Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-30-2006, 12:27 PM   #1
AaronWRX
Member#: 7194
2011 997.2 Turbo
Have a Nice Day? Utec spare solenoid parameters?
Can someone check this?
The directions for the spare solenoid is the red wire goes to (relay, whatever) and the black wire goes to ground.
I have my multimeter hooked to the black wire (which is connected to a ground point on the car) and the red wire to the multimeter.
I set the parameters to what I think would turn on the solenoid at anything ober 4 TPS. It's just not working. Any ideas?
Code:
	PARAMETERS		  USER CONSTANTS	 TURBOXS STi UTEC (Ver 1.1c) (c) 2004
 PARAMETER									  RANGE	   VALUE
 Shift Light 1 ON RPM (x100)				  (0 to 80) :   48
 Shift Light 2 ON RPM (x100)				  (0 to 80) :   58
 Shift Light 3 ON RPM (x100)				  (0 to 80) :   68
 Spare Solenoid ON above RPM (x100)		   (0 to 80) :   0
 Spare Solenoid OFF above RPM (x100)		  (0 to 80) :   80
 Spare Solenoid ON above TPS (%)			 (0 to 100) :   4
 Spare Solenoid ON above Air Temp. (deg. C)  (0 to 100) :   0
 Spare Solenoid ON above Coolant (deg. C)	(0 to 100) :   0
 Spare Solenoid ON above MAP (psi)		  (-50 to 50) :   -50
 Spare Solenoid OFF Delay Time (seconds)	  (0 to 10) :   0
 CEL (DISABLE = 0, NORMAL = 1)				 (0 or 1) :   1
 MAP Display (ABSOLUTE = 0, GAUGE = 1)		 (0 or 1) :   0
 Baud Rate (4800 = 0, 19200 = 1)			   (0 or 1) :   1
 Launch Control RPM (x100)				   (20 to 80) :   55
 Launch Control (OFF = 0, INJ = 1, IGN = 2) (0, 1 or 2) :   0
 Launch Control of Spare Solenoid	 (OFF = 0, ON = 1) :   0
 For Future Use										 :   0
AaronWRX is offline   Reply With Quote
Old 04-30-2006, 12:30 PM   #2
AaronWRX
Member#: 7194
2011 997.2 Turbo
this is what im trying to do:
everything on the WI side is hookied up and i can make is spray by hooking power right to the pump but for the life of me i cant get the utec to "solenoid" to trigger power.
Old 04-30-2006, 03:08 PM   #3
Gethin
Member#: 2998
Does the dashboard show that the spare solenoid is being triggered with TPS above 4% ? If not then it's something in the parameters. If it shows on the dashboard that the spare sol is being triggered but you're not getting any pump action it's your wiring.
My wiring looks more or less like yours, apart from that my pump is on the other side of the relay, i.e. 12v goes into the relay directly then the pump is on the other side.
Gethin is offline   Reply With Quote
Old 04-30-2006, 03:15 PM   #4
AaronWRX
Member#: 7194
2011 997.2 Turbo
yeah... i just realized a little while ago that the red wire on the utec plug (7) is not power. Its switched ground. Still im at a loss on how to wire this.
This is what I originally tried:
Code:
Utec 1 --> ground (black wire)
Utec 7 --> 85 redwire
        87--> pump
     86|-->ign 85| --> utec 7
         30--> battery
someone send me a clue.
Old 04-30-2006, 03:35 PM   #5
AaronWRX
Member#: 7194
2011 997.2 Turbo
Im testing this now:
utec-red-wire(7) ---> ground of a test light
12v ----> red wire on test light
utec-black-wire(1) --> ground
anything ober 4 tps should light up my test light but its not. any ideas?
Old 04-30-2006, 03:43 PM   #6
Gethin
Member#: 2998
Old 05-01-2006, 01:03 PM   #7
AaronWRX
Member#: 7194
2011 997.2 Turbo
RESOLVED: I had it hooked up right but the car must be running. apparently a min RPM of 0 isnt enough.
electrical output specs for UTEC spare solenoid? dave_the_driver Engine Management & Tuning 10 08-04-2003 05:24 PM
Utec spare solenoid for water spray, but... kenchan Engine Management & Tuning 5 07-14-2003 11:23 AM
Utec spare solenoid activation problem codean Engine Management & Tuning 8 06-02-2003 06:39 PM
Utec spare solenoid power not working... codean Engine Management & Tuning 5 05-07-2003 01:18 AM
UTEC spare solenoid problem David@Vishnu Engine Management & Tuning 5 04-07-2003 11:58 AM
