Old 04-28-2006, 02:16 PM   #1
Lennon
Member#: 34821
02 built usdm2.o
v6 sti heads
Default built 2.o w/ v6 sti heads
usdm 2.0 (8k mi)
eagle rods
je pistons
balanced crank
arp head studs
v6 sti heads
[LHS20v008
RHS20v006]
titanium valve springs (bling)
polished covers (more bling)
fired it up today...it's much louder than i had anticipated but it's not running rough at all. i haven't driven it yet, monday i will get it trailered back to my house and put the hood / bumper and fenders back on (i almost always take the skins off when working on my motor) headlights in, etc and drive it around.
question: any utec users that had to adjust the knock sensitivity dramatically or disable it all together? (i guess i should ask that in EM&T)
Lennon is offline   Reply With Quote
Old 04-28-2006, 03:03 PM   #2
rustyzipper
Member#: 79175
2004 FXT
Red
interesting build, good luck
did you have any issues with the JE pistons?
rustyzipper is offline   Reply With Quote
Old 04-28-2006, 07:34 PM   #3
Lennon
Member#: 34821
02 built usdm2.o
v6 sti heads
no problems yet...installation was a breeze
Old 04-28-2006, 07:36 PM   #4
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
What did you do with the cam gears and the cam sensor on the front of the motor.
Token-Negro is offline   Reply With Quote
Old 05-03-2006, 06:29 PM   #5
Lennon
Member#: 34821
02 built usdm2.o
v6 sti heads
hey, my frankenstein motor is smoking a bit...help me diagnose please. of course the engine itself is burning off the residual dirt and oil (expected) but there is some smoke also creeping out of the exhaust. not alot, but it's there and it's buggin me. looks like it's only a problem at idle, but i can't tell for sure. the turbo (1820) is spooling fine and i don't see any blow by in the IC piping.
all new gaskets, EVERYWHERE and the heads are being held on by ARP studs. i had the compression chceked it was 160-165 across the board.(cold). and leak down tested also came out 12 ,15,15 ,17...(cold also) . does that look straight? what do you think?
Old 05-07-2006, 02:13 AM   #6
bmxwrx
Member#: 105086
Did you fix your problem?
Your buildup is similar to what i would choose, i'm running a 1820 myself.
Have you got it tuned yet? Results?
bmxwrx is offline   Reply With Quote
Old 05-07-2006, 05:18 AM   #7
scooby-stu
Member#: 52890
When my newly built motor was done ther was some noise to begin with but it died as time went on
scooby-stu is offline   Reply With Quote
Old 05-07-2006, 08:32 AM   #8
Lennon
Member#: 34821
02 built usdm2.o
v6 sti heads
okay so this motor is still pretty new to me, but here it goes...cold starts are still pretty 'in your face' loud but quiets down during warmup. almost all the slap is gone under any kind of load (higher rpms) then returns on deceleration. another thing i've noticed is this motor smoked alot at first, now it's not (much ). haven't tuned it yet, still running my 1820 / 650 / fmic maps from before...it's all good for now, more to come.
Old 05-09-2006, 12:44 AM   #9
shouldaboughtanSTI
Member#: 100782
Is this in a us wrx??If so..what engine management did you go with..I was planning this same swap sorta awhile back..But, i have a ver.7 shortblock..and wanted to run it off my stock ecu,and tune with Utec..I was told it most likely wouldnt work..So, i never bought the heads..Sounds fun..keep us posted..Jason..
shouldaboughtanSTI is offline   Reply With Quote
Old 05-09-2006, 12:22 PM   #10
Lennon
Member#: 34821
02 built usdm2.o
v6 sti heads
Originally Posted by shouldaboughtanSTI
Is this in a us wrx??If so..what engine management did you go with...
yes it is a usdm block
i am using the same utec / ecu i was before because the motor, obviously, has the same wiring harness and the heads are non avcs
the EM issue was one on the reasons why i built up a usdm and didn't go full on JDM.
V5/V6 STi Heads trex616 Private 'Wanted' Classifieds 6 05-16-2010 05:01 PM
FS: GST Built 2.5L Block, Stock STi heads 1WRX2NV Engine/Power/Exhaust 18 10-28-2009 12:59 AM
GS Crank Pulley $89! STG 2 Built SB $2799! EJ22 $1999! STI HEADS $999!PERRIN FUEL 299 Gruppe-S Engine/Power/Exhaust 9 05-11-2007 01:56 PM
charlottesville install: v6 STi heads / built 2.0L Lennon Mid Atlantic Impreza Club -- MAIC 26 05-03-2006 11:51 PM
Built 2.5l Motor W/wrx Heads Turbo Set Up ...... And More julezamazing212 Private 'For Sale' Classifieds 61 02-17-2006 11:45 PM
