Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Legacy Specific Parts
Old 04-27-2006, 04:48 PM   #1
sk8erord
Member Sales Rating: (1)
Member#: 68431
2006 Legacy 2.5GT MT
Question 98 Legacy GT EJ25T swap - need hood
Any thoughts? Will a baja turbo hood work for this application? (A search indicates that it might...)
We're basically swapping a stock USDM STi EJ25 + drivetrain into a 98 legacy chassis and need a hood to work with the TMIC. We're not really interesting in going FMIC, as we don't want the lag and aren't likely to swap to a larger turbo anytime soon.
sk8erord is offline   Reply With Quote
Old 04-27-2006, 04:49 PM   #2
sk8erord
Member#: 68431
I found this on a search here: http://www.erebunicorp.com/NEW/SUBARU.HTM
But on this thread someone said it didn't fit well. But nothing has been said about this year car and this specific application.
Old 04-27-2006, 04:54 PM   #3
Bakergtt
Member#: 59207
'05 X was 98 LGTT
the stock GT hood should work
Bakergtt is offline   Reply With Quote
Old 04-27-2006, 04:57 PM   #4
sk8erord
Member#: 68431
I'll have to look again, but the small scoop a) doesn't look functional b) doesn't look like it lines up properly with the TMIC. But I'll check again when I head over to his place this week.
Old 04-27-2006, 05:05 PM   #5
skunkfifty
Member#: 73102
1998 legacy outback
white
the turbo baja hood doesnt fit right i i recall. you can make the stock hood functional but i'm not sure it flows enough air for the TMIC.
skunkfifty is offline   Reply With Quote
Old 04-27-2006, 08:04 PM   #6
Bakergtt
Member#: 59207
'05 X was 98 LGTT
The opening on the Baja isnt much more the the gt hood i thouht. anyways doesnt the baja work of the BE not BD?
Old 04-27-2006, 08:34 PM   #7
suby2low
Member#: 82633
'08 WRX STI
definately no fitting a baja hood onto a bd.
suby2low is offline   Reply With Quote
Old 04-27-2006, 09:41 PM   #8
RoundtheBend
Member Sales Rating: (47)
Member#: 5034
2004 Money Pit
silverish-mud
I have a BD hood with '02-'03 STi scoop molded in for sale. $250 + shipping.
RoundtheBend is offline   Reply With Quote
Old 04-27-2006, 10:10 PM   #9
UTCiv
Member Sales Rating: (13)
Member#: 30695
BOOM , Get her to
sew THAT!
If you are staying stock or near stock, the GT hood should work. I know Kraziken has been running his STi with a stock scoop, also xcntrk75 has been running a stock scoop with his 300whp beast. I as well am running a stock scoop, but have no real experience to back it up. We will see this summer. They may be looking for larger scoops as the power levels increase, I know the issue has been brought up on the board previously.
There is a bit of the intercooler that sticks past the front of the opening if you only remove portions of the scoop by unbolting the blockout. I want to to a little fab work right up against the edge and turn the hood down to make a seal on the intercooler, and fasten a piece in the rear and on the sides to create a seal around the face of the intercooler The stock scoop also allows for a small chimney on the one side if you should so choose to pipe to.
Either way, good luck with the swap, and have fun!
Ahh, might as well throw this in:
UTCiv is offline   Reply With Quote
Old 04-27-2006, 11:07 PM   #10
Kraziken
Member Sales Rating: (3)
Member#: 38629
1999 Legacy GT (STI)
STI I/C and motor works fine under the stock GT hood.
You can see more car pics in my thread.
http://forums.nasioc.com/forums/show...ht=project+sti
I think the cooling has been fine. I've lifted the hood, touched the intercooler after a few runs.
It could be an issue if you push more boost. I have the I/C spray that turns on after 8psi of boost currently to keep things cool.
Kraziken is offline   Reply With Quote
Old 04-28-2006, 02:28 PM   #11
sk8erord
Member#: 68431
Thanks, this saves us a lot of money.
Old 04-28-2006, 02:52 PM   #12
tecnica technician
Member#: 105442
99 Legacy gt
hey I have been thinking of doing this about how much have you spent and how difficult was the swap
tecnica technician is offline   Reply With Quote
Old 04-28-2006, 02:57 PM   #13
IronMonkeyL255
Member Sales Rating: (4)
Member#: 38120
1991 Rio Red
Legacy Turbo
I was thinking of an STI swap into my 1g legacy.
IronMonkeyL255 is offline   Reply With Quote
Old 04-28-2006, 04:01 PM   #14
Kraziken
Member#: 38629
If your talking about a USDM STI swap. (and just the engine swap, nothing else).
Motor online ranges from $3500 to $6000 for the complete engine/wiring/ecu/turbo/intercooler.
Transmission rebuild, plus heavy duty clutch $1000 to $1500. If you go with the STI 6 speed and DCCD I think I've seen these in the $4500 range.
As for difficulty. The motor will mechanically connect just fine, it's the spaghetti mess of wiring and some other minor fabrication that is involved.
UTCiv and I are the only BD legacies I know of with this engine setup. He can comment on the difficulty of the swap. Or you can search for his build/swap thread for more information.
My wife was nice enough to let me buy all the parts. If I chose to work on the car instead of my project house, I'm not sure I'd be alive right now, so I paid to have it done.
Old 04-28-2006, 04:58 PM   #15
sk8erord
Member#: 68431
My buddy got basically the full USDM STi drivetrain: Engine, tranny, axles, etc. He's doing brakes and a custom driveshaft. He also bought the car with 150,000 miles specifically for this project. He's doing the Cobb Full TBE, headers, Cobb SFI and a protune. With everything, including the car and a ProTUNE, he should come to about $18,000. I think the car was about $6-7,000 of that off ebay.
Old 04-28-2006, 06:41 PM   #16
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
I figure it'd be a bit cheaper to just buy a whole totalled car and have everything there.
That way, you could just swap over the whole STI engine wiring harness and save alot of wiring.
Old 04-28-2006, 11:19 PM   #17
sk8erord
Member#: 68431
Our next problem is deciding what to do about the dash/gauges. He has the DCCD so he'd like to use an STi gauge cluster, but we have no idea if there is anyway to make it work in the BD dash.
Old 04-29-2006, 01:25 AM   #18
Kraziken
Member#: 38629
I think UTCiv swapped the STI gauge cluster over on his BD.
Does the STI dash show something in regards to the DCCD?
The 6 speed and DCCD is on my list of "future" upgrades.
Old 04-29-2006, 09:04 AM   #19
UTCiv
Member#: 30695
BOOM , Get her to
sew THAT!
The STI cluster is doable, but its a bit of work and a lot of faith to start hacking the $350 piece. I'll take some pics today of the finished product. There are a few bugs I have yet to work out to get some lights to go out, but the DCCD, speedo. tach, illumination, oil, fuel, CEL and most of the good stuff works. I'll try and take a video today.
Kraziken, yeah it has a pretty neat display for the manual mode, and an indicator of auto/manual.
EDIT: Click here to watch Gauges-98
Old 04-29-2006, 06:52 PM   #20
Kraziken
Member#: 38629
AWESOME.
From the looks of it, the STI cluster looks maybe just a bit taller? it looks like there might be some squeezing to get it to fit, but it looks good.
Where did you mount the roller/rocker switch?
BTW, I just picked up that Legacy hood with the 03 STI hood scoop. Somehow it looks better installed on the car. Than just sitting in the shop floor.
I'll take pics as soon as it quits raining cats and dogs outside.
Old 04-29-2006, 11:03 PM   #21
UTCiv
Member#: 30695
BOOM , Get her to
sew THAT!
I definately want to see it, I bet it looks sweet! Right now I have the roller mounted on my passenger seat the Auto/Manual switch and the roller are going in the center console.
The cluster is a bit taller and the plugs extend from the top. I had to take all of the plastic and foam off of a spot dash in order to get the plug to clear.
Old 05-01-2006, 12:08 PM   #22
Kraziken
Member#: 38629
OK, we finally got some sun yesterday. Here's the pics.
Side profile
Shot next to my bro's Saabaru 92-x
From inside the cockpit, I like the significantly larger hood bulge.
Old 05-01-2006, 01:01 PM   #23
UTCiv
Member#: 30695
BOOM , Get her to
sew THAT!
I like it, looks like a good size for the car!
Old 05-01-2006, 03:37 PM   #24
Kraziken
Member#: 38629
If you look at the pic, standing almost over the hood. You'll notice that the hood is a slight different shade of white.
My brother mentioned he would have never noticed it if I didn't say anything.
I have just the rear bumper that hasn't been painted on this car. It's a bit faded from sun damage I think. I'll probably get the rear bumper, hood and my JDM mirrors (on their way) all painted at the same time.
Old 05-01-2006, 07:27 PM   #25
sk8erord
Member#: 68431
Both the scoop and the gauges look awesome. Hopefully my buddy can get them to work.
2005 WRX-98 Legacy GT wagon 5MT swap WIP iluvdrt Legacy Forum 33 07-10-2015 05:01 PM
04 WRX 5 Speed Transmission Swap To 98 Legacy GT 4EAT B2.5GT Legacy Forum 15 08-28-2012 11:32 PM
98 Legacy Outback WRX SWAP! need to sell loaded! NJ $6,500 elsanto Private Vehicle 'For Sale' Classifieds 8 04-24-2009 10:15 PM
98 Legacy Outback WRX SWAP! need to sell loaded! NJ $6,500 elsanto Tri-State Area Private Classifieds 9 04-22-2009 03:08 PM
98 Legacy GT Turbo Swap I/M Problems akbigbud907 Subaru Conversions 1 08-05-2006 10:06 AM
