Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 04-27-2006, 06:31 PM   #1
henzly23
Member#: 35286
2015 Impreza Hatch
Default Changing transmission fluid with AT WRX
I have read a number of the threads discussing changing the trans. fluid and front differential fluids. In these I have seen recommendations for how to change it as well as what type(s) of fluids are recommended.
I have been unable to find this type of information for an Automatic transmission car. I know that transmission fluids are definitely different for Autos and Manuals, but I wasn't sure what the final word on the WRX is.
I have an '03 and would like to change out the tranny and front diff. fluid but I wanted to make sure I am using the proper fluids and performing the change properly. Any help / advice would be appreciated.
Matt H
henzly23 is offline   Reply With Quote
Old 04-29-2006, 04:46 PM   #2
henzly23
Member#: 35286
2015 Impreza Hatch
no assistance on this one?
Old 05-01-2006, 06:04 PM   #3
poolumps
Member#: 97863
2005 9-2x Stage2 XX
Satin Grey
I did not do it myself (dealer did with my fluids) but did lots of reserch and I ended up using AMSOIL AT Fluid. I have actually noticed the car shift smoother.
http://www.modernoils.com/ATF_Amsoil...hetic_ATF.html
poolumps is offline   Reply With Quote
Old 05-01-2006, 09:59 PM   #4
henzly23
Member#: 35286
2015 Impreza Hatch
What is the fluid capacity? How many quarts will I need to buy?
I know the AT fluid is separate from the front differential fluid so I am sure about fluid capacities as well. I want to make sure I have enough of each before I start draining them. Any help would be appreciated as well as a possible source for this information.
Old 05-01-2006, 10:46 PM   #5
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
I have a MT so I can't help you, but your owner's manual is a GOOD source for this information.
dm
dwmoss_68 is offline   Reply With Quote
Old 05-01-2006, 11:08 PM   #6
poolumps
Member#: 97863
2005 9-2x Stage2 XX
Satin Grey
it depends on if you are doing a complete flush or not. Just a drain and refill should be about 4-5qt.
Changing transmission fluid terrenceseet Transmission (AT/MT) & Driveline 0 02-27-2006 09:29 PM
How to change transmission fluid? njskatchmo Transmission (AT/MT) & Driveline 10 02-07-2006 12:39 AM
changed transmission fluid = boost problem ric923 Service & Maintenance 2 06-28-2005 11:32 PM
How many liters do I need to change transmission fluid and what kind? SpoonTypeR Service & Maintenance 4 10-23-2004 04:16 AM
How and when do I change transmission fluid? FatJoe Transmission (AT/MT) & Driveline 2 04-22-2003 01:43 PM
