Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 03-13-2000, 08:26 PM   #1
BeAn
Member#: 558
2002 WRX sedan
midnight black pearl
Have a Nice Day? Grinding noise... Legacy
I have a 91 legacy L sedan.. around 2500 rpms to 3000 rpms. i have a grinding noise sounds like metal, i have no clue as to what it is and dealer/mechanic couldnt find anything wrong.. its pissin me off of course. any ideas. it only happens during WOT and also when accelerating kinda hard like when the pedal is like 3/4 the way down. ok any help would be great. thanks
BeAn is offline   Reply With Quote
Old 03-14-2000, 03:32 AM   #2
PeteH
Member#: 431
Question
Hmmm, wierd, need more info. Where is the noise coming from (be as specific as you can) can you 'feel' it or do you just 'hear' it?
PeteH is offline   Reply With Quote
Old 03-14-2000, 03:08 PM   #3
BeAn
Member#: 558
2002 WRX sedan
Post
the noise is coming from the engine.. its not the tranny.. um seriously i have no clue its like mysterious the mechanic couldnt duplicate it only i can. its a high pitched whinigh noise that sounds like metel scraping . if no one has a clue dont worry about it.. im just awed as to what the hell it is
Old 03-14-2000, 04:02 PM   #4
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Post
BeAn, how many miles do you have on it? It could be alot of things but the water pump surley comes to mind. I've hear bad ones make anything from a whining sound, to a grinding sound, to a squeaking sound. I had mine replaced when I had the T-Belts done at just a bit over 100k, just because first gen water pumps are not known for their superior reliability For the price of one, it will sure save alot of hassle down the road if it leaves you stranded or worst case, your motor goes poof. If you did already have a new one, disregard this post .
Shik is offline   Reply With Quote
Old 03-14-2000, 08:51 PM   #5
BeAn
Member#: 558
2002 WRX sedan
Post
the car does have around 110k miles.. its serioulsy pissin me off. but would it be the water pump since it only happens during WOT, and hard acceleration. ok any more info would be great.
Old 03-15-2000, 02:31 AM   #6
Shik
Member#: 132
2015 WRX 6spd CWP
Post
To be honest, I've never heard of one only making noise at WOT, but I have heard of the noise being inconsistent( sometimes it would make a noise, other times it sounded normal), so in that sense I guess it's possible. A quick way to look is pop the hose off the pump, pull the T-stat out, and see if there is any metal shavings in the coolant inside the pump. The only problem is you'll lose most of your coolant in the process. A real bummer if the pump is OK.
If it were me, with 110k miles, I'd change the pump anyway. I think they're like 60 bucks or so. Even if it isn't the problem now, it most likely will be a problem down the road.
I've also heard loose crank pulleys make an awful racket. You can usually see those things wobbling when the car is idling.
Old 03-15-2000, 06:49 PM   #7
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
Post
I'd say the water pump.
My buddy had a maxima that would only make noise between 50-65 and once they changed the water pump poof the noise went away.
-mike
Paisan is offline   Reply With Quote
Old 03-15-2000, 10:30 PM   #8
BeAn
Member#: 558
2002 WRX sedan
Post
Ok the crank pulleys do look loose... they wobble a lil when idleing, how would i go about tightening them?, also how much would a water pump be from an auto store. and also is it a do it yourselfer project? any info would be appreciated. its seriously a problem. ok thanks,
mark
Old 03-16-2000, 02:55 AM   #9
Shik
Member#: 132
2015 WRX 6spd CWP
Post
Bean, if your crank pully is wobbling, I would take it to a dealer ASAP and have them do it as it should be put on with an impact gun and it needs to be tighter then tight! Until then I'd drive the car as little as possible. There is a little key that fits into the end of the crank. When the pulley comes loose, the key can start start wearing out the hole it fits in. Once the key no longer fits into it's hole on the crank, you're in big trouble. At least that's the way I remember it( it's been a while).
As far as the water pump, I'm not a big fan of non-oem parts and for the price, I'd just get one from Subaru but that's me. You'll have to take the T-Belt off so it may get involved. If your not real confident of your mechanical skills, I'd have the dealer do it. Good luck.
1998 Legacy GT makes rear grinding noise -schmitty- Normally Aspirated Powertrain 8 01-02-2008 07:22 PM
Weird grinding noise? Pikeadon Forester Forum 4 03-07-2001 10:59 AM
Brakes making a grinding noise! ImprezedRS Brakes, Steering & Suspension 7 03-01-2001 03:39 PM
grinding noise from rear of car N/A Technical Forum Archive 4 09-04-2000 10:14 PM
