Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 04-28-2006, 04:05 PM   #1
Xtant
Member#: 105710
2006 WRX Wagon
WR Blue Pearl
Default 06 WRX Turbo Upgrade Question
So I've been lurking for months now checking out threads and doing research but I haven't really been able to get exactly the information I'm looking for. I have an 06 Wagon which I want to upgrade the turbo on. Currently it's bone stock. With the turbo upgrade I planned in doing a TBE, fuel pump, TMIC and EM of some sort (still undecided). I have some particular and specific goals and restrictions on this.
  • I do not want a rotated or any setup requiring a FMIC
  • I want to utilize stock location
  • I want the ability to put down somewhere in the neighborhood of the mid 300's to the ground
  • I do not want complicated alky or water injection
  • The car will be used as a daily driver
  • I do not want to do anything to the stock rotating assembly
I'm open to ideas on how to best get to where I want to be. I'm a newbie to turbo setups so please forgive any possible ignorance on this subject. If cams are required to get to where I want to be that is accecptible as long as the car remains easily daily drivable. That is about the extent of the motor work I'd be willing to do to beyond the support turbo requirements. I welcome your thoughts and suggestions. Thanks!
Xtant is offline   Reply With Quote
Old 04-28-2006, 04:34 PM   #2
jeeps1998
Member#: 99473
2006 WRX TR stg 2
I would recommend getting the Cobb AP first then the 18G turbo, TBE, and any TMIC other than the STI TMIC. You can run a STI TMIC, but if you plan on putting mid 300's down then you will probably want something else. With this setup you should be at 288 AWHP. Thats all that I plan on doing because I don't want to upgrade my transmission. Good luck.
jeeps1998 is offline   Reply With Quote
Old 04-28-2006, 04:37 PM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Did you read my Turbo FAQ? You need to state your spool wants as well. Learn compressor map reading and find your own turbo or ask a PRO like Jerry at Deadbolt for their opinion. Choosing a turbo is a V E R Y long and thoughtful process....research three times, wait, then do so again. After much more thought.....buy.
Old 04-28-2006, 05:20 PM   #4
Chiketkd
Member#: 71634
In hibernation...
Depending on how much $$$ you want to spend, you can get a low mileage STI VF39, STI TMIC, 3" TBE and Cobb AP with the stage 3 (VF39 Map) and you will be right around 275whp.
From there spend $400 for a 'safe' protune and you'll be knocking on 300whp. Not the mid 300's you're looking for, but a solid start.
If you'd really like a turbo from the start that's capable of make mid 300's on pump gas, it should be doable on a 20G or FP Green.
Chiketkd is offline   Reply With Quote
Old 04-28-2006, 05:52 PM   #5
Chiketkd
Member#: 71634
In hibernation...
Here's a thread showing an STI that's made 360+whp on pump 92 with an FP Green:
http://forums.nasioc.com/forums/showthread.php?t=993052
He does have a FMIC though. With the 2.5L block in your '06 WRX, you should be able to make 350+whp with a similar safe tune (compression is slightly higher in the WRX block, so you won't be able to hit the same numbers as an STI). However, the life of your trans will be significantly shortened unless you have an automatic (in which case I'd suggest you install 2 tranny coolers in series)
Old 04-28-2006, 06:21 PM   #6
ControlFreak
Member#: 99200
I can't tell you what turbo is best for your situation, it will require some research. I will say that I have an 06 wrx, and I'll be putting on a TurboXS TMIC, Element Tuning 18g, and a protune.
Keep in mind I don't really have any specific whp goals, I'm just looking for a more grunt over the stock turbo with out going crazy and replacing internals to handle more boost and hp.
ControlFreak is offline   Reply With Quote
Old 04-28-2006, 06:49 PM   #7
toekneeyo
Member#: 97884
06 WRX_vf39
06 X5 Black
Fuel Pump is Optional with this set up:
1.)turboback exhaust
2.)Cobb AP stage 2
3.)JDM STI TMIC (cause jdm fits better)
4.)vf39 (used goes for $300-$400 depending on mileage)
or
4.)18G but it's going to cost ya
5.)then load the vf39/18G map with your Cobb AP since stage 2 is no longer needed
6.)enjoy
-if it gets boring after a while
7.)protune
toekneeyo is offline   Reply With Quote
Old 04-28-2006, 06:51 PM   #8
FNR32
Member#: 84147
03 WRX
I agree w/ jeeps
FNR32 is offline   Reply With Quote
Old 04-29-2006, 12:43 AM   #9
juste_frank
Member#: 109265
2006 WRX sleeved
built engine
My car is a daily driver 2006 wrx.
List of mods:
TD06h16 turbo tuned @16 psi (conservative tune)
custom up-pipe 2.5"
custom turbo-back 3" w/high-flow cat in downpipe
silicon turbo inlet
green air filter
pink injectors
Ecutek
walbro 255 pump
lightweight pulley kit
currently at 291 whp
juste_frank is offline   Reply With Quote
Old 04-29-2006, 11:07 AM   #10
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
List of mods:
custom up-pipe 2.5"
silicon turbo inlet
green air filter
pink injectors
Ecutek
walbro 255 pump
Did your turner require the fuel system upgrades? Or was that just a prefrence? Also same question for the up-pipe.
UndertoW101 is offline   Reply With Quote
Old 04-29-2006, 03:46 PM   #11
slipstreamxk1
Member#: 99280
2006 WRX LTD
wow man you didnt need to buy pinks for your car... theyre the same flow rate!
and why did you make a custom up pipe? unless you were going to change the headers it really doesnt mean much in the 06's. nice numbers other wise!
slipstreamxk1 is offline   Reply With Quote
Old 04-29-2006, 04:07 PM   #12
juste_frank
Member#: 109265
2006 WRX sleeved
built engine
The tuner recommended to change the pump. And for the injectors, well at the time we had no idea about the flow rate of the 06's. The up-pipe was optionnal (the 06's have no cat in up-pipe) but give a little more throttle response. Very happy with this setup but will probably put a bigger TMIC. Also, with this kind of power the clutch barely holds and can't stand any launch.
Old 04-29-2006, 05:41 PM   #13
mdd1986
Member#: 83450
2000 Audi S4 Stage 3
i think that 290whp is good for a conservative tune, but on that turbo u should be over at least 300whp with your setup. I think that for what your looking for the 20g is the perfect option. It will give u decent spoolup and will deff be able to hit 350whp on it with the right tune. The only thing is that you might want to thiink about upgrading your tranny b4 u do this.
mdd1986 is offline   Reply With Quote
Old 04-29-2006, 06:07 PM   #14
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
What about upgrading the internals? 350 whp is quite a bit on the stock WRX guts don't you think?
Old 04-29-2006, 06:14 PM   #15
slipstreamxk1
Member#: 99280
2006 WRX LTD
from what i understand the 06 internals are the same as the sti so theyre good for about 450 crank. Pistons are really the only thing needing upgrades beyond that point.
I understand about the flow rates on the injectors in the 06 but wasnt sure the orientation before i went and bought some of my own. the 06 wrx injectors are side feed correct?
Old 04-29-2006, 06:48 PM   #16
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
[quote=slipstreamxk1]from what i understand the 06 internals are the same as the sti so theyre good for about 450 crank. Pistons are really the only thing needing upgrades beyond that point.QUOTE]
I don't think that has been proven just yet. I was under in impression from my readings that most if not all of the wrx internals are diff part numbers than the sti.
Please correct me if i am wrong...it would be great
Chris
Old 04-29-2006, 06:59 PM   #17
Sypher
Member#: 106366
2006 WRX
[quote=UndertoW101]
Chris
From what I understand from previous post the Entire Block is the same as the STI, pistons, etc, only diff is in the head. Besides STI's engines dont have forged internals any way, problem is once us WRX owners get to the 300WHP range that is IT, anything over would be a problem for the tranny I would imagine. Ide just play it safe. Besides 300WHP is plenty more then enough to SPANK a stage 2 STI, heck youll even beat Stage 2 STI protuned. Oh yeah forgot to mention if you plan on spending that much to boost you might as well buy an STI, I got the WRX 06 TR just so I can have equal performance of an STI for HELLA cheap. Which you can get HELLA cheap.
Sypher is offline   Reply With Quote
Old 04-29-2006, 07:04 PM   #18
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
gOOD to know.....
Hope i see 300whp with an 18g and STi TMIC
Old 04-29-2006, 07:37 PM   #19
Defiantspaz
Member#: 101100
04 WRX STi
WR Blue Pearl
I was told the trans in the 06 WRX was sourced from the Forester turbo and is beefier than the previous WRX units.
Defiantspaz is offline   Reply With Quote
Old 04-29-2006, 07:58 PM   #20
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
List of mods:
custom up-pipe 2.5"
silicon turbo inlet
green air filter
pink injectors
Ecutek
walbro 255 pump
Got any pictures of the setup...or install?
Want to see what i have to look forward too
Old 04-29-2006, 08:14 PM   #21
kn0bby8
Member#: 97644
2006 WRX
I have been pondering the same upgrade questions since I bought my car. One week I am donig a gt30 next week, a green, next I am going to wait for the new helix turbo. Now I think the best thing to do for me, also the cheapest out of the others is
VF39
Either STI TMIC or Aftermarket TMIC
Meth/ Water Injection
I can probably get a used VF39 and STI TMIC for arond $700.
Meth/Water Injection kit for around $500
I would install turbo and tmic myself and run cobb stage 3 map until I get the meth installed. I have now Idea how much the install is gonna be but I can't see it being more than $500.
That puts me at $1200 buks for proably around 320WHP.
I only listed the essentials and am probably forgetting sumpin or other.
I will also proabably end up adding
Fuel Pump $100
AVCR $375
Intake $200
BOV $250
Clutch $?
Even with the extras it seems like it will be a cheap way to make just a little more power than the tranny could handle. Down the road if I ever end up doing PPG tranny than I can go BIG!
kn0bby8 is offline   Reply With Quote
Old 04-29-2006, 08:20 PM   #22
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
Nobody wants to go with a mitsu turbo? 16/18/20G
I was going to stay away from the vf series because i heard they crack a lot.
Old 04-29-2006, 08:32 PM   #23
Sypher
Member#: 106366
2006 WRX
eh that whole cracking thing I heard doesnt really affect anything dude. Hell look at it like this, You CAN get a turbo Back for 500$ or less, This is what I did,
Buschur (LOuD AS OPRAH) Catback Exhaust Used 180$
Megan 3 Inch Bellmouth DownPipe (damn good quality for the price) 186$ Shipped
I found a local STI dude whos selling me a STI intercooler for 200$
COBB AP 650$
VF-39 400$ Or 18G 850$ shipped
Add all that up and NO you DONT need a fuel pump........That is Less then 2 Grand I repeat 2 grand to be FASTER then a STOCK STI, and get the same gas mileage youve always been getting. Subaru made it TOO easy to equal an STI's acceleration in 06, PLUS they gave us a TR thats 24k MSRP? Seriously you can get 06's for 22k if your good, add that up, then add Coilovers, Hell STi seats, Kartboy Short Shifter and bushings, Wheels and Tires Enkies or what ever, and your Still saving THOUSANDS and now you can do everything an STI can do but faster and better. And the STock Clutch is more then enough for 300WHP, my friend in a 03 with a VF30 putting down 310WHP is on his stock clutch from when the car was bought New, it now has 70k miles on it.
Old 04-29-2006, 08:39 PM   #24
Sypher
Member#: 106366
2006 WRX
Lol I just think its funny what 05 and down and STI owners say about the 06. They seem to nitpick everything thats wrong with the car or how theres is better, always comes down to looks though. I remember having an argument with an STI owner who swore up and down that my cars fuel injectors were smaller then his. Then I pointed him to Nasioc and Presto, "Well that makes no sense why the WRX injectors are bigger then my STI's" I just cant wait till I put my 18G on and SMOKE a Stage 2 STI protuned (Which I believe is VERY possible) that spent probably more on his Exhaust and Tune alone then I spent on my entire Set up.
Old 04-29-2006, 08:40 PM   #25
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
[quote=Sypher]eh that whole cracking thing I heard doesnt really affect anything dude. QUOTE]
Um....did you have any more to say on why you think this? I have read a lot about vf's cracking.
Also...I got some quotes for a new VF39 going for 700+
06 WRX turbo Upgrade Questions. 06wrx_WRB Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 05-02-2010 11:16 AM
06 WRX brake upgrade question rkjunior Brakes, Steering & Suspension 1 04-26-2010 01:59 PM
06 wrx 18g upgrade questions Wannascooby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 03-18-2010 04:07 PM
06 WRX Turbo Upgrade Progress drmichael Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 03-13-2010 04:21 AM
06 WRX turbo upgrade question Sharkey Newbies & FAQs 8 11-10-2006 10:43 PM
