Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 05-01-2006, 02:28 PM   #1
Zrex11
Member#: 94881
1989 Hoopty Stylez
Road Slipper
Default Launch control with ecutek
other than by using a utec do any of you guys know of an alternative way to get some launch control that i could run with my ecutek flash?
Zrex11 is offline   Reply With Quote
Old 05-01-2006, 09:06 PM   #2
Zumble
Member#: 34860
2005 Forester CGM
Yes, get a Hydra...
Zumble is offline   Reply With Quote
Old 05-04-2006, 02:30 PM   #3
Zrex11
Member#: 94881
1989 Hoopty Stylez
Road Slipper
haha ok other then buying a whole different engine managment system.
Old 05-04-2006, 05:27 PM   #4
Freon
Member#: 88322
2009 BMW 135i
I thought for some cars Ecutek had a LC feature, but unfortunately the only way to make it happen on a reflash is for them to decompile and rewrite a lot of code. That's a lot more complex that just finding the maps and changing values. New logic code must actually be written and crammed into the limited space of the ROM without screwing anything else up.
I think there may be some aftermarket ignition systems that offer a two-step, but that might be just as bad as buying a UTEC or Hydra after it is all said and done. And that only gives you spark cut, not injector cut, which is arguably worse on your car.
Freon is offline   Reply With Quote
Old 05-11-2006, 07:52 PM   #5
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
I do not believe it is available, but I would confirm with EcuTeK about that.
Cheers,
William T. Knose Jr.
Lead Programmer
Crawford Performance / I-Speed USA
Crawford/I-Speed is offline   Reply With Quote
Old 05-12-2006, 01:39 PM   #6
Zrex11
Member#: 94881
1989 Hoopty Stylez
Road Slipper
thanks for the input here
-Z
Old 05-16-2006, 05:54 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i rememebr hearing somthing about LC for ecutek'd evos but not subarus
Old 05-22-2006, 05:35 PM   #8
FRSTi
Member#: 34180
2011 EDM STi sedan
1998 JDM 22B STi
There is another option left for STi owners...
Most Ecu's have a "no speed signal rev limiter", this safety feature is set to 6000 rpm on EUDM STi.
Using a push switch to open the speed signal circuit to Ecu & desactivating the relevant DTC, you get a nice "manual" assistance for launch until you release the switch.
Of course, this cannot be compared to the tek launch control, using a speed based rev limiter offset... but...
FRSTi is offline   Reply With Quote
Old 05-22-2006, 05:51 PM   #9
Freon
Member#: 88322
2009 BMW 135i
There is no stationary rev limiter in the USDM STI unfortunately. You can run it right up to 7k sitting still out of gear.
Old 05-23-2006, 06:52 PM   #10
Zrex11
Member#: 94881
1989 Hoopty Stylez
Road Slipper
yep it will just improve my launching skills till some day either ecutek will get on the ball with map switching / launch control, or I upgrade to a diff EM solution.
Old 05-23-2006, 10:00 PM   #11
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
You can do anti lag with Ecutek. Contact Ben at Ecutek for details. Ecutek put in specific settings into Rom files to adjust for this purpose.
Clark
AZScoobie is offline   Reply With Quote
Old 05-23-2006, 10:04 PM   #12
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
ECUTek offer map switching and launch control for the stock ecu. Contact them.
west_minist is offline   Reply With Quote
Old 05-26-2006, 05:41 PM   #13
FRSTi
Member#: 34180
2011 EDM STi sedan
1998 JDM 22B STi
Don't get me wrong, I'm not talking about "zero speed rev limiter" (or what ever speed you set to unleash the rev limiter offset like Ecutek does into the code), I'm talking about "no speed signal", no signal at all into the Ecu.
All STi Ecu's since 2001 have this feature... I guess it was designed to avoid speed signal wire cutting on 180 kph-limited JDM ecu's.
Using the method I described above with a push to open switch located on the wheel (opening speed signal circuit) gives nice result.
Old 05-26-2006, 09:03 PM   #14
AZScoobie
Member#: 8785
netcom.com
That also kills the AVCS.
Clark
Old 05-30-2006, 05:38 PM   #15
Zrex11
Member#: 94881
1989 Hoopty Stylez
Road Slipper
for the newer model vehicles? there may be some launch control feature but i can say almost w/o a doubt that there is not a map switching control, atleast at the customers end, the maps have to be loaded in from some one with a tuner license as far as i know.
Old 05-31-2006, 12:11 PM   #16
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
there is a map switching feature with the 2.0L non DBW ecus
Old 06-28-2006, 02:54 PM   #17
thejean
Member#: 17763
Clark
So I am to understand that you can do launch control and anti-lag with ECUtek. BUT, can you somehow access the ECU using other software to disable it for daily driving? Or, am I looking at a standalone for this functionality?
thejean is offline   Reply With Quote
***EcuTek coming out with FFS, Launch Control, Map Switching, Per Gear Rev Limits*** modaddict Commercial ECU Reflashes 42 03-18-2011 01:06 PM
Launch Control with AT trans & hydra? WickedRydaX Other Engine Management 4 06-03-2008 09:16 PM
Can Cruise control co-exist with launch control with the 2002 wrx Hydra? jigga Other Engine Management 5 04-17-2007 09:16 PM
Boost controller with Ecutek?? matdiot Engine Management & Tuning 1 04-17-2006 05:45 PM
Launch control with Protuner? Henryk Engine Management & Tuning 0 07-27-2005 09:42 PM
