Old 04-28-2006, 06:25 PM   #1
toekneeyo
Member#: 97884
06 WRX_vf39
06 X5 Black
Default BOOST SPIKE FIXED! or is it? HELP!
hey guys i have a vf39 and was experiencing boost spike at 4th gear in the higher RPM's. Cobb tuning says to combat this you need to dremel a hole in the restrictor pil with a #57 drill bit (.043") in one of the vacuum lines on the turbo.
it seems like the hole in the pill is already that size. i used the pill from my td04 because the vf39 didn't come with one.
i decided to just get the next biggest, #56 drill bit (.0465).
i was using my AP to measure the boost.
4th gear - 18.3psi-17.0psi in the higher RPM's
does this look normal to you guys?
toekneeyo is offline   Reply With Quote
Old 04-28-2006, 06:30 PM   #2
blah man
Member#: 84434
2008 Felt AR4
Carbon Black
have you been protuned, or do you have a stage map? do you have a catless/catted downpipe? Need more info
blah man is offline   Reply With Quote
Old 04-28-2006, 06:37 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
you shold have 0.9 bar or 13.5 psi stock boost.
enlarging the opening in the restrictor pill will actually
lower overall boost. so the spike should lessen.
the larger the opening in the pill, less boost.
so no the boost you are experiencing is not
normal, unless your ecu is mapped for that
level of boost.
Old 04-28-2006, 07:08 PM   #4
toekneeyo
Member#: 97884
06 WRX_vf39
06 X5 Black
i am running Cobb's vf39 map.
target boost 16.5psi +/- .7 would be normal
i reset the ECU this time.
on 3rd gear the boost went to 18.0psi in the higher RPM's
but 4th gear goes around 16.5psi now.
do you think it's safe to just run my car like this?
or i might have to drill a hole slightly bigger
(could it be that im using my Cobb AP as a boost guage? readings might be inaccurate?)
'06 wrx
-TBE
-Cobb Tuning AP
-jdm sti tmic
-vf39
Old 04-28-2006, 07:36 PM   #5
4EVO2NV
Member#: 51692
04 STi JBP
Enginuity Tuned
well they dont make a vf39 map for an 06 sti. SO that would be your problem. Could be wrong. Why not call cobb?
4EVO2NV is offline   Reply With Quote
Old 04-28-2006, 07:39 PM   #6
4EVO2NV
Member#: 51692
04 STi JBP
Enginuity Tuned
I just checked. The map u are running on your accessport is not made for a vf39. THAT IS YOUR PROBLEM. You are using a turbo not designed for your tune. Try www.pdxtuning.com See if they have a ots map for vf39.
Old 04-28-2006, 08:22 PM   #7
kn0bby8
Member#: 97644
2006 WRX
Cobb did make a vf39 map!
kn0bby8 is offline   Reply With Quote
Old 04-28-2006, 08:51 PM   #8
toekneeyo
Member#: 97884
06 WRX_vf39
06 X5 Black
1.)CLICK ON WRX
2.)GO TO 2006 ACCESSPORT MAPLIST. NOT 2002-2005.
3.)CAREFULLY LOOK FOR "VF39 91/93 OCTANE MAP"
boost spike, have a problem need help Brother EddieJ. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-24-2009 11:53 AM
low boost in heat? or is it time to buy an '08? madsociety Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-22-2008 06:05 PM
Not your everyday boost controller question... or maybe it is... preluden20 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 06-04-2006 11:14 PM
loosing boost any idea or is it normal wrxin' Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-01-2003 06:50 PM
UniChip boost spiking fixed.. but... phooka Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 77 11-23-2001 07:13 PM
