Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-28-2006, 09:23 AM   #1
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Default Bad Det with TXS Stage 2 - help?
Below is a clip of a 1-4 gear run with my Stage 2 04 STi running the off the shelf TXS Stage 2 map. I am getting bad det at around 5500 rpm. Any ideas what is up? BTW, my Tuner cable was on the fritz, so I have no WB AFR values for this run.
Code:
                    Load Knock                Mod   Mod         Mod
 RPM   MAP  MAF TPS Site Count  Ign#1  Inj#1  Ign   Fuel Boost  MAF
       psia  V   %               deg   duty   deg    %   (CL)    V
 4329  -1.4 3.7  92  20    00   +25.8   50.4 ECU.   +0.0 ECU.   3.8
 4741  +3.9 4.0 102  50    02   +25.3   68.6 ECU.   +0.0 ECU.   4.0
 4450  +7.6 4.0 104  70    01   +19.4   62.4 ECU.   +0.0 ECU.   4.0
 4701 +11.3 4.0 104  80    00   +19.6   67.3 ECU.   +0.0 ECU.   4.1
 4642 +13.9 4.0 105  80    00   +18.7   68.8 ECU.   +0.0 ECU.   4.0
 4909 +14.5 4.1 104  80    00   +19.0   75.1 ECU.   +0.0 ECU.   4.1
 5583 +14.3 4.2 104  70    00   +18.3   79.2 ECU.   +0.0 ECU.   4.2
 6265 +13.7 4.3 105  70    00   +18.7   85.6 ECU.   +0.0 ECU.   4.3
 6734 +12.9 4.3  98  70    00   +22.4   84.2 ECU.   +0.0 ECU.   4.3
 6816  +9.8 2.4   0  00    00   +22.8    9.5 ECU.   +0.0 ECU.   1.9
 6858  +6.2 3.9 107  10    00   +39.4   62.9 ECU.   +0.0 ECU.   4.1
 4844  +5.3 4.2 110  20    02   +24.8   77.3 ECU.   +0.0 ECU.   4.1
 5350  +5.7 4.2 112  70    03   +24.6   80.2 ECU.   +0.0 ECU.   4.2
 5611  +8.6 4.2 112  70    07   +22.3   81.1 ECU.   +0.0 ECU.   4.2
 5920 +12.9 4.2 110  70    00   +21.4   86.1 ECU.   +0.0 ECU.   4.2
 6150 +13.3 4.3 109  70    00   +22.5   87.7 ECU.   +0.0 ECU.   4.3
 6447 +13.7 4.3 109  70    00   +24.3   88.3 ECU.   +0.0 ECU.   4.3
 6788 +13.3 4.3 108  70    00   +26.3   89.3 ECU.   +0.0 ECU.   4.3
 7092 +13.1 4.3 104  70    00   +26.9   86.3 ECU.   +0.0 ECU.   4.3
 7473 +10.4 2.7   0  00    00   +35.1   12.2 ECU.   +0.0 ECU.   1.9
 6523  +4.1 2.3 109  10    00   +42.0   12.4 ECU.   +0.0 ECU.   2.9
 5640  +1.7 3.9 112  10    00   +30.7   68.5 ECU.   +0.0 ECU.   4.1
 5376  +1.9 4.2 110  50    00   +24.3   82.8 ECU.   +0.0 ECU.   4.2
 5574  +5.1 4.3 110  80    12   +19.3   86.6 ECU.   +0.0 ECU.   4.3
 5837 +10.8 4.3 110  70    00   +18.9   87.0 ECU.   +0.0 ECU.   4.3
 5963 +13.9 4.3 110  70    00   +18.8   87.1 ECU.   +0.0 ECU.   4.3
 6218 +13.7 4.3 110  70    00   +19.5   89.7 ECU.   +0.0 ECU.   4.3
 6184 +13.5 4.3 110  70    00   +20.5   91.3 ECU.   +0.0 ECU.   4.3
 6397 +13.5 4.4 110  70    00   +21.3   90.7 ECU.   +0.0 ECU.   4.3
 6666 +13.5 4.4 110  70    00   +22.6   92.9 ECU.   +0.0 ECU.   4.4
 6775 +13.5 4.3 109  70    00   +23.8   92.6 ECU.   +0.0 ECU.   4.4
 6626 +13.5 4.4 109  70    00   +24.6   90.9 ECU.   +0.0 ECU.   4.4
 7199 +13.3 4.4   9  00    00   +18.2   84.1 ECU.   +0.0 ECU.   3.6
 7293  +7.8 1.9  23  00    01   +39.7    9.8 ECU.   +0.0 ECU.   2.0
 5837  +1.7 2.3 109  10    00   +41.3   18.4 ECU.   +0.0 ECU.   3.3
 5027  -1.2 4.0 112  10    00   +29.4   68.6 ECU.   +0.0 ECU.   4.0
 5491  -0.8 4.2 112  50    03   +16.4   84.6 ECU.   +0.0 ECU.   4.3
 5500  +4.9 4.3 112  80    05   +22.7   86.8 ECU.   +0.0 ECU.   4.3
 5518 +11.5 4.3 112  80    07   +22.8   84.6 ECU.   +0.0 ECU.   4.3
 5621 +14.3 4.3 112  80    02   +20.8   87.4 ECU.   +0.0 ECU.   4.3
 5889 +14.5 4.3 111  80    07   +18.4   91.7 ECU.   +0.0 ECU.   4.3
 5837 +14.3 4.3 112  80    00   +18.3   89.9 ECU.   +0.0 ECU.   4.4
 6060 +13.9 4.3 110  70    00   +18.3   91.5 ECU.   +0.0 ECU.   4.3
 5963 +14.3 4.3 110  80    00   +18.6   92.4 ECU.   +0.0 ECU.   4.3
 6172 +14.1 4.3 110  80    00   +19.3   91.4 ECU.   +0.0 ECU.   4.3
 6161 +13.9 4.4 109  70    00   +19.5   91.7 ECU.   +0.0 ECU.   4.4
 6230 +14.1 4.4 110  70    00   +19.5   92.3 ECU.   +0.0 ECU.   4.3
 6337 +13.7 4.4 109  80    00   +20.7   93.2 ECU.   +0.0 ECU.   4.4
 6497 +13.7 4.4 109  80    00   +21.3   93.4 ECU.   +0.0 ECU.   4.4
 6561 +13.7 4.4 109  70    00   +21.9   90.8 ECU.   +0.0 ECU.   4.4
 6693 +13.5 4.4 109  70    00   +23.6   90.6 ECU.   +0.0 ECU.   4.4
 6844 +13.7 4.4 109  70    00   +24.3   88.6 ECU.   +0.0 ECU.   4.4
 6816 +13.3 4.4  64  70    00   +24.7   91.5 ECU.   +0.0 ECU.   4.4
bcblues is offline   Reply With Quote
Old 04-28-2006, 10:10 AM   #2
wrex03
Member#: 29963
04 sti
By the looks of it your not actually using the stage two map, but are on map zero.
Timing is being controlled by the ecu, and your actual maf and mod maf is the same.
Basically your car is detonating all on it's own and the utec is recording it.
wrex03 is offline   Reply With Quote
Old 04-28-2006, 11:12 AM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
+1
Old 04-29-2006, 12:27 PM   #4
JDM 3SGTE
Member#: 35479
adjust your tps
JDM 3SGTE is offline   Reply With Quote
Old 05-03-2006, 07:17 PM   #5
fantabulous
Member#: 57364
99 m coupe
01 z3 coupe
yeah, double check your map in hyperterminal. i remember when i bought my utec they told me it was loaded with various maps. but guess what? no maps.
fantabulous is offline   Reply With Quote
Old 05-04-2006, 01:18 PM   #6
bcblues
Member#: 17256
04 STi
Adjusted my tps, which did away with a stumble I had been suffering at about 3500 rpm. I finally figured out that I had a Cobb AP Stage 2 map loaded in my ecu. Whoops. _insert sheepish grin here_
Max boost on stock boost guage with TXS Stage 2? digitaltekniq Engine Management & Tuning 2 05-27-2003 11:52 PM
Max boost with TXS Stage 2, VF23 and stock injectors? muddywaters Engine Management & Tuning 7 01-22-2003 06:06 PM
Gas milage bump with TXS stage 2 ezatnova Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-29-2002 05:59 PM
Some one with txs stage 2 i need your help! cronic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-04-2002 09:58 AM
EGTs with TXS stage 2 BOP Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 02-15-2002 11:17 PM
