Old 04-28-2006, 05:38 PM   #1
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Default AVCS Heads in a non AVCS Car?
Well im starting my 2.5 build and just recieved my 04 sti heads with the AVCS i was just now told that i will need to build a bracket for the single cam sensor the none AVCS cars use. Has anyone done this with success? OR should i try and source a JDM ecu with the ability to run the AVCS?
Im building a fully forged 2.5 for my 05 WRX
Token-Negro is offline   Reply With Quote
Old 04-29-2006, 11:15 AM   #2
keaniegenie
Member#: 94494
2005 Element 92x
Once you get into this, I'd recommend getting a Hydra. Instead of sourcing a AVCS ECU, then getting a STI EM, the WRX Hydra has AVCS use. This is the main reason why I'm going to a hydra. It's a standalone ecu that will plug in with just four wires and replace your factory ecu.
Phil from Element is at World One today, so I'd try calling down there if you want to talk to him. Hydra's are typically for pretty advanced engine setups, but yours seems to fit the bill.
If you have AVCS heads, I'd recommend using the avcs control.
keaniegenie is offline   Reply With Quote
Will JDM STI AVCS cams in USDM STI AVCS heads? dexterous Built Motor Discussion 102 09-11-2014 12:32 PM
Directions how to install AVCS heads in a non AVCS car and not use AVCS sgiord86 Built Motor Discussion 1 11-19-2009 04:31 PM
So is it possible to put an oem sunroof in a non sunroof car? scobaru Interior & Exterior Modification 12 08-19-2007 09:27 PM
Any write ups on AVCS motor into a non AVCS Car? SINthetic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 02-04-2006 05:53 PM
Accidentally put diesel in a non-diesel car, any suggestions? INTEGRAtoWRX Off-Topic 19 07-09-2004 10:39 PM
