Old 04-27-2006, 08:24 PM   #1
dcdub23
Member#: 94459
2002 Impreza WRX
Default 4th gear pull/Cobb vf34 93 oct
Hey everybody! i just logged my car using tari racing and i am currently runnin a cobb vf34 93 oct map. Everybody let me know what you think about this 4th gear pull! I would love to know how my car is runnin and wether or not i have knock! Thanks everybody! Jay
http://www.yourfilelink.com/get.php?fid=91641
dcdub23 is offline   Reply With Quote
Old 04-27-2006, 08:31 PM   #2
Zumble
Member#: 34860
2005 Forester CGM
It would really help if you logged throttle position. It looks good though no knock according to your logs.
Zumble is offline   Reply With Quote
Old 04-27-2006, 10:27 PM   #3
dcdub23
Member#: 94459
2002 Impreza WRX
Now that makes me happy! I did forget to check that but my foot was to the floor! Would a pdx map be more effecient and give me a lil more power?
Old 04-28-2006, 12:31 AM   #4
Cabot
Member#: 28131
2003 WRX Sedan
Logging knock signal with ecuExplorer is worthless (refresh rate of 100-150 ms is just not fast enough to capture knock signal). You'd have to be really lucky (actually..unlucky, since knock = bad ) to detect knock with ecuExplorer. Don't forget the ecu will update signals/data much more faster than any datalogging software.
Taking a look at your log, I would, unfortunately, suspect a knock event at 5400 rpm (ecu is pulling timing, knock correction goes from 8 to 2..). I'm no expert, but that's definitely something to investigate..
Cabot is offline   Reply With Quote
Old 04-28-2006, 06:36 PM   #5
dcdub23
Member#: 94459
2002 Impreza WRX
I tried emailing the map to cobbs tuner and pdx's tuner for thrm to give me a better understanding. I am putting a manuel boost controller on to keep my boost under 18. I am also waitin for pdx's map. That should solve knock! Thanks for your help good sir!
Adviced Needed: 07 USDM STi Stg2 Master Map 4th Gear Pull Linkseal Open Source Reflashes 15 08-14-2009 11:55 AM
Videos posted to my site: Launch, 4th gear pull etc... TurboQueef Proven Power Bragging 41 10-04-2006 06:19 PM
Cobb Stg2 93 oct w/ Injen CAI map wrxicon Engine Management & Tuning 1 08-24-2005 06:57 PM
slight bucking 4th gear pull mikaust Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-12-2004 12:21 PM
overseas dyno differences: 3rd vs. 4th gear pulls annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-25-2002 03:53 PM
