Old 05-01-2006, 06:21 AM   #1
MKopack
Member#: 113853
2005 Baja
Silver / Gray
Default Speedometer failure - speed sensor?
Hello all,
Driving into work this morning, my speedometer needle on my '95 Legacy/Outback began to 'wobble' for a minute or so and then went straight to zero. The cruise control ceased to function at the same time (I assume that they both get their signal from the same place...)
Has anyone dealt with this before? Speed sensor perhaps?
Is this something that I could reasonably change myself? (Relatively accessable?)
Mike Kopack
[email protected]
MKopack is offline   Reply With Quote
Old 05-01-2006, 11:37 AM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
isn't that year's speed/tach run by cables? maybe a loose connection?
I'd take off the cluster and take a peak, making sure everything is still hooked up right.
fibuz
fibuz is offline   Reply With Quote
Old 05-01-2006, 05:24 PM   #3
subjfd
Member#: 106854
Well, mine has the same issue, and I checked first if the cable hooked up to a drill made the speedometer turn. The answer was yes. I knew then that the cluster, speedo and cable worked. There is only one option left (if you car is a 5 speed), and it's the tranny gear, but for that you need to drop the exhaust and tranny, disassemble the tranny, and I do not think it is worth it for me. So I followed a friend on the highway, and made marks on my tach, so I know my topspeeds in 5th gear.
subjfd is offline   Reply With Quote
Old 05-01-2006, 05:32 PM   #4
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
2007 Legacy GT Spec-B
Same thing hapened to me. I think it was $100 for the part. You can fix it yourself. Just un skrew the sensor from the passenger side of the transmission housing and replace the sensor. Shouldn't take more than 30 mins to do.
V8Slayer is offline   Reply With Quote
Old 11-15-2006, 10:44 PM   #5
disque71
Member#: 57330
2008 WRX
where is this located on the tranny?
disque71 is offline   Reply With Quote
Old 11-16-2006, 09:25 AM   #6
sha_zapple
Member#: 41012
1998 Legacy L
I posted up a picture a while ago from a FSM i had
http://forums.nasioc.com/forums/show...t=speed+sensor
sha_zapple is offline   Reply With Quote
speedometer cable issues/speed sensor Draino Transmission (AT/MT) & Driveline 2 02-07-2007 06:01 PM
'95 Speedometer/Speed Sensor Failure MKopack Outback Forum 6 06-13-2006 02:03 PM
Speedometer failure? Anyone? 2yLiTe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-23-2003 09:37 AM
Wheel Speed Sensor Failure? Hitokiri Service & Maintenance 2 06-12-2003 05:33 PM
Speedometer failure & simultaneous CE matt7102 Service & Maintenance 2 05-30-2003 09:18 PM
