Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 04-29-2006, 04:10 PM   #1
Dobes
Member Sales Rating: (4)
Member#: 164
1997 Legacy GT-T
Default EJ25 longblock, transmission, and WRX rear diff
Legacy parts are from a one owner, old lady driven 5-speed car. I pulled them for a swap and no longer need these things.
1. Stock EJ25 motor from my 1997 Legacy GT. The car had a blown headgasket so it'll need to be replaced along with the valve cover gaskets. Currently the motor is stripped down and comes with what you see (flywheel, heads, etc). There was 150k miles on this motor. $300. Only available for pickup.
2. Stock 1997 Legacy GT manual transmission. I'm pretty sure this is the same as in the early RS's but I can't confirm that, you'll have to double check. There's 150k miles on this and it worked great when pulled. $150. Only available for pickup.
3. 2002 WRX rear diff - needs work. The diff made a hell of a whine so I replaced it with a low mileage unit. Unknown origin, unknown miles. There seems to be a bit of play in the pinion bearings but the gears look ok. You'll have to fiddle with it to make it work. Also, one of the retaining plate bolts is broken off in the housing, it needs to be drilled out. FREE for the taking. Only available for pickup.
Diff is the one in the rear of this picture:
Please IM for more info or go here for more pictures: http://www.pbase.com/jeffdoble/subar...stuff&page=all
Thanks,
JD
Dobes is offline   Reply With Quote
Old 04-29-2006, 04:55 PM   #2
nottofast
Member Sales Rating: (56)
Member#: 89663
1962 Fuji 350
cerelean blue
PM sent on the rear.
nottofast is offline   Reply With Quote
Old 05-01-2006, 08:07 PM   #3
Dobes
Member#: 164
1997 Legacy GT-T
One TTT before listing on the regular classifieds.
WTB auto driveshaft and wrx rear diff WR_BLUE_05_X Tri-State Area Private Classifieds 1 04-06-2010 05:49 PM
WRX rear axles, and WRX rear diff RSTi.ftw Drivetrain 3 10-14-2008 08:19 PM
GI: JDM v8 6mt transmission and r180 rear diff akcel Drivetrain 2 08-22-2008 07:33 PM
FS: Two 92-94 legacy transmissions and one rear diff delosew NWIC Private Classifieds 2 06-22-2008 11:45 AM
FL People: Anyone have/know where I can find a WRX Tranny and WRX rear diff or... latinskllz South East Region Forum 1 05-13-2003 08:41 PM
Message Board Statistics All times are GMT -4. The time now is 01:23 AM.
