Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-28-2006, 06:48 PM   #1
da n00b
Member#: 65951
02' e46 ///M3
Imola Red
Default Valet Starting Problem
I have a problem starting my engine when the Utec is on Valet Mode(Map 6). I test start every other map and they all seem to be fine. Security mode I would understand but Valet Mode would turn on but then when I shut off the engine and would try to restart it it wouldn't start. Also when I have been driving around on Valet mode and turn off the car and would start it again it wouldn't start unless I set the map switch to any other map besides 7(which is security mode). Anyone have any input?
da n00b is offline   Reply With Quote
Old 04-29-2006, 09:28 AM   #2
ZR2_S10
Member#: 83865
2005 Saab 9-2X Aero
Midnight Blue
Hook up yer laptop, and turn the key to "ON" and look at the dashboard. Make sure your switch is reporting the correct position / map.
Thats a start.
Jason
ZR2_S10 is offline   Reply With Quote
Old 04-29-2006, 11:54 AM   #3
da n00b
Member#: 65951
02' e46 ///M3
Imola Red
Yeah I did hook up my laptop and looked if I was in the correct map. Everything seems to be fine now but whenever I took it to the tracks tonight and drove it on the Valet map I smelt some sort of burning coming from my engine. After the tracks on the way home I had it in valet mode and smelled the same thing and this only happens in Valet map. Is this map not recommended not to drive on? Will it harm your engine?
Starting Problems Yanofsky Service & Maintenance 15 02-05-2002 09:39 PM
Can the unichip cause cold-start problems MARTY5446 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 01-04-2002 03:00 PM
Cold Start Problems? Kapwi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-10-2001 05:36 PM
