Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 04-27-2006, 07:05 PM   #1
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Black - Rotated gt3037s
Question Throttle lag
Hi guys,
I have the 2.14r10 version hydra for my impreza sti,
My problem is that when i hit the throttle, the car starts to accelerate 1 seconds later,
It is very disturbing in daily use,
How can i reduce this lag ? Is it related with the length of the silicone hose that is connected to Hydra map sensor ?
Thanks
WhiteKnight is offline   Reply With Quote
Old 04-27-2006, 08:55 PM   #2
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
sounds like dynamic enrichment is either too high or too low IMO. I'm running modified stock wrx injectors, my enrichment is 67... whats yours?
Could you log the car during that period of time and post it here?
DarthChicken is offline   Reply With Quote
Old 04-29-2006, 10:40 AM   #3
WhiteKnight
Member#: 56133
2004 Euro spec Sti
I have checked it, dynamic enrichment is set to 70,
I hit the throttle and car waits for 0.5 or 1 seconds then gets the command to go,
I couldn't find any solution to this ?
I can post a log without AFR's, because my wideband is not connected to hydra.
Do you still want me to post w/o afr reading ?
Old 04-29-2006, 03:19 PM   #4
bboy
Member#: 56468
04 Improved STI
Dirty White
Mine dynamic enrich is 85, but I've had it higher. There's also the throttle pump settings--maybe that's where Darth is heading with AFR. I've alway had great throttle response with the Hydra.
Old 04-29-2006, 03:47 PM   #5
WhiteKnight
Member#: 56133
2004 Euro spec Sti
What are your throttle pump settings ?
Thanks
experiencing a lag/stumbling on light to medium throttle application <<M>> Normally Aspirated Powertrain 4 09-15-2013 01:12 PM
Throttle lag with new 2010 WRX map.. Texas Paladin AccessPort 6 03-12-2010 10:11 AM
2.5i throttle lag? bani111 Normally Aspirated Powertrain 204 12-24-2008 06:35 PM
08 throttle lag saber787 Normally Aspirated Powertrain 24 03-14-2008 09:47 PM
MY00 has turbo lag.. er... rather.. NA lag..... Fitz New England Impreza Club Forum -- NESIC 7 04-03-2001 09:12 AM
