Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-27-2006, 09:49 PM   #1
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Default Tuner and UTEC not talking
I installed my Tuner, and at first it tlaked just fine with the UTEC. Then, today, they quit talking to each other. When hooked up via cables:
UTEC -> Tuner -> Laptop
I get the Tuner Screen only in Hyperterminal, with no option to switch to the UTEC screen.
When hooked up:
UTEC -> Laptop
I get the normal UTEC screen, and it works fine.
Again, when I first hooked it up, it worked normally, and when hooked up:
I used to get the normal UTEC screen in Hyperterminal, WITH the option to switch to Tuner, and it logged W/B O2 just fine. I have done NOTHING different with the laptop or my UTEC or Tuner. In fact, the laptop is an old model that lives in my car just for datalogging.
Any idea how to get the UTEC and Tuner talking to each other again?
bcblues is offline   Reply With Quote
Old 04-27-2006, 09:50 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Have you tried switching serial cables in case the one from UTEC->Tuner got pinched...or was that the one you just plugged into the laptop?
cdvma is offline   Reply With Quote
Old 04-27-2006, 09:53 PM   #3
bcblues
Member#: 17256
04 STi
I'll try right now. It is a different cable. Well worth a try.
Old 04-27-2006, 10:15 PM   #4
bcblues
Member#: 17256
04 STi
Wouldn't you know, I cannot dig up a serial cable anywhere in my house! 4 computers, 2 laptops, and NO serial cables. I threw away several when I cleaned out under my computer desk about 6 months ago. "When will I ever use these again?" Oh well, off to Best Buy!
Old 04-27-2006, 10:24 PM   #5
bcblues
Member#: 17256
04 STi
Hey, I just remembered that both my UTEC and my Tuner came with serial cables. I never used the tan ones that came with the TXS units, instead opting for nice black ones that I had laying around. I pulled out one and replaced the one I had been using, and PROBLEM SOLVED!
Thanks for pointing out the obvious, that I have been overlooking!
Old 04-28-2006, 03:19 AM   #6
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Cool!
Old 04-28-2006, 04:55 AM   #7
TravisSTi
Member#: 51243
2004 Subaru WRX STi
WRB - GTX30r
I had this same problem when I got my tuner. The soltion I found was to reflash the tuner to the 1.5v software on the TXS site. My tuner came with 1.6v software that you cant get on the site. After the reflash it worked fine. So if you run into the problem again you might try this.
TravisSTi is offline   Reply With Quote
Old 04-28-2006, 09:24 AM   #8
bcblues
Member#: 17256
04 STi
Thanks for the tip. Seems to be running fine now (v1.5 software).
Old 04-28-2006, 12:35 PM   #9
bcblues
Member#: 17256
04 STi
I had a different issue running the v1.6 software. Once in a while, the UTEC would not log when run through the Tuner. v1.5, and all is well.
Old 04-30-2006, 11:55 AM   #10
bcblues
Member#: 17256
04 STi
Well, I spoke too soon. I flashed v1.5, and have two brand new serial cables connecting my UTEC -> Tuner -> Laptop. Hyperterminal still only sees the Tuner, not the UTEC. If I remove the Tuner from the loop, the laptop sees, and logs the UTEC fine. Likewise, the laptop sees and logs the Tuner fine when hooked up alone Tuner -> Laptop. Any ideas? I am getting frustrated!
Old 05-04-2006, 06:49 PM   #11
Spec_C
Member#: 91423
Chapter/Region: HIIC
2004 PSM STi on Meth
Tuned by Chris [email protected]
i too have the same problems. i talked to nathan @ TXS and he asked where i had my power wire for the tuner hooked up to. i have mine going to the ACC wire for my stereo. He said that was the problem right there. he says the utec needs to power up prior to the startup of the tuner. he suggested that i put a toggle switch so i would be abel to switch on the tuner once the utec has powered up. any other suggestions?
Spec_C is offline   Reply With Quote
Old 05-05-2006, 09:29 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
power up sequence is doing it. the utec must be booted before the tuner.
Old 05-05-2006, 10:51 AM   #13
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
And don't forget you need at least a 2amp source for the tuner, or the O2 sensor won't "pre-heat" fast enough (well during the heat cycle count down when you first start-up the tuner).
coyote73176 is offline   Reply With Quote
Old 05-05-2006, 04:06 PM   #14
Spec_C
Member#: 91423
so where should the power wire for the tuner go to, to ensure that the the utec can be read through the tuner?
Old 05-05-2006, 04:41 PM   #15
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i used what used to be the cig lighter.
i "hotwired" my cig lighter to be always powered straight to the battery (through a fuse of course) so that cellphones/laptops/etc could be charged easily.
works perfectly for me.
Old 05-05-2006, 04:56 PM   #16
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I use the power feed that comes out of the fuel pump relay. Whenever the fuel pump is on, the tuner is on and thats good for me!
Old 05-06-2006, 08:19 AM   #17
bcblues
Member#: 17256
04 STi
ride5000: Did you put a switch in your power line? Or does your Tuner just run 24/7?
Old 05-06-2006, 08:21 AM   #18
bcblues
Member#: 17256
04 STi
It seems that if I wait to launch Hyperterminal until after the Tuner finishes its warmup countdown, it works fine. Of course, it will probably rear its ugly head again when I least want it to, just like last time.
Old 05-06-2006, 12:47 PM   #19
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
No the cig lighter line is key switched...he used that line for the Tuner which used to be hooked up to the lighter but he ran a different line to the lighter now that is always on. Make sense?
Old 05-07-2006, 06:43 AM   #20
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
thanks chris--that's exactly what i did.
when the car is cranking the acc line is removed from power, which insures the tuner will come up last.
Old 05-08-2006, 11:05 PM   #21
Spec_C
Member#: 91423
i'm a electrical noob got a quick diagram that you can post up so i can see what u mean?
Old 05-09-2006, 01:15 AM   #22
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Downside is you don't get cold cranking AFRs...which I really need because of the injectors.
Old 05-09-2006, 07:49 AM   #23
bcblues
Member#: 17256
04 STi
I have been waiting to start Hyperterminal until after the Tuner finishes its warmup, and that seems to work fine. I tapped into the in-cabin fusebox into the cigar lighter fuse for power to my Tuner, and it doesn't boot until after the car is done cranking.
Old 05-09-2006, 10:39 AM   #24
2phless
Member#: 69343
1998 TransAm cnvrtbl
Just to ram this one home a little more:
I've run my tuner to an ACC power supply (like the lighter). The UTEC is both constant and IGN anyway.
So I've gotten used to this car-start-sequence:
Key in, turn on (i.e. one click past acc to 'run').
Pause just a moment to let the UTEC boot fully. The Tuner is already on at this point too and the connection isn't right.
Start the car. The ACC drops out during 'start' turning the tuner off.
Releasing the key turns the tuner back on.
If there is some hangup later I can always twist the key enough towards start to kill the radio (and tuner) but NOT bump the starter. That'll reset the connection for me. That's worked well for a year.
2phless is offline   Reply With Quote
Old 05-09-2006, 01:22 PM   #25
bcblues
Member#: 17256
04 STi
Yep, that is pretty much how I do it too. If you just turn key on to crank position directly fromthe off position, it takes a few revolutions for the UTEC to boot before teh car starts anyway. I have gotten into the habit of turning key to ign (just before starter engages) for a couple seconds before proceeding to crank the car. It then starts the first revolution. I just liken it to the old WW2 fighter plane days: "magneto -- check...."
My exhaust system is in trouble and I'm not talking about my car 10-56 Off-Topic 22 02-28-2008 03:09 PM
Fun in the Snow... And I'm not talking about snow ball fights and hot cocoa. 06AWD Member's Car Gallery 25 02-26-2007 10:11 PM
Street tuner and Utec or Hydra? greysave Other Engine Management 15 12-02-2005 08:51 PM
Pro-tuner and Utec tuning party version 2.0 mpower22 Mid Atlantic Impreza Club -- MAIC 43 06-27-2005 11:42 AM
TurboXS Tuner and UTECs in stock Prestige Motorsports Engine/Power/Exhaust 7 08-30-2004 09:18 AM
