Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Old 04-27-2006, 08:22 PM   #1
Daily Llama
Member#: 106885
2005 Forester XT
Default A/C DOA after service
OK so I had my wife's 02 OBS in for service at the Dealership. Had a leaking head gasket which was replaced under the drivetrain warranty. The Tech also replaced the belts. ..great! ...so I thought. Now the A/C does nothing when it's suposedly engaged. The little green light comes on but that's it. Checked the fuse...15A in slot 17 under the dash....is OK. anyone know if there's something simple I can check before I have to drag it back to the dealer?
Daily Llama is offline   Reply With Quote
Old 04-27-2006, 10:08 PM   #2
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Look under the hood for an unplugged harness.
My dealer forgot to connect mine when they did their PDI.
Spenk is offline   Reply With Quote
Old 04-27-2006, 11:18 PM   #3
Daily Llama
Member#: 106885
2005 Forester XT
I thought the same thing but i'm not seeing any unplugged anything....not that i know where to look. All I can find is the disconnected green 2 wire plug under the dash but I believe that is reserved for diagnostics.
Old 04-27-2006, 11:28 PM   #4
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
When you say it does nothing, does it blow warm or not blow at all?
P.S. Where in Northern NJ?
RexyGirl is offline   Reply With Quote
Old 04-28-2006, 12:36 AM   #5
Daily Llama
Member#: 106885
2005 Forester XT
It blows just like it does with the A/C turned off. So the fan works fine...It's just the compressor isn't getting turned on. All the A/C button does is turn on/off the little green light that says "AC"
P.S. Live in Northern Passaic Cnty. Work In Rockland Cnty, NY
Old 04-28-2006, 01:31 PM   #6
RexyGirl
Member#: 63616
with mods :)
It sounds like you have a bad compressor, but it could be as simple as a relay under the hood. Call the service manager and let them know it worked when it came it, but now it doesn't. Let him know if it's not related and they can prove it (it might not be), you will pay for at least the diagnosis of the problem. (this shows you are willing to accept responsibilty if it's not related
P.S> I used to live in West Milford, UGL, Wanaque, Wayne, etc. Also lived in Sussex County...graduated from High Point
Old 04-28-2006, 02:04 PM   #7
Daily Llama
Member#: 106885
2005 Forester XT
It was working perfectly before they touched it and I can't imagine them doing anything to damage the compressor so I'm assuming for the time being that it's something simple.
UGL!!! woot woot!!! I can see a corner of the lake from my living room window
Old 04-28-2006, 03:22 PM   #8
Hayes
Member#: 11808
Is the belt on? I'd recheck electrical connections carefully as a ground wire may have been left off. I doubt any thing wrong except something was not hooked back up.
Hayes is offline   Reply With Quote
Old 04-28-2006, 05:15 PM   #9
MrViggy
Member#: 54412
2002 Impreza WRX
WRC Blue
+1 for checking the belts, since you mentioned that they replaced them.
Viggy
MrViggy is offline   Reply With Quote
Old 04-28-2006, 06:57 PM   #10
all_hail_audi
Member#: 113667
2005 Twin Turbo S4
Dead subaru
Subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!subaru Sucks !!!
all_hail_audi is offline   Reply With Quote
Old 04-28-2006, 11:18 PM   #11
RexyGirl
Member#: 63616
with mods :)
Sent you a PM
Old 04-28-2006, 11:47 PM   #12
Hawke
Member#: 25777
You'll also want to check the pressure in the system. Too low and it won't allow the compressor to turn on.
Hawke is offline   Reply With Quote
Old 04-29-2006, 01:32 AM   #13
pjensen641
Member#: 36777
2004 WRX Wagon
they have to drain the system to pull the engine...did they refil it correctly? There is a safety pressure switch that will keep the pump from engaging if the system is not filled properly.
Take it back and tell them to fix it.....and don't pay a cent for it.
pjensen641 is offline   Reply With Quote
Old 04-29-2006, 01:26 PM   #14
Daily Llama
Member#: 106885
2005 Forester XT
Thanks for all the inputs people. I've double checked alll the connections and everything looks ok....fuse is good belts spin with no slippage.... So the tech obvioulsy frelled something up. It goes back next week.
After service have bubble in rearview mirror? p3Ch4 Newbies & FAQs 2 11-02-2007 12:09 AM
Brake problems-after service LegacyLDave Brakes, Steering & Suspension 1 01-03-2007 05:02 PM
BMW dealer "gives" car to thief after service ... amusing story wyn525i Off-Topic 24 06-15-2006 04:20 PM
Help! Dentist wants more $$ then quoted after service performed! akm3 Off-Topic 8 11-12-2004 03:58 PM
Turbo hissing after service Hawk-Eye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2002 01:57 AM
