old 04-27-2006, 09:28 AM   #2
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
I'll leave it to the autocross and track guys to tell you what setting will give you the extra .002% traction, but I can tell you that decreasing rear negative camber to around -1 or even a little less improves feel and turn-in quite a bit. Especially if you have so little front negative camber.
Jon Bogert is offline   Reply With Quote
Old 04-27-2006, 09:37 AM   #3
salisburyv
Member#: 41863
2015 STI
Crystal Black Silica
there is a safe range on the negative camber. For daily driving you really dont want more than -1.5 deg. camber. the rear range (stock) is .2/ -1.6. . I have -1.2 front. and - 1.0 rear. Too much will wear the tires on the inside edge. Bring it to a reputable alignment shop and tell them what you want specifically. They should be able to come pretty close. But make sure they know what they are doing. As alignments are one of the cheapest and best ways to make your car handle good. Its also one area where, if its bad....it can really mess things up. Ask them for a printout of the alignment specs.
salisburyv is offline   Reply With Quote
Old 04-27-2006, 10:16 AM   #4
tuskenraider
Member#: 65699
15 WRX
WR Blue
The guys were able to get -.6 up front for cambers and ~-1.2 on the back. I know the front negative camber will enhance handling, but what about the rear camber? Do you also max it out or just leave it?
They clearly didn't try very hard up front. They should be able to get at least -1.0 up front, just by making sure the camber bolt is in max position and loosening the strut mount bolts from behind the wheel with weight of the car on them on the rack. As far as rear camber, the more you have, the less rotation you'll get from the rear end during corning because grip will be increased. Most people I see autox'ing like around -1.0 to help get a little "oversteer" that is lacking with the stock suspension setup. Braking ability will decrease, but with the typical <-1.5 Subies have in the rear, this isn't really noticeable. Going with less of course will do the opposite. Even though there are no stock rear camber bolts, some adjustment is possible by manipulating the slop in the stock rear strut mounting points. Again, loosening the bolts with the weight on the car will maximize rear camber. Jacking the car up and pulling the top of the wheel out, will minimize it. Set toe to 0 and tire wear will not be an issue with stock camber adjustment ability.
tuskenraider is offline   Reply With Quote
Old 04-28-2006, 10:55 AM   #5
homiusang
Member#: 88836
06 Evo IX
GG
some great info here, thanks alot!
Yeah I think the guy didnt' try very hard to max out the front camber because right upon they take the car in, I said they should *at least* get -1 deg. up front. The alignment is done at a very reputable shop where most autox'ers go to, so I guess they know what they are doing. I had the alignment done a day before my last track day and the improvement was very noticiable, especially for the money spent.
Whats psi are you running on stock turbo killichnakropf Newbies & FAQs 7 05-27-2010 01:13 PM
What pistons/compression to run on my STi? colbs19 Newbies & FAQs 8 10-12-2009 12:28 AM
what tire pressure is everyone running on stock sti potenza's STI1981 Tire & Wheel 7 08-26-2005 03:31 PM
what tire pressure to run on a GC8? ommmjido Tire & Wheel 2 09-08-2003 10:35 PM
what size wastegate to run on my turbo? STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-31-2002 01:46 AM
