Old 10-07-2001, 01:08 AM   #1
DarkImpreza
Member#: 3607
98 Impreza RS
black
Default help: Ignition
hey guys, I am running minnam turbo kit on 2.5 RS
just wondering what kind of spark plugs and wires
you guys use, because I think I am getting
new plugs and wires, but not sure which is good
for the turbo set up, so please help me out thanks. =)
DarkImpreza is offline   Reply With Quote
Old 10-07-2001, 01:15 AM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Honestly, the stock wires are more than enough. anything else is just for looks or bragging rights.
For plugs, I would go with the NGK 7's I got mine from Sunnit and they are the plug of choise on the i-club
Eric
Eric SS is offline   Reply With Quote
Old 10-07-2001, 02:48 AM   #3
DarkImpreza
Member#: 3607
98 Impreza RS
black
is factory plug those platium one??
Old 10-07-2001, 03:20 AM   #4
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Unless you have upgraded ignition, the stock wires are fine. If you do end up getting new wires, do NOT get Nology Hotwires as they are complete garbage. Stick with a quality manufacturer like Magencor or Jacobs.
Ben
bsquare is offline   Reply With Quote
Old 10-07-2001, 05:12 AM   #5
DarkImpreza
Member#: 3607
98 Impreza RS
black
really? nology is garbage???, my friend has nology hot wire
on his GS-R turbo, works really well though......
or may be sux at subaru engine or something then....=)?
i am thinking of NGK wires or MSD
but MSD is abit pricy, NGK seems cheaper isn't it?
I don't know about my factory wires and plugs...it seems
to have abit lagging on my RPM on each gears when I do
power shift, I thought was my factory clutch thats
not holding the power and slips...but one of my
friend told me should be my ignition has problem
either the plug is almost dead or wires
and feels like the ignition is not giving out
the power I need....after my turbo I mean.=)
Old 10-07-2001, 07:12 AM   #6
bsquare
Member#: 1911
2000 Impreza 2.5RS
Yes, Nology wires are garbage:
http://www.magnecor.com/magnecor1/truth.htm
Note that although it is a Magnecor page, the testing that showed Nology wires reducing power was done by an independent magazine. The physics of Nology's snake oil is well described, and that page is a great primer on the technology of ignition in engines.
Ben
Old 10-07-2001, 03:51 PM   #7
DarkImpreza
Member#: 3607
98 Impreza RS
black
damn, what about MSD wires? I think manacore is abit expensive
isn't it?
and if I am changing spark plugs which once do you guys prefer?
Old 10-07-2001, 10:39 PM   #8
bsquare
Member#: 1911
2000 Impreza 2.5RS
Once again, are you even upgrading your ignition system (meaning you are installing higher output coils, such as MSD, Crane, or a TEC-II)? If not, you will not really see a benefit from upgrading the wires, though if your wires are degraded, a new set of stock wires might be in order.
I use Magnecors with my TEC-II and they are top quality. A very well insulated, high quality conductor wrapped in silicone. Exactly what is wanted in an ignition wire.
Ben
Old 10-08-2001, 01:41 AM   #9
DarkImpreza
Member#: 3607
98 Impreza RS
black
ya I think my wires are leaking, thats why I am thinking
since I am changing it why not go for aftermarket one then
Old 10-08-2001, 02:22 AM   #10
bsquare
Member#: 1911
2000 Impreza 2.5RS
A set of Magnecor 8.5mm wires should be less than $50. You might save $10 by going with Jacobs wires.
Ben
Old 10-08-2001, 08:03 AM   #11
DarkImpreza
Member#: 3607
98 Impreza RS
black
you mean 50$ U.S right?
I am in Vancouver by the way =)
so should be around 100$CDN after tax anyways=)
but ya thanks alot for the help really appriciate it=)
Old 10-08-2001, 06:07 PM   #12
sidewayz
Member#: 5810
2001 S366 2.5RS
Originally posted by bsquare
Stick with a quality manufacturer like Jacobs.
Ben
Jacobs..A quality manufacturer
Those wires suck! have fun pulling the wire right through the boot
sidewayz is offline   Reply With Quote
Old 10-08-2001, 07:14 PM   #13
bsquare
Member#: 1911
2000 Impreza 2.5RS
I suspect anyone can tell a negative story about any manufacturer. I use Magnecor and have had no problems with them, but I'm sure someone out there can tell a story of their Magnecor wires being junk.
Ben
Help: Ignition Lock Cylinder kpotzmann Service & Maintenance 7 02-03-2010 01:19 PM
HELP: I NEED 02+ WRX ignition coils xlur8ed Private 'Wanted' Classifieds 0 10-01-2009 06:26 PM
Help: Candidate for Ignition upgrade on an RS-T? kgb Normally Aspirated with bolt-on Forced Induction Powertrain 18 12-07-2006 01:01 AM
DPR Headquarters releases Ignition Solutions direct replacement ignition coils. DPR Racing Int. Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-22-2005 08:36 PM
('93-'01) Exhaust Igniter Kit????? cpages2 Impreza Forum 3 04-10-2001 05:43 PM
