Old 04-17-2006, 01:56 PM   #1
Rayman21287
Member#: 105125
2005 WRX/ 2008
Stage Pi/MercedesC300 4MA
Default Manual boost controller with stock turbo?
Would it make a diff. If I put a manual boost controller in my car even though it still has the stock turbo?
Would you be able to simply raise the amount of boost to maybe 15-17 PSI?
Rayman21287 is offline   Reply With Quote
Old 04-17-2006, 01:59 PM   #2
dvang
Member#: 84188
05 legacy
caravan full of kids now
yes and yes
should you ???
dvang is offline   Reply With Quote
Old 04-17-2006, 02:03 PM   #3
Rayman21287
Member#: 105125
2005 WRX/ 2008
IDK should I?
Old 04-17-2006, 02:05 PM   #4
WRX-ERROR
Member#: 83211
2002 WRX - stg4
I heard 04/05 WRX's don't take well to MBC. Not sure what the issue is but you might want to research 1st.
WRX-ERROR is offline   Reply With Quote
Old 04-17-2006, 02:07 PM   #5
Crawdads
Member#: 30907
SWP GDB-G
*sigh*
bonus points if you have the stock up pipe and a BOV.
Crawdads is offline   Reply With Quote
Old 04-17-2006, 02:11 PM   #6
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
Originally Posted by Crawdads
*sigh*
Lol...
MBC is just a cheap way of raising boost without EM
It will not mix well with the OL/CL transition on your 05
So in other words...I wouldnt try it
Gfunk720 is offline   Reply With Quote
Old 04-17-2006, 02:14 PM   #7
LastResort
Member#: 99289
If you are unable to figure out the search button on this site, I am going to say that you do not have a expertise to properly execute an MBC without grenading your motor.
LastResort is offline   Reply With Quote
Old 04-17-2006, 02:29 PM   #8
Rayman21287
Member#: 105125
2005 WRX/ 2008
Do you think the turbo guru's at TurboXS could make it happen?
Old 04-17-2006, 02:34 PM   #9
Gfunk720
Member#: 42549
E92 M3 M\\\
Ok...So you obviously havent learned to use the search function. These are all questions that have been answered time and time again...
Forget the MBC and get a AP or Utec to raise boost safely
Old 04-17-2006, 02:36 PM   #10
Crawdads
Member#: 30907
SWP GDB-G
your car barely gives itself enough fuel STOCK....a MBC tuned by a n00b will kill the car.
Old 04-17-2006, 02:53 PM   #11
dirtymatt
Member#: 110461
I have a txs mbc and run turned where it will spike 17 psi then at higher rpms it will lower to 15 psi it runs perfect. no problems, you will find though by shifting to a higher gear then your need and giving it more boost when it will hit fuel cut. example: driving 40 mph while in 5th gear and flooring it will only result in higher boost then your ecu will throw a cel which is the fuel cut.
overall it helps with turbo lag ALOT, just dont get to big headed and turn the nozzle.
dirtymatt is offline   Reply With Quote
Old 04-17-2006, 03:08 PM   #12
Crawdads
Member#: 30907
SWP GDB-G
What kind of A/F ratios are you seeing? EGTs?
Old 04-17-2006, 03:20 PM   #13
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
.....deeeeeeeeewwwwwwwwd.....it is only time until ya blow it up doin that....and you WILL blow it up, no doubt
Old 04-17-2006, 03:22 PM   #14
Uncle Scotty
OK buy Nates beans
.....deeeeeeeeeeeeeeeeeeeeeeeeeeeeewwwwwwwwwwwwwww wwwwwwd......
READ ALL THE FORUM FAQ'S before ya do/buy/dream/jizz ANYTHING.....or ya likely gonna be
Old 04-17-2006, 03:24 PM   #15
djplayboy
Member#: 72933
MY02 WRX Wagon
the em on the 04/05s is diff frm the 02/03 DO NOT put a MBC on a 04/05 if you had an 02/03 sure put one on if you know what your doing and have the supporting mods and dont run 17psi constantly on the stock turbo it will die quickly
btw yes i run a mbc, yes i have all the supporting mods excpt em(shame on me) no i dont run it at max boost all the time i save that for track day
djplayboy is offline   Reply With Quote
Old 04-17-2006, 04:16 PM   #16
jsalassi
Member#: 61261
04 WRX Wagon
Wingless+Blue+Stg2
i think that you should save your time money and risk and get some EM and exhaust.
jsalassi is offline   Reply With Quote
Old 04-17-2006, 04:52 PM   #17
xplane
Member#: 66152
04 wrx sti
blue
OL/CL transision does not have any problems in the 05, it was the 04. MBC in a stock car is a bad idea plus IIRC the maximum boost out of a td04 while retaining efficiency and reliability is 15psi your better off doing the 3/16 mod, I did it when I had only a TBE and it raised my boost from 13.5 to 15, then it went broke after 10k miles....
xplane is offline   Reply With Quote
Old 04-17-2006, 04:55 PM   #18
-Kevlar-
Member#: 82378
what? since when?
-Kevlar- is offline   Reply With Quote
Old 04-17-2006, 04:59 PM   #19
xplane
Member#: 66152
04 wrx sti
blue
Call cobb... they will tell you... Gruppe-S can also confirm this...Its also been posted before its only an 04 problem....
Last edited by xplane; 04-17-2006 at 05:10 PM. Reason: Ive just read some of the 05 had the same problem, but its still not as percistant as the 05, my apologies
Old 04-17-2006, 05:12 PM   #20
dirtymatt
Member#: 110461
Notice i did say i run a MBC it "SPIKES" 17 but lowers back to stock. i dont use it to raise psi just to reduce spool up time. it helped. as far as a/f still runs rich because of the SSQ BOV.
Old 04-17-2006, 05:28 PM   #21
LastResort
Member#: 99289
You realize that spiking and blowing off are two mutually exclusive events and one will not make the other richer or leaner.
Old 04-17-2006, 05:40 PM   #22
illmattic016
Member#: 86734
2002 Stage 2 WRX
spikings not a good thing and why dont you just save for a true EM system
illmattic016 is offline   Reply With Quote
Old 04-17-2006, 05:50 PM   #23
Wagun
Member#: 106433
2004 WRX wagon
So...will an '05 ECM solve this problem?
Wagun is offline   Reply With Quote
Old 04-17-2006, 05:52 PM   #24
Uncle Scotty
OK buy Nates beans
.....deeeeeeeeeeeeeeeeeeeeeewwwwwwwwwwwwwwwwwwwwd. ...ya smokin crack...LOTS and LOTS of crack if that's what ya think......ALL '04+ WRX's have the same OL/CL issue and MBC's are bad juju.
Old 04-17-2006, 05:53 PM   #25
Uncle Scotty
OK buy Nates beans
.....deeeeeeeewwwwwwwwd....he don't know jack, and NO....ya need engine management....NOT a new ECU
Do I need a manual boost control with the VF30? WildWolf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-24-2007 04:44 PM
Manual Boost Controllers on Stock WRX St3fan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 12-22-2006 03:24 AM
Manual Boost Controller with Cobb Stage 2? aakrusen Newbies & FAQs 5 05-06-2006 01:51 PM
WTT: turboxs standard manual boost controller for stock 03 EBC raglan New England Impreza Club Forum -- NESIC 0 08-08-2005 10:10 PM
Do I need a manual boost controller with these mods? SlidewaysSTi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 05-21-2004 06:37 PM
