Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 04-29-2006, 12:29 AM   #1
shemoves
Member#: 80663
2005 STi
Default How to tell if brakes are glazed?
I just put new pads on and tried to break them in properly. Is there a way to tell if the pads/rotors are glazed? And...what exactly is 'glazing?'
edit: I did search and have also been looking through stoptech's whitepapers...still don't know how to tell.
shemoves is offline   Reply With Quote
Old 04-29-2006, 01:13 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
glazing is pad material deposited as a coating on the rotor.
Old 04-29-2006, 03:21 AM   #3
shemoves
Member#: 80663
2005 STi
How can I tell if they are glazed? What would one vs. the other look like?
Old 04-29-2006, 09:01 AM   #4
RUrunning
Member#: 68758
15 STi
LE
if you doubt that there's a proper transfer layer, just go out and re-follow the instructions on stoptech's website (i used those instructions too, even though my carbotech pads came with their own). proper bedding-in will remove whatever was already there and will add it's own new transfer layer as well. if you over-heat your brakes (which is what SHOULD happen if you follow the directions) and avoid coming to a complete stop, you should get an even glaze. can't tell you exactly what to look for, but trust ya did a good job following a print-out
RUrunning is offline   Reply With Quote
Old 04-29-2006, 09:08 AM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
if there is pad material on the rotor, you will see it as discolored regions. Usually it's only the pads which glaze - if you look at the business side of the pad it will be very smooth and shiny.
Old 04-29-2006, 02:22 PM   #6
shemoves
Member#: 80663
2005 STi
ahh, so I'd have to take off the pad to check for glazing?
Old 04-30-2006, 07:18 PM   #7
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
http://www.raceshopper.com/tech.shtml#brake_pad_glazing
The rotors will typically have a bluish hue/tint to them and be smooth.
Legacy777 is offline   Reply With Quote
Old 05-01-2006, 02:33 AM   #8
shemoves
Member#: 80663
2005 STi
They will have this blue hue when glazed?
Old 05-04-2006, 07:58 PM   #9
Legacy777
Member#: 4800
I can't say they will always be like this, but more then likely they will look a little different and be smooth.
Old 05-05-2006, 11:26 AM   #10
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
on my old car the rotors would become really smooth and polished. That would diminish the braking ability
vapore0n is offline   Reply With Quote
Old 05-05-2006, 04:25 PM   #11
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Unless you're next chunk of miles in your car is to the track where you need maximum performance from your brakes, it doesn't matter if you glazed the pads or not. Eventually, the glazed portion will wear down and you can rebed the brakes.
I had a set that apparently didn't bed well in one spot on the pad. I wasn't doing anything but driving on the street for the time being so I kept purposely stopping hard to sorta rebed when the opportunity arose. After awhile, I checked the pads and the "sticky spot" was completely gone. Obviously this only works if you have time to wear them down.
chimchimm5 is offline   Reply With Quote
Old 05-11-2006, 02:16 PM   #12
Legacy777
Member#: 4800
We're (or at least I was) talking about glazed rotors....not pads. Having the rotors cut is pretty much the only 100% way to get rid of the brake pad material.
Accidentally left my guitar amp on for over a week. How to tell if tubes are bad? lennyTR Off-Topic 85 10-30-2009 12:12 AM
How to tell if struts are done? Mr_Snips Brakes, Steering & Suspension 3 11-21-2008 12:31 AM
Bought used konis, how to tell if they are shot? elsanto Brakes, Steering & Suspension 5 08-09-2007 11:11 AM
How to tell if morettes are genuine? Drowner Electrical & Lighting 4 03-21-2006 05:06 PM
how to tell if my Rota Battles are hubcentric? balajc Tire & Wheel 2 04-16-2004 11:45 AM
