Old 10-06-2001, 04:27 PM   #1
Boeleni
Top Scoob 003
Member#: 1812
1999 Impreza Try-R
Satin Black
Default EGT's on the Rise... ?
Hi guys. It's been pretty cold up here for the past couple of days.. and my EGT's are going up and up and up. Is this normal? When things were warmer at wide open throttle it would never go over 800 C. Now it's going 900 C and up but I shut down whenever i see it approach those numbers. Is this because my EGT probe is colder or something? HELP!
5 PSI on T3 turbo .64 trim, Intercooled, 99 using an AFC and not much else till I get a real ECU.
Boeleni is offline   Reply With Quote
Old 10-06-2001, 04:52 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
watch your fuel pressure, this is what happened to 8complex's car....#4 injector was starting to clog making the EGT's Very irratic...ended up[ full clogging under boost and detonating a piston.
Jeremy
Oh yeah you guys are prolly already runnign winter blend gas which has more ethanol in it which burns hotter.
Old 10-06-2001, 06:43 PM   #3
Boeleni
Top Scoob 003
Member#: 1812
1999 Impreza Try-R
Satin Black
Thanks.. the fuel pressure appears to be okay.. but the temps rise very quickly when I'm on the throttle.. I'll fill up today and see if there's any change. I guess if it's the injector problem I need to try some fuel injector cleaner?
Old 10-07-2001, 03:15 AM   #4
PERRIN
NASIOC Manufacturer
Member#: 6776
If you are using the stock ecu with a 2.5 engine the timing might be too high when you get to the upper boost and rpm levels. this could cause some of the heat problems,
Where do you have the EGT sensor?
You said fuel pressure isn't a problem, do you know what kind of pressure you are running? What injectors?
Let me know when you want an standalone ECU. Haltech is only $1300.
PERRIN is offline   Reply With Quote
Old 10-07-2001, 11:54 AM   #5
Boeleni
Top Scoob 003
Member#: 1812
1999 Impreza Try-R
Satin Black
I thought timing retard caused EGT's to go up?
I have the sender about an inch away from #3 outlet.
Fuel pressure when off boost is just over 40, at 5 psi it creeps up to somewhere between 50 and 60 psi.
I am running the stock injectors right now, I had 550cc's on order but I'm starting to think they will never come from this vendor.
I am considering all kinds of ECU/Injectors right now, so please e-mail me with info on what you can provide. I've looked into the Wolf 3D system, TEC II system, SDS, and Link so far. I'll do some research on Haltech today. I'm looking for a system to control boost, larger injectors, and be able to run close to 8-10psi daily on my T3 (unless it proves to be too much of a restriction).
Old 10-08-2001, 01:04 PM   #6
PERRIN
NASIOC Manufacturer
Member#: 6776
i can get you the Haltech if thats what you go with, i even have maps for them. I am making a in-car cpu that you would be able to tune while you are in the car. Its just like a laptop, but the screen will be detatched and the keyboard will be very small.
Are the 550cc injectors a side feed style?
do you know what size the stock injectors are?
Old 10-08-2001, 01:26 PM   #7
Boeleni
Top Scoob 003
Member#: 1812
1999 Impreza Try-R
Satin Black
I'm pretty sure the stock injectors are 280 cc. Not sure what the fuel rail is.
Old 10-08-2001, 07:59 PM   #8
PERRIN
NASIOC Manufacturer
Member#: 6776
i was asking because i have some 620cc side feed style injectors i will be selling soon.
knife attacks on the rise in the UK- NEED MORE GUNZ!! HighWayDrifter Off-Topic 28 07-18-2008 04:26 PM
So my friend's group is on MTV's on the rise Depeche Off-Topic 14 11-18-2007 10:32 PM
EGT's on the 1.8t smahala1286 Normally Aspirated with bolt-on Forced Induction Powertrain 9 04-23-2006 01:08 PM
Recycling, waste on the rise Layman Off-Topic 15 01-11-2006 03:57 PM
Gas prices on the rise!!! SBC2night Mid West Subaru Owners Club Forum -- MWSOC 15 09-03-2003 09:15 PM
