Old 05-02-2006, 09:07 AM   #1
happasaiyan
Member#: 37731
Default strong vibrations at low rpms after clutch/flywheel install
yesterday i got my car back after having an ACT HD clutch and ACT streetlite flywheel installed. forewarning- i will be calling the shop later on today, just seeing if anyone has any idea, or has had this problem before.
the problem is- when i am in 1-4th gear at about ~1600rpms and am giving the car more than 30% throttle, there is a violent vibration. the vibration goes away after ~1750rpms, and everything seems fine after that. this is a pain when going around corners, or pulling away from stop signs since i am usually in 2nd and pulling from low rpms. the sound of the vibration gets amplified since it resonates through the whole dashboard and sounds really bad. yesterday i was driving with the wife, and she gave a disgusted look over to me and said "they broke your car" haha.
anyone have any ideas?
happasaiyan is offline   Reply With Quote
Old 05-02-2006, 10:15 AM   #2
herewegoagain
Member#: 107778
2006 Legacy GT Sedan
Obsidian Black
Engine/pitch mount broken or not fastened down?
What type of disk?
herewegoagain is offline   Reply With Quote
Old 05-02-2006, 01:31 PM   #3
happasaiyan
Member#: 37731
What type of disk?
street disk...going to call them now...
Old 05-02-2006, 02:29 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
As suggested check the mounts for the engine and pitchstop. also check the tranny subframe and mounts. Might also want to try rotating the driveshaft 90* and see if that helps.
Old 05-02-2006, 06:42 PM   #5
_blank
Member#: 97172
Bus Pass
_blank is offline   Reply With Quote
Old 05-02-2006, 06:54 PM   #6
happasaiyan
Member#: 37731
apparently, i am just a n00b to aftermarket lightened flywheels.
it was just me lugging the engine too much
Crude Transmission Deceleration and Acceleration Noise after Clutch/Flywheel Install caterpill Transmission (AT/MT) & Driveline 271 05-20-2015 05:36 AM
vibrating noise in glove box area at low RPMs... island boyeee Interior & Exterior Modification 26 01-10-2011 05:01 PM
Howdy! First post w/ problem clutch slips ? then grabs at low rpms?? Alex Germain Newbies & FAQs 15 03-25-2010 12:09 PM
problem with power drop at 4k rpm after injector/vf34 install. please help! ansonb505 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 02-21-2008 05:10 PM
Vibration at low RPM weggy Newbies & FAQs 9 10-17-2006 09:13 PM
