Old 04-29-2006, 03:48 PM   #1
ttatsumi
Member#: 85763
Default clutch question
i own a 02LGT 5 speed.
First...i know how to drive manual. or at least i do...anyways i have some questions regarding my clutch. the clutch works perfectly fine most of the time but SOMETIMES...when i press down on the clutch...theres a squeeky noise...i checked my clutch fluid and its not too much or too little...its at the perfect fluid level.
Second... when i get stuck in traffic and after 20mins being stuck in traffic, theres increase in free play. maybeeee about double or triple of what its supposed to be...but when i let the car sit for 30mins+ everything works fine again.
i was wondering if my clutch is glazed? or theres a air blubble in the clutch line? or any other possibilities?
if anyone has any ideas, please help me.
thanks.
ttatsumi is offline   Reply With Quote
Old 04-29-2006, 08:59 PM   #2
suby2low
Member#: 82633
'08 WRX STI
the squeaking is probably just coming from the slave cylinder or the pedal itself. due to not being greased from time to time. as for the freeplay. you have me stumped for the moment. do you sit in traffic holding the clutch in? or do you put the trans in neutral and let the clutch out?
suby2low is offline   Reply With Quote
Old 04-29-2006, 11:57 PM   #3
ttatsumi
Member#: 85763
i leave it in neutral and pop the clutch out. I only step on clutch when i need to shift...i heard holding the clutch down all the time is not good?
is there a thread on the forum about greasing that part? i need help. I dont know where its located and i dont even know how it looks like...if anyone knows help meeeee... thanks.
Old 04-30-2006, 01:29 PM   #4
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
You might want to get any air out of the line, that could be suspect. Other than that I'm not sure what it could be.
As for greasing the parts, yoiu should try the tranny and driveline forum.
~Mike
pilfflip is offline   Reply With Quote
Old 04-30-2006, 01:39 PM   #5
ooberdoob
Member#: 70418
Five Subarus later I
drive a lifted TJ.
(squeak is just in need of a little grease, which i'm too lazy to do.) otherwise:
my clutch did the same thing in NC.
moved by the ocean here in RI and it quit????????
i had COMPLETELY flushed and bled the lines too. no benefit. i understand it's the clutch master being a bastar'
i'm not gonna pay that till it's dead
ooberdoob is offline   Reply With Quote
Old 04-30-2006, 02:57 PM   #6
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
The play sounds like a bad master or slave cylinder seal. This can only be resolved by repairing or replacing the faulty unit. The squeak may be related to the faulty part, or might be something as simple as the pedal assembly. Try to determine if the sound is coming from inside or outside of the cabin.
DLC is offline   Reply With Quote
Old 04-30-2006, 04:39 PM   #7
ooberdoob
Member#: 70418
drive a lifted TJ.
i mentioned slave and the guys at work all said the master....
we'll see what happens when i head to NC in a few weeks.
Old 05-01-2006, 01:06 PM   #8
ttatsumi
Member#: 85763
thanks guys.
Old 05-02-2006, 12:05 AM   #9
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
well, they don't know then. Mine just started acting up, and someone pulled up a tech service bulletin. It is the slave cylinder (subaru calls it the operating cylinder). Also, the clutch hose gets replaced. It is all located on the top of the trans, under the air filter box.
It takes about 30 minutes to replace everything and was REAL easy to do (though I tightened my banjo bolt too tight and broke it. I had to wait for a new one to be shipped, grrrrrrr). It is only a few bolts total and then a fluid bleed. no problem at all and now my clutch system feels brand new, like it is straight off the lot...
janikphoto is offline   Reply With Quote
Old 05-02-2006, 12:08 AM   #10
janikphoto
Member#: 10471
2000 BMW Z3
... when i get stuck in traffic and after 20mins being stuck in traffic, theres increase in free play. maybeeee about double or triple of what its supposed to be...but when i let the car sit for 30mins+ everything works fine again...
I think the bad slave cylinder is making it feel like you have more play, though the actual play stays the same. Mine would act up after driving, when things got hotter under the hood. I think the part would sieze up more when it got heat soaked. Replace the operating cylinder, hose and two crush washers, you'll be happy you did.
Old 05-30-2006, 10:24 PM   #11
jkyes
Member#: 707
99 Legacy GT
Quick silver
MY Clutch just went to the floor sunday. It did work to some extent, but only when all the way to the floor, then when i let go, there seemed like no power return(hydrolic pressure). I could get it in gear, but barely. anyone else have a problem with this. I am looking into replacing the slave and master clutch cylinder. from what i have read this seems pretty straight foward. Anyone have any hints or ideas for me?
jkyes is offline   Reply With Quote
Old 05-31-2006, 02:22 AM   #12
janikphoto
Member#: 10471
2000 BMW Z3
There is no problem doing the slave, just don't over-tighten the banjo bolt. Everything is so easy your grandma could do it. I even bled the line myself, as I could move the clutch fork back and forth and work the bleed valve all from the same spot. Real easy to do (assuming you don't have some mega-heavy sports clutch that you can't move with your hand at the fork)... I haven't done a master cyl yet, so I can't say how involved it is.
Old 05-31-2006, 02:49 AM   #13
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Pfft.. I'm about a month late on that reply. And I didn't finish reading before I posted, so I posted the same thing as above. So now I'm removing it.
Speedwagon is offline   Reply With Quote
Old 05-31-2006, 06:31 AM   #14
jkyes
Member#: 707
99 Legacy GT
Quick silver
How did you know if it was the master or slave? I just know my clutch has no hydrolic pressure and it sounds like the correct deduction on what to fix. my other problem is that when i send my parts request the subaruparts.com the came back with only one cylinder not two... do all our cars(99 in particular) have master and slave?
any and all help would be appreciated.... of all car stuff i can handle, brakes and clutch are not an area i have dabbled in much.
Old 05-31-2006, 08:53 PM   #15
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Its the slave.. There is a Subaru bulletin on it
aross is offline   Reply With Quote
Old 06-01-2006, 06:30 AM   #16
jkyes
Member#: 707
99 Legacy GT
Quick silver
Thanks... any chance you or anyone can find a part number for that...i have been looking, and i did just order what i think is the master, but i can not find a number for the slave.
Old 06-01-2006, 01:10 PM   #17
ooberdoob
Member#: 70418
drive a lifted TJ.
i gotta replace it, it's doing it again
Old 06-01-2006, 02:45 PM   #18
janikphoto
Member#: 10471
2000 BMW Z3
If you look at the slave when you pull it off, it gts a sludge build-up on the piston. I think this contributes to the problem. I think the part numbers are in the tsb, which was linked to a thread around here somewhere. I just walked into my dealership with a print-off of the tsb. You need at least three things (operating cyl and two crush washers - my thought is that the hose is not a MUST to replace unless it is showing cracks or wear)...
Old 06-01-2006, 03:04 PM   #19
ooberdoob
Member#: 70418
drive a lifted TJ.
i wonder how much a stainless line would be?
Old 06-01-2006, 03:11 PM   #20
Idahoser
Member#: 78147
93 impreza 4dr
280.000 and runs 100+
What fluid are you running? Might try dot 5 if you have 3 in there.
Idahoser is offline   Reply With Quote
Old 06-01-2006, 03:28 PM   #21
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
97 LegacyGT Wagon 4EAT
In reference to finding a part number, I recommend e-mailing Jamie @ subarugenuineparts. Very helpful, good prices, fast shipping
GTWagon_Phreak is offline   Reply With Quote
Can anyone identify this transmission, clutch, and flywheel? +Clutch questions! 2002_wrx Transmission (AT/MT) & Driveline 4 11-26-2011 11:29 AM
Drivetrain question on '03 rex - gearing/clutch question swalker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-19-2005 03:55 PM
Crappy clutch question (My questions is different I swear!) Huntlick Transmission (AT/MT) & Driveline 7 10-11-2001 12:55 PM
('93-'01) Newbie clutch question..... Samirr76 Impreza Forum 8 05-21-2001 05:31 PM
clutch questions and help greg Mid West Subaru Owners Club Forum -- MWSOC 4 08-17-2000 07:42 PM
