Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 04-28-2006, 06:56 AM   #1
cinemaster
Member#: 76127
2005 WRX wgn 5spd
Obsidian Black Pearl
Default Engine oil for turbo engine differs from regular engine oil?
It's time to change engine oil for my ride.
I am used to visit subaru dealer for doing it 'cause they told me they used a special engine oil for turbo engine.
Is it true or not?
Subaru dealer charges around $35 for oil change, yet I can save at least $10 if I go local service.
cinemaster is offline   Reply With Quote
Old 04-28-2006, 06:59 AM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
They lie.
supermarkus is offline   Reply With Quote
Old 04-28-2006, 07:26 AM   #3
cinemaster
Member#: 76127
2005 WRX wgn 5spd
Originally Posted by supermarkus
They lie.
So can I change engine oil at other place?
Old 04-28-2006, 07:35 AM   #4
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
The only special oil they are using is on your wallet.
specialev is offline   Reply With Quote
Old 04-28-2006, 08:15 AM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
maybe they are putting in a synthetic (which is a good idea for a turbo)
Old 04-28-2006, 02:44 PM   #6
FD777
Member#: 84820
2005 WRX Sedan
Crystal Gray
If you've had your oil changed by this dealer before, it should say what oil they were using on your invoice/receipt.
That way we can tell you if $35 is a good price. I highly doubt the local service will do a synthetic oil change for $25. Then again, I doubt a dealer will do a synthetic change for $35.
I'd change your oil for $25 and give you a nice OEM filter. Too bad it costs me that much to drive there and back
Generally,
Quality:
Do It Yourself > Dealer > Local Place
Price:
Do It Yourself (cheapest!) < Local Place < Dealer
FD777 is offline   Reply With Quote
Old 04-28-2006, 03:33 PM   #7
Hayes
Member#: 11808
Your owners manual is your friend. The manual gives all the required specs for all the fluids.
Hayes is offline   Reply With Quote
Old 04-28-2006, 03:37 PM   #8
long5152
Member#: 93657
2002 V8 Bitches
psm
correct. i have found out that majority of people dont even read this book that they provide with the car. if they read it, they will know just about everything to maintain the car in a good condition
long5152 is offline   Reply With Quote
Old 04-28-2006, 09:38 PM   #9
98skuby
Member#: 52632
1998 impreza rs
black
there is not special oil for motors (that i have ever seen, i been a tech for years). oil is oil. the difference is motor oil and snythetic oil. snythetic is better for performace engines. it cleans a little better. and cost more.
as long as u keep up on the oil changes you should be good.
james
98skuby is offline   Reply With Quote
Old 04-29-2006, 04:34 PM   #10
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Did you see what it says in the owner's manual? 10W30.
Nothing special. You decide if you want to use synthetic or not.
Samurai Jack is offline   Reply With Quote
Something different from Mead Engineering 2.5iSTI Normally Aspirated with bolt-on Forced Induction Powertrain 23 01-19-2009 04:53 PM
Turbo sound different from VF39 and stock wrx Fiddy82 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 09-16-2007 03:11 AM
For sale Gc8 tapped oil pan, for turbo kit, with SS lines and oil galley tap felixwankel88 Engine/Power/Exhaust 4 01-29-2007 06:31 PM
greddy bov won't fit? sti mount different from regular wrx mount? burnout555 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-26-2003 05:21 PM
TurboXS Electronic Engine Management for 03 WRX different than 02 turbowrx03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-15-2003 12:46 AM
