Old 04-30-2006, 02:28 PM   #1
SubyGuy86
Member#: 107734
1995 White Impreza L
^wrecked as of 8/16/2006
Question Another trans swap question
I just emailed my closest Subaru parts place about a 5speed for my L, so this is a question to all with experience swapping transmissions. To change my auto trans. to the 5speed, from what I know it should involve some cutting in the firewall and some light fabrication. But what I really wanna know is can I use the same ECU or do I need the ECU off of the 5speed car I'm open to any info or helpfull tips that would make this as easy as possible. THANKS.
*Mike*
SubyGuy86 is offline   Reply With Quote
Old 04-30-2006, 03:06 PM   #2
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Since the L came in a 5spd the swap should be pretty easy. I am in the process of swapping a 5 spd into a SVX and it is a pain. They only came as automatics so you have to do a ton of fabrication work. I will be using the stock ecu with a slight wiring change to accomadate the neutral switch and the clutch switch so I can still use the cruise control.
btw I have an extra 5 spd for sale (250 + shipping). It's from a 01 Forestor and has 411 gearing with a 1:1 center diff.
http://forums.nasioc.com/forums/showthread.php?t=991783
LiquidForce is offline   Reply With Quote
Old 04-30-2006, 05:10 PM   #3
SubyGuy86
Member#: 107734
sssssoooooo I don't need the 5spd ECU???
Old 04-30-2006, 05:21 PM   #4
amorton
Member#: 72798
2000 2.5 RS Sedan
Blue Ridge Pearl
I just did this swap on my 93L, sort of. I did an entire AWD/Auto to manual conversion. As far as fitment you donít need to do any fabrication, the trans bolts right in, I think you need a manual transmission crossmember, although I may be wrong on that. As far as the computer goes the Auto computer will work fine you just need to make the ECU think it is in manual mode. The car uses a separate computer to run the auto transmission. http://www.surrealmirage.com/subaru/swap/swap.html if you read this is should give you everything you need.
amorton is offline   Reply With Quote
Old 04-30-2006, 06:45 PM   #5
SubyGuy86
Member#: 107734
Sweet! Thanks a lot!
Trans swap question 4subaru Transmission (AT/MT) & Driveline 0 01-05-2010 01:01 AM
trans. swap question... subarusoldier Transmission (AT/MT) & Driveline 2 07-10-2009 06:26 PM
Couple trans swap questions former3g Subaru Conversions 3 04-29-2009 01:55 AM
trans swap question. SubyImprezaRS-T Transmission (AT/MT) & Driveline 5 05-09-2008 02:41 PM
AT to MT trans swap questions and pricing greddy18 Transmission (AT/MT) & Driveline 6 02-13-2008 01:08 AM
