Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 04-30-2006, 05:49 PM   #1
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
Cool Attn: All Emanage Users
Who out there is using Emanage or Emanage ultimate on there Subarus and with what engine setup?
I want to see how many users on here are actually using the emanage or just contemplating it.
jkjersey is offline   Reply With Quote
Old 05-01-2006, 11:28 AM   #2
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Hitokiri is offline   Reply With Quote
Old 05-03-2006, 04:47 PM   #3
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
That's it only Hitokiri using emanage out there? Or at least browsing this section of the forums.
Old 05-03-2006, 06:02 PM   #4
GC8 Andy
Member#: 114092
1994 impreza turbo
blue
Have just installed ultimate on my UK Impreza Turbo,but i am having some problems.I can add or trim fuel no problem,problems when i try to add timing.
I will have another look at weekend.
GC8 Andy is offline   Reply With Quote
Old 05-08-2006, 12:11 AM   #5
Pecosdude
Member#: 93033
- SG5 & GVF
I am currently using Emanage Ultimate.
I have upgraded the turbo and injectors on my car. (DB super16G turbo + PE 800 cc injectors)
No problem so far as to adding/trimming fuel & timing.
You can also have the Emanage Ultimate to autotune the AFR by connecting a wideband AFR to the unit.
The cons so far :
1) The Analog voltage clamp is not working properly.
2) The Emanage Ultimate DOES NOT HAVE a boost controller.
You have to buy a separate electronic boost controller.
(I bought the DTEC unit, one of the best electronic boost controller)
Pecosdude is offline   Reply With Quote
Old 05-08-2006, 04:27 PM   #6
GC8 Andy
Member#: 114092
1994 impreza turbo
blue
Had another look this weekend seems EMU will not read cam or crank sensor signals. having to read RPM from ignition signal may explain why cannot advance timing.Am running 2.5 bottom end, Wisco pistons ,STI3 heads and cams, equal length headers,reverse inlet and FMIC . Next upgrade 20G.
In UK Apexi PFC very popular but i wanted to try something a bit different,already running Apexi AVCR but i think you can control boost using sub injector map of EMU to alter duty cycle of boost control solenoid.
Old 05-08-2006, 05:57 PM   #7
CUTTER
Member#: 114459
Im thinking of getting a altimate. Any ebay reviews?
CUTTER is offline   Reply With Quote
Old 05-27-2006, 10:43 PM   #8
project_legacy
Member#: 114408
1999 Subaru Legacy L
30th AE Maroon
i am also looking into an emanage, and maybe even an ultimate, if the price is right. i would love to see more feedback. BTW, this would be going in my 1.8L impreza, with a Frankenstein motor.
project_legacy is offline   Reply With Quote
Old 05-29-2006, 01:56 PM   #9
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
GC8Andy - Did you call Greddy technical support. On my Emanage I could advance timing I am sure you can on the Emanage Ultimate.
Old 05-30-2006, 12:46 AM   #10
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
you can 100% control boost with the sub injector map.
There is nothing better at all out there for our older ECUs hands down. Anyone have any questions feel free to shoot me a pm.
Old 05-31-2006, 08:16 PM   #11
Brydon
Member#: 107569
1998 Forester S
SRP
I have a sti shortblock with wiseco pistons and wrx heads with springs and retainers... I also have a gt35r turbo. I am using a emanage ultimate to control fuel and timing and boost cut. So far it works great and has a wonderful interface to work with. It is pretty easy to do tuning with. It also data logs well. I still need to wire up a wide band to see if the open loop tuning works. but so far it is very fast. Oh its in an 93 impreza with a full 04 wrx wiring harness dash etc. The ecu is actually an 02 wrx becuase they come out of closed loop faster. Its quite the mut but the emanage ultimate has worked great for me.
Brydon is offline   Reply With Quote
Old 07-09-2008, 02:24 AM   #12
xtcass
Member#: 184093
Sorry for bringing back this one from the dead...but is it possible to use the EM ultimate with the stock boost control?
Thanks
xtcass is offline   Reply With Quote
Old 07-13-2008, 07:26 PM   #13
rdodger
Member#: 156447
99 18g'd 2.5RS-T
I believe you can but it may not function properly due to the tricked ecu signals, but you should really connect your solenoid to the sub injector output then you have your own mapped programmable boost control.
Thanks
rdodger is offline   Reply With Quote
calling all emanage blue users - idle problems mxpunk Normally Aspirated with bolt-on Forced Induction Powertrain 10 11-16-2007 09:03 PM
ATTN: All central fl Accessport users SubieSport02 South East Region Forum 5 03-12-2005 06:23 AM
Attn: All SBC yahoo dsl users MyScoobie28 Off-Topic 22 12-28-2004 02:03 PM
To all IPOD users... or future users. BHodges3 Off-Topic 14 04-13-2004 09:23 AM
Attn: All EcuTek, UTEC, Link, AEM & S-AFC Users!! schwarzenegger Vancouver Impreza Club Forum -- VIC 22 11-26-2003 12:20 AM
